9th March 2010, 06:49 | #7201 | Link |
Hi jdobbs,
As promised yesterday, I re-ripped Batman,TDK, and let it cook overnight and through most today with DVD Rebuilder. Below is the log. [20:29:41] BD Rebuilder v0.32.07 (beta) - Source: THE_DARK_KNIGHT - Input BD size: 37.92 GB - Approximate total content: [03:47:28.960] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640 [20:29:41] PHASE ONE, Encoding - [20:29:41] Extracting A/V streams [VID_00010] - [20:29:42] Reencoding: VID_00010 (1 of 4) - [20:29:42] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 1,800 frames - [20:29:42] Reencoding: VID_00010, Pass 1 of 1 - [20:30:19] Video Encode complete - [20:30:19] Reencoding audio tracks (if req'd) - [20:30:21] Multiplexing M2TS - [20:30:22] Extracting A/V streams [VID_00005] - [20:30:35] Reencoding: VID_00005 (2 of 4) - [20:30:35] Reencoding secondary video [TRK_02] - [20:31:25] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 14,498 frames - [20:31:25] Reencoding: VID_00005, Pass 1 of 1 - [20:36:00] Video Encode complete - [20:36:00] Reencoding audio tracks (if req'd) - [20:36:02] Multiplexing M2TS - [20:36:06] Extracting A/V streams [VID_00008] - [20:39:28] Reencoding: VID_00008 (3 of 4) - [20:39:28] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 115,411 frames - Bitrate: 5,672 Kbs - [20:39:28] Reencoding: VID_00008, Pass 1 of 2 - [22:26:18] Reencoding: VID_00008, Pass 2 of 2 - [02:09:26] Video Encode complete - [02:09:26] Reencoding audio tracks (if req'd) - [02:09:51] Multiplexing M2TS - [02:11:10] Extracting A/V streams [VID_00007] - [02:28:56] Reencoding: VID_00007 (4 of 4) - [02:28:56] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 218,981 frames - Bitrate: 16,276 Kbs - [02:28:56] Reencoding: VID_00007, Pass 1 of 2 - [06:01:05] Reencoding: VID_00007, Pass 2 of 2 - [14:31:03] Video Encode complete - [14:31:03] Reencoding audio tracks (if req'd) - [14:33:16] Multiplexing M2TS [14:48:25]PHASE ONE complete [14:48:25]PHASE TWO - Rebuild Started - [14:48:25] Rebuilding BD file Structure [14:48:31] - Encode and Rebuild complete [14:48:31] BURNING BD structure to disc Unfortunately, the disc never burned. Here's what my computer said to me: I/O Error! Device (0:0:0) Pioneer BD-RW BDR-205 1.04 (D (ATAPI) SCAI Status 0X02 Interpretation: Check Condition SDB = AA 00 00 13 EO 20 0000 99 20 40 00 Interpretation = Write (12) - Sectors: 1302560-1302591 Sense Area - 71 00 04 00 13 00 00 0E 00 00 00 00 44 00 00 0000 00 Interpretation: Internal Target Failure Then when I click on "Retry" at the bottom of the message, the message simply repeats. When I go into the working files area and click on the streams to play with VLC, they do work. I am a novice with all these files as well as IMG Burns, so would you direct me (or tell me) what files (or folders) I need to manually drag over to IMG Burn, so I an see if a bluray 25 will work so I don't have to re run the program and try again for another 18 hours? Also, is 18 hours really necessary to get a high quality version of this disc? Thanks again, Richard |
9th March 2010, 07:37 | #7202 | Link |
@RichardB;
If you look inside of the destination folder you chose for your backup, you will see a folder named after your source. Inside of this folder will be two folders, BDMV and CERTIFICATE. Those contain the files you need to burn. You will want to use IMGBurn, udf 2.5. ( IMGBurn will set it up for you ) I would recommend creating an image first that you can test with a software player like PowerDVD. Then, if all looks good, test burn to a BD-RE for playback on your standalone. If all is still good, burn to BD-R. |
9th March 2010, 08:22 | #7203 | Link | ||
BluRay Maniac
@jdobbs, thanks for quick update. |
9th March 2010, 18:07 | #7205 | Link |
I'm not 100% sure (because I did not save the project so that I would be able to doublecheck now) but I have the impression that in batchmode 32.08 "forgets" the selected audio streams and uses the default settings.
Can anyone confirm this? +++++ Seems like I was fooled by BD RB: the conversion is fine with only the selected audio streams I wanted BUT BD RB displayed (after it had finished) ALL default audio streams and not the selection I had made. Last edited by DK; 9th March 2010 at 18:16. |
9th March 2010, 19:10 | #7206 | Link | |
Under THE_DARK_KIGHT source folder contains the folder: CERTIFICATE If I open CERTIFICATE I get a bunch of small files and two folders: BACKUP BDMV Do I drag the entire CERTIFICATE folder over, or just the BDMV folder, or any other combination / permutation? Also, what is udf 2.5 and how do I make sure it is activated? Richard |
9th March 2010, 19:36 | #7209 | Link | |
Imgburn normally sets UDF 2.50 automatically (for BD material) but you can doublecheck in the "Options" tab. Last edited by DK; 9th March 2010 at 19:39. |
9th March 2010, 20:15 | #7211 | Link | |
Latest release notes:
So you can set the B_PYRAMID=1 to enable strict pyramid, but is there any way to disable the --pic-struct command? |
9th March 2010, 21:26 | #7213 | Link | ||
10th March 2010, 00:31 | #7216 | Link | |
"Strict" isn't as efficient as "Normal", but is necessary for Blu-Ray compatibility.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
10th March 2010, 00:33 | #7217 | Link |
x264 ceased to work
Hi firends & BD Rebuilder enthusiasts,
Last weekend was the end of my Win7 RC1 and re-installation of a full version (windows 7-64 ultimate). Like with all re-installations usually comes trouble, first thing i tried is BD-Rebuilder to make sure everything was okay. I sucessfully Rebuilt a 'Movie only' with no problem = 100% working. HOWEVER, only two days after that, i am now unable to do anything. Each time i run BD-Rebuilder, when it gets to encoding, x264 stops working (looks like it crashes) I am currently running BD-rebuilder (0.32.05). Latest abvailable version = same result. Windows doesn't give any clue why x264 crashes. When the first crash happened, i was running Handbrake in the background (also using x264 as an encoder) so my first guess was 'x264 doesn't like to be run in multiple instances'. I closed everything and rebooted but no effect. Curiously, Handbrake doesn't seems to have any problem (still) using x264 (no crash) but nothin' to do when it's called by BD-Rebuilder (running alone in the machine). I also tough of a crappy data left over in some mysterious 'AppData/User/Roam/x264...' path but i cannot find where (if any) x264 would store temporary config data. Anyone have any clue on this ? Thanxs ! |
10th March 2010, 00:36 | #7218 | Link | |
In the THE_DARK_KNIGHT folder I have ONE folder ... CERTIFICATE under CERTIFICATE I have two folders... BACKUP and BDMV plus a bunch of little things (app.discount, bu.discount, id.bdmu,online.online,online.sig) did I screw up? What do I drag over? (Seems to me I can't drag the Certificate AND MDMV file together if BDMV is a subset of Certificate!?!?). Richard Last edited by RichardB; 10th March 2010 at 00:41. |
10th March 2010, 00:51 | #7219 | Link |
There are two folders you want, BDMV and CERTIFICATE. Check your original source disc, it will have two just like this. Any other folders are unnecessary.
So you should have one folder with the name "DARK KNIGHT" that was inside the destination folder you selected. That is the folder you want to direct IMGBurn to. And inside of that folder will be the other two folders. Thats it! |
10th March 2010, 00:53 | #7220 | Link | |
