Old 12th February 2018, 04:29   #48941  |  Link
70MM
X Cinema Projectionist NZ
the ghosting is easily visible in the video. but not sure if this is the issue you are talking about.
can you make me a screen of the OSD?
You really cant see the artifact Im describing in the video. What you are seeing is not the problem described. The video is not displaying this ghost/double image on the fade in after the text "The Mountain Between Us"
I really think its an issue with the JVC X9900.
This video has the OSD stats. The top display section 23.97??? is missing from the OSD with my black velvet screen masking.
https://youtu.be/gI2jQ49NJSc
70MM is offline   Reply With Quote
Old 12th February 2018, 04:51   #48942  |  Link
Originally Posted by spotswood View Post
Thank you for your fast reply, 8GB it is. Will save me a few buck too. Love this forum... and madVR!
make sure your device of choice doesn't have thermal throttling issues(sadly not uncommon for small factor intel devices) and you are not going to do more than FHD.
Old 12th February 2018, 09:22   #48943  |  Link
runner
I would like to know how to use the control function for the videoprojector, in particular I would like at the end of the playback to return to position 1 of the lens. thank you
runner is offline   Reply With Quote
Old 12th February 2018, 11:26   #48944  |  Link
chros
chros's Avatar
Originally Posted by Clown shoes View Post
My 4k display is 8bit + frc and I can't work out whether I should be setting MadVR to 8bit or 10bit.
Mine is also 8bit+frc (see in the signature): use 10bit in madvr.
Old 12th February 2018, 16:16   #48945  |  Link
Siso
Soul Seeker
Siso's Avatar
In regards of refresh rates, which one is the better option - to overclock your monitor to be used 72hz all the time (no switching), or to use the default 60hz, and to create 48hz and madvr to switch it on when needed? I don't like smooth motion at all :/
Old 12th February 2018, 18:25   #48946  |  Link
hannes69
If you donīt like smoothmotion, use custom refresh rates according to your video material and according to the capabilities of your monitor.
For 23.976fps movies use refresh rate 23.976Hz OR 47.952Hz OR 71.928Hz OR ... Which one doesnīt matter, use the one your monitor accepts.
So a full set of refresh rates for all possible common movie frame rates would mean e.g. 47.952Hz (->23.976fps), 48.000Hz (->24.000fps, 48.000fps), 50.000Hz (->25.000fps, 50.000fps), 59.94Hz (->29.970fps, 59.940fps), 60.000Hz (->30.000fps, 60.000fps). Or other multiples if your monitor doesnīt accept these ones.
72Hz with no switching only works correctly for 24.000fps movies, so thatīs no option when wanting judder free playback and not using smoothmotion.
The default 60Hz are usually in reality 59.94Hz, so with your default "60 Hz" and 48 Hz you could only playback 29.970 fps, 59.940fps, 24.000fps and 48.000fps correctly.
It depends on your video material, but for all possible scenarios you would need the 5 custom refresh rates, see above.
I wouldnīt use the term "overclocking" in this context. Ok, a colcok of 72Hz is higher than the "default 60Hz", but there arenīt the same principles like overclocking e.g. a GPU or a CPU (which gives more temperature and more electrical stress on the components). A monitor accepts a given refresh rate by the computer or not. A higher refresh rate doesnīt do any harm or is dangerous. The worst thing that could happen is, that you have to do a safe boot because of getting a black screen when using a custom resolution your monitor doesnīt accept. But thatīs it. Use whatever your monitor can display correctly.
hannes69 is offline   Reply With Quote
Old 12th February 2018, 19:14   #48947  |  Link
Asmodian
Originally Posted by thighhighs View Post
2.4 default for double again mode (or NGU AA). For direct 4x "if any upscaling is needed" by default.
Ah! The complexity!
madVR options explained
Old 12th February 2018, 20:40   #48948  |  Link
ABDO
Originally Posted by hannes69 View Post
Which one doesnīt matter, use the one your monitor accepts..
thanks for this great explanation.
ABDO is offline   Reply With Quote
Old 12th February 2018, 20:52   #48949  |  Link
Siso
Soul Seeker
Siso's Avatar
72hz and reclock works very well, I have no repeated or dropped frames for around 12 hours. Reclock likes 24 multiple refresh rates.
Old 12th February 2018, 22:55   #48950  |  Link
Asmodian
Reclock simply likes it "close enough" so you won't notice. It would change the audio speed less if you used a multiple of 23.976 Hz instead of 72 (at least for 24/1.001 fps content). Not that it is important, but Reclock is for when you cannot match your refresh rates, it is like smooth motion for the audio.
edit: actually that analogy isn't very good, Reclock cannot deal with 24 fps into 60 Hz but it is good for 29.97 fps at 60 Hz, where smooth motion is also good for preventing dropped frames.
Old 12th February 2018, 23:09   #48951  |  Link
Siso
Soul Seeker
Siso's Avatar
So a refresh rate of 71.928hz will do better than 72hz? I mostly watch 23.976 content.
Old 12th February 2018, 23:20   #48952  |  Link
jkauff
If you create your custom refresh rates in madVR, following madshi's tutorial for optimizing those refresh rates, you'll likely end up with a resolution that produces less than 1 repeated frame every 3-4 hours (or better). At that point, you'll have no need for Reclock.
One of the advantages of this is that by removing 32-bit Reclock, you can then use all 64-bit components in your playback chain.
Old 12th February 2018, 23:44   #48953  |  Link
Siso
Soul Seeker
Siso's Avatar
That's good, but sometimes I watch tv shows at 25 fps, slowing them down to 24 fps with reclock.
Old 13th February 2018, 06:54   #48954  |  Link
XMonarchY
Any chance there will ever be extra slots for different 3DLUT's? I have encountered several displays that require different 3DLUT's/calibration for different refresh rate modes. The 48/72/96Hz refresh rate modes on TV's without full calibration controls require re-calibration for that mode. I have a TV like that and I change change 3DLUT's in settings depending on whether I watch 23/24p content (48Hz mode) or 29/30/60p (60Hz mode) content, but it would be nice if madVR had the option to set specific 3DLUT's for specific display modes. I think 3DLUT option for 23/24p mode and 29/30/60p mode would be perfect!
Old 13th February 2018, 07:29   #48955  |  Link
you can use a profile for that.
Old 13th February 2018, 15:22   #48956  |  Link
foozoor
foozoor's Avatar
Maybe in madAudio?
foozoor is offline   Reply With Quote
Old 13th February 2018, 15:41   #48957  |  Link
clsid
Set speed step value in MPC-HC options to 4%. Then click reduce speed button to change 25.000fps into 24.000fps. The internal audio renderer does automatic resampling and pitch control.
Old 13th February 2018, 17:07   #48958  |  Link
ashlar42
You're obviously entitled to do whatever you want but... are you sure those tv shows don't have a native framerate of 25? Because most European productions do (almost everything by BBC, for example).
Old 13th February 2018, 17:29   #48959  |  Link
chros
chros's Avatar
I didn't know this either, thanks, I'll try it out.
Old 13th February 2018, 22:50   #48960  |  Link
spotswood
The i7 models include a fan and 3 power modes one of which is "Best Performance" that runs the processor/igpu at full speed so no throttling. Don't know how loud it is though.
No more than FHD? Not 4k? The specs here https://support.microsoft.com/en-us/...?os=windows-10 show the Surface Pro can output 4k@60Hz 4096x2304. Are you saying the new Surface Pro 2017 with the configuration I'm thinking about w/i7, Iris Plus 640, 8GB isn't powerful enough to run madVR at 4k?
spotswood is offline   Reply With Quote
