7th April 2020, 16:45 | #701 | Link |
I'm wondering if someone here can help me, not quite a tsmuxer issue, but figure people here might know.
I'm doing a project where I'm using libbluray to take a bluray playlist and turn it into a single m2ts (well a bit more complicated, meant for streaming, but that's close enough for a first approximation). What I realize is that in doing this, it loses the language metadata (i.e. the langauge for audio and subtitle tracks) as this data seems to only be in the clip info files so isn't in the "m2ts" stream I'm reading from libbluray. Is there anyway to edit this into a pure m2ts stream? (either editing the stream on the fly or appending a packet of sorts to the start), or is this simply impossible in the m2ts format? |
7th April 2020, 17:44 | #703 | Link |
Well, I can reproduce the bug in MPC-BE with the 2 last versions. Not only with DV but with any files.
I only tried the latest version on my x700 though. sample: https://drive.google.com/file/d/1oTQ...ew?usp=sharing |
7th April 2020, 19:06 | #704 | Link | |
Life's clearer in 4K UHD
On my [2016] LG television, the Dolby Vision encoded video and EAC3 audio work perfectly. Sadly my TV does not support PGS subtitles. On my OPPO, the Dolby Vision encoded video and EAC3 audio work perfectly too. But as others have reported the PGS subtitles are black. And they are huge
7th April 2020, 20:00 | #705 | Link | |
if yes then...ehm lol...my 2019 lg c9 usb media player loads a sec then says file not supported.... kind regards Last edited by B1gD4ddy; 7th April 2020 at 21:08. |
7th April 2020, 20:34 | #706 | Link |
I transferred imhh11's Mandalorian sample onto a USB flash-drive, and used the TV's built-in 'Photo & Video' media player app to play it....
7th April 2020, 20:53 | #707 | Link | |
I have pushed the commit to reinstate the HDMV descriptor for DV tracks. I still believe that the HDMV descriptors should be present only for m2ts and not for ts. Anyway... I'll work on an option for manual selection of the HDMV descriptors when I have time -after 2.7.0. As for the srt... no clear if it was already there with 30/03 version, let's see if the reinstatement of the hdmv descriptor fixes the issue. |
7th April 2020, 21:04 | #708 | Link | ||
and like already mentioned every dv (m2)ts created from uhd by tsmuxer only triggers hdr on c9 instead of dv. no idea what magic seemoredigitals 2016 lg does... kind regards Last edited by B1gD4ddy; 7th April 2020 at 21:18. |
7th April 2020, 21:14 | #709 | Link | |
"I have spoken"...
7th April 2020, 21:16 | #710 | Link |
GogleDrive is pants!!! I suggest you try playing the sample file from a USB flash-drive instead...
7th April 2020, 21:18 | #711 | Link | |
kind regards Last edited by B1gD4ddy; 7th April 2020 at 21:21. |
7th April 2020, 21:22 | #712 | Link | |
7th April 2020, 21:24 | #713 | Link | |
EDIT: might be my source file after all because I tried with other samples and I can't reproduce it now Last edited by imhh11; 7th April 2020 at 22:56. |
7th April 2020, 21:31 | #714 | Link |
With regard to PGS subtitles... I wonder if genuine PGS subtitles (extracted from a 4K UHD disc) will work better with your Mandalorian sample?!
7th April 2020, 21:32 | #715 | Link | |
c9 is able to show preview thumbnail pics but when i click on the file the c9 loads a sec and then gives me a german error message which translated to english says something like "this file is not recognized. back to list." firmware is newest from some days ago, 4.71.25. kind regards Last edited by B1gD4ddy; 7th April 2020 at 21:34. |
7th April 2020, 21:35 | #716 | Link | ||
EDIT. pgs works just fine when i remux uhd-bd to dual layer TS. But there is no Mandalorian UHD-BD yet, my sample is a downloaded/untouched stream from Disney+. That's why i have to deal with SRT for that profile 05.06 sample. Code:
Complete name : D:\srt bug.ts Format : MPEG-TS File size : 119 MiB Duration : 1 min 1 s Overall bit rate mode : Variable Overall bit rate : 16.2 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : 36 Duration : 1 min 1 s Bit rate : 14.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.074 Stream size : 107 MiB (90%) Color range : Full Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : 135 Duration : 1 min 1 s Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 5.61 MiB (5%) Language : English Service kind : Complete Main Complexity index : 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Text ID : 4768 (0x12A0) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 1 s 793 ms Last edited by imhh11; 7th April 2020 at 22:36. |
7th April 2020, 22:49 | #717 | Link | |
7th April 2020, 23:21 | #719 | Link |
Ok, the SRT bug seems to be related to my PC(Win10 64x) at work because using the same file and the same tsMuxer here with my PC at home(Win10 64x), no more problem....
how is that possible? sample with working subtitles (converted from SRT): https://drive.google.com/file/d/1VCx...ew?usp=sharing subs, atmos and DV works on x700 C8= atmos + DV but no subs Shield= Atmos + DV but no subs (plex fault here i think) sorry for the confusion. Last edited by imhh11; 8th April 2020 at 00:14. |
8th April 2020, 08:27 | #720 | Link | |
