24th January 2010, 16:11 | #6762 | Link |
can somebody send me m2ts file with DTS-MA 6.1?
24th January 2010, 18:22 | #6763 | Link |
Not 6.1 but you can get a couple 7.1 DTS-HD MA m2ts trailers over here: http://www.demo-world.eu/trailers/hi...n-trailers.php
-Lude |
24th January 2010, 18:38 | #6764 | Link |
I need 6.1
24th January 2010, 19:43 | #6766 | Link |
ripbot264.ini
24th January 2010, 20:33 | #6768 | Link |
How big is your m2ts file?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th January 2010 at 20:54. |
24th January 2010, 20:56 | #6769 | Link | |
24th January 2010, 23:15 | #6770 | Link |
I dont care so should you
I was talking about the rented video comment, but yes if they are ripped off then them as well.
My Installer's || |
25th January 2010, 02:15 | #6771 | Link |
ripbot264 and dvr-ms files.
Is there any way to get ripbot264 to encode a dvr-ms file? When I open the file it says "Please wait... Gathering information..." but it never finishes.
It would be great to avoid having to go through an extra step to remux this into another container. Thanks in advance. |
25th January 2010, 04:21 | #6772 | Link |
25th January 2010, 04:29 | #6773 | Link |
DieselDog
mplayer site has all types
http://samples.mplayerhq.hu/A-codecs/DTS/dts/ |
26th January 2010, 06:07 | #6774 | Link | ||
I've tried a newer ffdshow.exe file and re-installing codecs, but the problem remains. Any other suggestions? |
26th January 2010, 06:18 | #6775 | Link |
i'm trying to convert a blu-ray rip of Oldboy to mkv. it is a korean movie and i need subtitles. when i tell it to "build in picture" and start the conversion, it says conversion is complete after 1 second of initializing. if i reset the subtitle option, the conversion begins normally. the subtitle file i select is the one found in the job temp folder.
26th January 2010, 14:12 | #6779 | Link |
@Tolham
Send me 100 MB sample (.m2ts file) to www.mediafire.com. Use DGsplit. Show me log file from Logs folder
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 26th January 2010 at 14:15. |
26th January 2010, 17:49 | #6780 | Link |
i'm having issues with ripbot and blu-ray files. It's only recently though that it's happening. It's not related to 32bit or 64bit differences (i just finished trying that, it first started on win7 x64 and now on win7 x32)
When i load either the elementary h264 stream, or one that's inside an mkv container, i get an avisynth error "DirectShow Source: Timeout waiting for graph to start. M:\temp\Ripbot264temp\job1\getinfo.avs, line 2" It's also not related to just one movie. It started doing this on "The Fifth Element" last friday (64bit) and when i did a fresh install of 32bit (like only gpu driver, ffdshow, firefox, haali, java, avisynth) it worked fine. Yesterday i finished setting up the pc and tried loading "Land of the Lost" (in both mkv, then .264) it gave me the avisynth error. I tried earlier version,s same issue. I tried reinstalling avisynth, same issue. I'm pulling my hair out right now trying to figure out what's going wrong. I have coreAVC 2.0 installed (wasn't an issue before) and i have ffdshow rev3222 clsid variant (i'm thinking that might be the issue, but when windows was fresh install, it worked?). Can you please help me? I love ripbot 264, but if i can't get it to work, i'm not sure what i'll do! EDIT: i read the first page, downgraded my Haali (although .264 files inside .mkv container shouldn't be an issue, also haali changed something, the FouCC so that it can work around windows 7 stuff) and now all works just fine! Last edited by stumped; 27th January 2010 at 01:06. |
