16th February 2014, 17:33 | #19241 | Link |
speaking of relax, you have earned it Perhaps go for dinner with your family as well.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 16th February 2014 at 17:39. |
16th February 2014, 20:13 | #19242 | Link | |
I then went through your BDRB install steps from page 1 and then tried Season 1 of the Wire again, and The Simpsons Season 2 both 4 DVDs --> 1 BD. Both BDs have sound/video sync issues, however, it is very pronounced on The Simpsons. jdobbs, The Wire is actually pretty close in terms of syncing. If you could just do me one more favor and check the first episode of season 1 (The target) - go to around the 50 minute mark (it's chapter 6 on my disc) where Bunk and McNulty are in a bar talking about his separation...the sound is about 1-2 seconds behind the video; is yours spot on? FWIW, here are the batch log, settings ini, inspect log, and sample avs files from The Simpsons season 6 (my Wire files were deleted by the cleanup process). |
16th February 2014, 20:15 | #19243 | Link | |
16th February 2014, 21:02 | #19244 | Link | |
It would be a very strange coincidence if it was a bad rip, b/c every episode has a lag - this was across 4 DVDs. Same thing with The Wire Season 2, and The Simpsons Seasons 2, 3, and 6. 4 DVDs each/season. Further, the source videos are MPEG-2, 720x480, _Hybrid_ files. I also did The Simpsons seasons 4 and 5 without issue, however, the total source size was < 23500, so there was no video reencoding. So, that's 20 source DVDs, all with MPEG-2, 720x480, Hybrid files, all of which would need to have been bad rips to support that. But, right before I wiped my machine I reencoded season 4 of The Wire without issue, but these were _not_ hybrid source files. I also did 5 BD to BDs without issue, so I know my burner is OK... |
16th February 2014, 21:20 | #19246 | Link | |
So you set it to force encode, even when it already was encoding, to deal with hybrid mpeg2 file video/audio sync issues? |
16th February 2014, 21:23 | #19247 | Link | |
16th February 2014, 21:23 | #19248 | Link |
I'm simply saying, that when rebuilder did not encode, there was a problem. By forcing, it corrected my issue. Thankfully, I rarely work with 480p/i sources :S
16th February 2014, 21:27 | #19249 | Link | |
Thanks for doing me this favor! This is the opposite of what I am experiencing. |
16th February 2014, 21:33 | #19250 | Link | |
@slvrsrfr I don't remember if I asked this before... what player are you using? |
16th February 2014, 23:04 | #19254 | Link |
In my previous run I noticed the audio had been reencoded and yours hadn't. So I changed the settings to match yours. Unfortunately, though, it completed again in perfect sync.
I don't know what else to do. All my instincts tell me something is wrong with your CODEC setup. But you've assured me everything is installed correctly and all of the recommended versions are in use. So I'm at a loss. |
16th February 2014, 23:32 | #19255 | Link |
I have had this happen a few times over the years. Every time it has been a bad original source. As others have said, players are forgiving and encoders are not. Put the original disc in your set top player and move to about a minute before where you say it goes out of sync. Play from that point and watch for any kind of glitch. If there is something, the player will probably ignore it and keep playing in sync but it will screw up the encode. If you don't see a problem there, try the same thing with the rip.
16th February 2014, 23:55 | #19256 | Link | |
I do have a copy of Windows 8, but haven't put it in the box that I run BDRB on yet, as I'm not ready to go there on it. What OS do you run? |
17th February 2014, 00:06 | #19257 | Link | |
17th February 2014, 00:25 | #19258 | Link |
BD Rebuilder v0.46.13 (beta)
I have updated the first post of this thread with a link to the latest version of BD-RB (v0.46.13). Changes for this release:
- Made a change to the processing of intact video sources. This will eliminate blocking artifacts that might be (rarely) introduced in recent versions of TSMUXER. - Further improved the algorithm for encoding with LAVF frame serving. Due to updates in newer versions of X264s LAVF, more source formats are directly supported -- making the need for reversion to DirectshowSource() less likely. - Corrected an error that could prevent BD-RB from keeping 3D sources intact when they would fit as-is in the target size. - Corrected an issue that might prevent AVCHD output from playing on certain players. - Fixed a problem in which errant ".mpls" and ".clpi" files could be created in an AVCHD movie-only authored structure. - Fixed an issue that could cause incorrect aspect ratio playback on certain rare MPEG-2 sources. - Disabled and removed PULLDOWN_720 from the hidden options. In testing I've found too many inconsistencies when it is set. - Added working folder free space as a part of the reported settings in error output and "Inspect". - Corrected an issue in which audio, subtitle, and blanking options were not being properly retained during a full backup via BATCH mode. - Other minor corrections and cosmetic fixes. |
17th February 2014, 00:26 | #19259 | Link | |
I'm probably a big PITA, but I do really appreciate all of your suggestions and effort to help me resolve this!!! |
17th February 2014, 00:30 | #19260 | Link | |
