21st August 2019, 21:11 | #17201 | Link | ||
So, after I did that
Then I read this post Quote:
So, I re-extracted the zip from the first page and updated it. Changed my settings and added 3 jobs. Now it looks waaaay faster than before, but I used my stopwatch to count the time between finishing and re-starting of a server (the next chunk). That was just over 5 minutes, and the network usage to the roof, again Anyone else has that problem?
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
21st August 2019, 21:35 | #17202 | Link | |
I hope that a Wacom driver update will correct this. |
21st August 2019, 22:25 | #17203 | Link |
Ok, second job is going faster, just a few seconds between chunks, don't know why
First two jobs completed with an error. Combining chunks didn't run Code:
Error: The file 'E:\Temp\RipBot264temp\video.264' could not be opened for reading: open file error.
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B Last edited by slalom; 21st August 2019 at 22:38. |
22nd August 2019, 02:47 | #17204 | Link |
Hey Atak
About week (maybe two) there was a update that is started causing weird issues on my system. I'm using DE. I don't know how to describe the, issue, in few places in a file, the video turns in a flashing slideshow with bunch of random frames from previous scenes. Its weird. here is the sample https://www.mediafire.com/file/woqlu...ample.mkv/file |
22nd August 2019, 06:33 | #17205 | Link | ||
ByteShare
I recall having that issue with some characters in a filename. Quote:
I noticed it with a new file. Going to see if I get the same issue rerunning the file as I tried encoding just the part with issues in isolation and didn't have an issue. The video had frames randomly from the end of the file well before the end of the video. Here is the source (00), the encode with the issue (01), and the re-encode from the source once I cut it down to the 8s clip (02): https://mega.nz/#F!UhIHTSzK!WziTOfYZYG80sLYHlu-DHg I've been going through and not every file has this issue so I'm not sure what is causing it. Seems to be very common on my videos over 30min. At this point encoding doesn't seem stable to me. Last edited by byteshare; 22nd August 2019 at 07:09. |
22nd August 2019, 08:52 | #17207 | Link | |
Anyway I closed and started Ripbot and the next encode completed successfully I need to check network usage today. I suppose the usual are short spikes about 30% network usage when completing chunks, but I saw higher and longer usage at some point. I need to see that again today
22nd August 2019, 09:11 | #17208 | Link | |
I've gone back to 1.24.1 and everything is spot on. I don't see why we needed LSmash when everything was working fine with FFMS. There seems to be no advantage to LSmash so why go through all the problems?? |
22nd August 2019, 09:49 | #17210 | Link |
Regarding flashing frames. What codec is used in source file? Mpeg2,avc,hevc?
22nd August 2019, 14:29 | #17211 | Link | |
it happens a lot in longer files. it all started about 1-2 weeks ago Code:
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 26 min Bit rate mode : Variable Bit rate : 5 150 kb/s Maximum bit rate : 25.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.099 Stream size : 3.04 GiB (87%) Writing library : x264 core 135 r2345 f0c1c53 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5150 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Code:
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 47 min 12 s Bit rate mode : Constant Bit rate : 9 322 kb/s Nominal bit rate : 10 000 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.188 Stream size : 3.07 GiB (94%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 |
22nd August 2019, 15:06 | #17212 | Link | ||
ByteShare
I added the media info files here: https://mega.nz/#F!UhIHTSzK!WziTOfYZYG80sLYHlu-DHg So far I've only managed to get through one file and it repeated the issue with the frames. ---Update: I also confirmed this issue with another AVC L4.0 file NOT using DE mode, so it doesn't seem exclusive to DE mode. ...besides the flashing frames the slowness of creating index files for every chunk is a major issue since it makes some encodes overall very, very slow even when the actual encode times are fast. Is there a way to speed this up by using the .lwi file we create when we're adding jobs? Quote:
Network usage, yes? At what point is that happening for you? I have two encoding servers but they are local so that might be why I'm not seeing those spikes? Last edited by byteshare; 22nd August 2019 at 16:57. |
22nd August 2019, 18:27 | #17213 | Link |
ByteShare
Just noticed the update from 8/20. Updated core from 8.17 to 8.20 (please consider changing the release number in the main window: 1.25.x)
Re-added the problem source videos as jobs. Realized that my encoding servers never started. I see the "Select SuperviseProcess.exe In the window I see this: Code:
[2019-08-22 11:21:04] C:\RipBot\EncodingServer.exe /start /restart-if-no-progress /minimize /ip 0.0.0.0 /port 2000 (PID:3268) executed. [2019-08-22 11:21:05] EncodingServer.exe (PID:3268) is responding. [2019-08-22 11:21:06] EncodingServer.exe (PID:3268) is responding. [2019-08-22 11:21:07] EncodingServer.exe (PID:3268) is responding. [2019-08-22 11:21:08] EncodingServer.exe (PID:3268) is responding. [2019-08-22 11:21:09] EncodingServer.exe (PID:3268) is responding. [2019-08-22 11:21:10] EncodingServer.exe (PID:3268) is NOT responding. [2019-08-22 11:21:11] EncodingServer.exe (PID:3268) is NOT responding. [2019-08-22 11:21:12] EncodingServer.exe (PID:3268) is NOT responding. [2019-08-22 11:21:13] EncodingServer.exe (PID:3268) is NOT responding. [2019-08-22 11:21:14] EncodingServer.exe (PID:3268) is NOT responding. [2019-08-22 11:21:15] EncodingServer.exe (PID:3268) is NOT responding. I've tried a reboot. I've tried killing my startup processes, I've tried closing everything I know to close. I can't get the encoding server to start. Non-DE mode starts and will try that in a bit. Running a StaxRip test since it uses the same filter to see if I get the flicker issue. Update: Stax only got 20% through the file before giving up. RB in non-DE mode is still going and over 50% through. Last edited by byteshare; 22nd August 2019 at 21:15. |
22nd August 2019, 21:46 | #17215 | Link | |
22nd August 2019, 22:26 | #17216 | Link | |
Solved - RB closes cleanly, now
Thank you. Last edited by FuzzyNutz; 23rd August 2019 at 00:40. |
23rd August 2019, 01:28 | #17219 | Link | |
ByteShare
For sure speeds up some of the work. |
23rd August 2019, 01:32 | #17220 | Link | |
ByteShare
- Okay in DE mode & non-DE mode, I got the flickering in Core 2019.08.17. - StaxRip 2.0.3 doesn't seem to have the issue but playback (FPS) is wrong and it can't complete the whole file (~20% of the total frames) +/- Non-DE mode (since encoding servers won't start for me) I'm not seeing the flickering in Core 2019.08.20...so it might be fixed (need more testing to feel confident) + In Handbrake I don't have the issue. If Core 2019.08.20 is fixed that is great. Not sure if the index slowness issues was fixed as well since I can't get the encoding server to start. Update-Update....I don't know why but the servers are starting now...I'll try DE mode in Core 2019.08.20 -NOT seeing the lwi indexes being created for chunks! Last edited by byteshare; 23rd August 2019 at 01:43. |
