24th July 2011, 18:10 | #4241 | Link | ||
I do. Since madVR's libav/ffmpeg dlls were renamed from *.dll to *.mvr there's no collision at all. Not between LAV filters and madVR at least. |
24th July 2011, 18:13 | #4242 | Link |
That's probably good then. We still need to convince J River to whitelist both madVR's decoder and LAV Video decoder so that we can start testing them in MC16.
24th July 2011, 18:18 | #4243 | Link |
I tested your current release and the problems with LAV Video Decoder not connecting to the default renderer are of the past. It was not the interlaced flags, but instead (as you noted in the tracker) the AR info which did the trick. Great!
Now, I was very confident that this will also solve my PowerPoint 2010 issue with one of videos you downloaded from our server (25_Video_MPEG2_Not_working_with_LAVSplitter_in_PowerPoint2010_Native.mpg), but no luck with this one. However, it does play fine if I use Elecard -> ffdShow or Elecard -> MS DTV-DVD Video Decoder -> ffdShow (raw) It's not working in the follwing cases: Elecard -> LAV Video Decoder LAV Splitter -> ffdShow LAV Splitter -> LAV Video Decoder LAV Splitter -> MS DTV-DVD Video Decoder LAV Splitter -> MS DTV-DVD Video Decoder -> ffdShow (raw) Elecard -> MS DTV-DVD Video Decoder PowerPoint will refuse to insert the clip or (if I use an existing Presentation already containing the clip) it will either state "medium not available" or freeze the App completely. At least today I only tested it on my Intel 4 Express Chipset Graphics, but as I had this issue already before LAV Video Decoder came out I know that it will also occur with ATI Graphics. I uploaded a pptx-presentation with the linked clip and some Graph Studio reports: http://www.mediafire.com/?9ry9aim077p4f6z If you can please have a look at it. The problem also happens with the PowerPoint Viewer 2010 so there is no need to install the full version of the App. P.S.: I also tried changing AR, interlace and threading options in LAV Video Decoder to no avail... Last edited by Sven75; 24th July 2011 at 18:35. |
24th July 2011, 18:18 | #4244 | Link | |
Typically, the first loaded wins. Last edited by e-t172; 24th July 2011 at 18:21. |
24th July 2011, 18:24 | #4245 | Link |
Sure, I get that, but, it's difficult to know for sure what the "first loaded" process is. I suppose it probably goes by how the graph is built in which case LAV would "win". However, I agree with madshi's approach of renaming the DLL's that are changed.
24th July 2011, 18:26 | #4246 | Link |
How do you define vanilla, though? The default static lib files produced for MSVC++ link to index numbers instead of function names. Which means that even if everything else is the same, if the index tables differ, getting a "wrong" vanilla libav/ffmpeg dll can already make your software crash, even if it's the same version family. I've already had this pleasant experience (2 different vanilla avcodec-53.dll files having different index tables).
24th July 2011, 18:27 | #4247 | Link | |
24th July 2011, 18:28 | #4248 | Link | ||
24th July 2011, 18:44 | #4250 | Link | |
For one, they are MPEG-TS files, but named .mpg? Oh well, that wouldn't break anything. However, the audio is flagged as stream_type=4, which is the ID for mpeg audio. If someone encodes stuff like this, it just will not work, sorry. I cannot support every broken file out there..
24th July 2011, 19:16 | #4251 | Link |
madshi/Nevcariel,
I don't remember if you recall me having real trouble with ts files. I filmed my computer during a test so that you can see what happens. First I open a normal mkv file (in this case the first episode of The Borgias). As you can see, nothing strange going on, it works fine. Then I open Underworld m2ts which is just one of many ts files that can't be played. The sound is garbled, the video it self runs at least twice as fast as it should. You can verify the filters used that they are all in use by going to the end of the video. You can download my film here: http://www.tcec-chess.org/xaurus_ts_video_truble.mp4 (filmed in 720p) Hopefully we can try to fix this, as of right now I am not even sure if the problem is with LAVfilters or madvr. I am using mpc-hc (latest build), madvr 69 (same with previous verisons), LAVfilters 0.30 and earlier LAVcuvid 0.9 (now LAV video isntead, but same problem with both). |
24th July 2011, 21:19 | #4252 | Link |
I would need a sample file that doesn't play properly to tell you anything.
Otherwise, the audio renderer is responsible for maintaining the reference clock that dictates when frames are shown - try using another audio renderer? On Windows XP, the renderes are directly linked into the audio drivers - bad drivers = bad renderer. On Vista/7 Microsoft put a proper mixer in between, where this wouldn't be a great problem. If you're on XP, try a renderer like ReClock - in fact, try it on whatever system you're on.
24th July 2011, 21:28 | #4253 | Link | |
Thank you. What I did was to remove AC3filter and add LAVaudio instead. And guess what? Now it works. And I have sound too. I remember asking you earlier why I couldn't get any sound into my external DAC with LAVaudio, but now I do. Did you add/change anything in the latest 0.30 version? Also, the DRC feature is great! |
24th July 2011, 21:32 | #4254 | Link |
AC3Filter does not work with DTS-HD (its a crappy implementation, instead of just ignoring the HD extension like any good decoder, it just fails miserably), maybe thats why it broke for you?
24th July 2011, 22:02 | #4255 | Link | |
Thanks for all your help! |
24th July 2011, 22:42 | #4256 | Link | |
My hobby website |
25th July 2011, 06:32 | #4257 | Link |
small bug report: LAV Filters (0.3) interferes with SIF1 (v1.20) as soon as I install the x86 splitter (even if I disable .avi support for the Splitter; may be the disabling optio in the installer doesn't work correctly) playback of SIF1 doesn't work properly. (If I disable the x86 splitter everything works fine.)
Cu Selur |
25th July 2011, 07:33 | #4258 | Link |
The version is 0.30 (read: zero dot thirty), not 0.3 (read: zero dot three). 0.3 is about a year old.
Anyway, the only thing LAV Splitter does when you install it, it sets itself up to be the source filter that handles AVI files. It doesn't do anything that would break anything else. Sounds to me like that filter you're talking about just doesn't like working with LAV Splitter, is all.
25th July 2011, 09:51 | #4259 | Link | |||
So after fixing my DXVA issues ( for those who want to have a insight view what was going on and how i fixed it http://forum.doom9.org/showthread.php?t=162021) , and retesting the result doesn't changed much except the 2 streams that showed sync issues also work in DXVA now without any issues, the Latm stuff stays problematic depending on the stream (how it was muxed flaged, does it use Scalable AAC ect). but all in all it works fantastically stable on the playback side with both Mainconcepts Mpeg-2 Decoder (switching between 4:2:2 Studio Profile Software Decoding and Hardware decoding works without issues) and Cyberlinks H.264 Decoder (no dynamic Hi10, Lossless and 4:4:4 Software switching possible yet, Lav Splitter + LavCuvid in combinatation with LavVideo it would be possible same for MPC-Video Decoder and LavVideo or Ffdshow) for *.ts Or put the whole Logic for this into MPC-HC directly (detecting stream with Mediainfo then decide based on the used Hardware for the most efficient Decoder or even the only working ones). this was done testing the 0.30 release one guy posted a BBC HD sample of a Beyonce concert here that indeed shows problems (stucks @ the first frame, no issues either with Mplayer though VLC also stucks some seconds but then plays) If it is damaged maybe after running it throug VIdeoRedo it can be made compatible with LavSplitter (though Lav Splitter should be able to parse this if mplayer, vlc are able too)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 25th July 2011 at 12:33. |
25th July 2011, 13:36 | #4260 | Link |
A friend posted a problematic trp file. No audio is being heard.
The file: http://www.sendspace.com/file/8v77k3 MediaInfo: http://pastebin.com/nBtREGvX Filters menu of MPC-HC while playing: http://lulzimg.com/i24/62f526.png (seems like the AAC is identified as mp1 audio) He used LAV Splitter and LAV Audio v0.30. |
