3rd April 2010, 00:31 | #5181 | Link |
Programmer (or just 教务长)
My concern is tsMuxeR's chapter setting in the mpls files for each title.
Basically a chapter jump (through a playlist mpls) is a "jump to the packet with PTS = xxxx". How could one be sure that this packet has the h264 start of a key/IDR frame? I'm either missing something or I'm not understanding the whole concept. Since decoding of the jump frame usually requires decoding of the previous IDR frame, I prefer to have x264 generate it just a bit earlier, so once the player decides to 'seek' for it, it will need to go just 1-2 frames back and reconstruct the requested one. Please let me know if I'm getting this all wrong. I have my observations of how PS3 (although a powerful machine) struggles to seek back (either with reversed playback or seek-back - spinning its fans to 150% since the CPU needs much much more power to reconstruct the rev-playback). And laserfan, my post is about a newly reencoded file (not a blu-ray one) and tsMuxeR's ability to link the chapter marks to the closest possible IDR frame in the encoded AVC video. Last edited by deank; 3rd April 2010 at 00:59. |
3rd April 2010, 03:03 | #5182 | Link |
deank, sorry to report that my Planet Earth, though it seemed to work perfectly playing on software players, would not work, and would freeze up my Sony S360 player after episode 6.
The first five episodes worked perfectly, including the motion menu and the motion title thumbnails. However, after the sixth episode, the motion menu would freeze up. The player seemed to be less responsive too after the 4-5th episode, taking longer to change to a different episode thru button navigation, as well as when selecting play, it took longer to start. I will try again with version 744+, since it appears you may have found the issue. I will try to let you know tomorrow with my results. |
3rd April 2010, 03:20 | #5183 | Link |
Fighting spam with a fish
Huh, okay, well, I seem to have run into a problem while encoding the motion thumbnail.
X264 crashed: http://www.screencast.com/users/Adub...a-2f623fa22aa1 If I click okay, Windows 7 tells me that I can close the program and report the error, or just close the program. I close the program, and multiAVCHD continues on it's own: Code:
[18:56:02] Initialising... [18:56:02] Checking for new version... [18:56:03] You have the latest build. [18:56:03] [02/04/2010] build 744 (latest is: 744) - Fixed SETUP page navigation for compilations with more than 10 titles. Updated BDSup2Sub to 4.0, x264 to r1510. New options. [18:56:03] Consistency check finished! [18:56:03] Initialization finished. multiAVCHD is ready! [18:56:03] 1 year and 97 days since multiAVCHD was published. [18:56:03] 267 people supported it with donations [18:56:03] and you are the 1395591 one to launch the program... [18:56:03] Support multiAVCHD to extend its features and keep it going! [18:56:03] multiAVCHD.dat version: [04000733] [18:57:18] Checking for available space and drive types (FAT32/NTFS)... [18:57:18] Destination [C:]: NTFS, 96512.09 MiB (94.25 GiB) free space [18:57:18] Temp folder [c:]: NTFS, 96512.09 MiB (94.25 GiB) free space [18:57:18] Log started for multiAVCHD v4.0 (build 744) [18:57:18] Selected output mode: Blu-ray player (BD-R/BD-RE disc) [18:57:18] Processing one title... [18:57:19] Processing (D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts)... [18:57:21] Detected frame reference count: 4 (max:4). [18:57:21] Detected video: ID#4113:V_MPEG4/ISO/AVC 1920x1080, fps=23.976, ref=4 [18:57:21] DTS-HRA, DTS-MA will not be reencoded. [18:57:21] Adding DTS audio track (ID#4352) [18:57:21] Adding DTS audio track (ID#4353) [18:57:21] Adding DTS audio track (ID#4354) [18:57:21] Detected subtitles: ID#4608:S_HDMV/PGS Language: und [18:57:21] Detected subtitles: ID#4609:S_HDMV/PGS Language: und [18:57:21] Detected subtitles: ID#4610:S_HDMV/PGS Language: und [18:57:21] Detected subtitles: ID#4611:S_HDMV/PGS Language: und [18:57:21] Detected subtitles: ID#4612:S_HDMV/PGS Language: und [18:57:21] Total of 4 tracks found in this file. [18:57:21] Creating clip and playlist info (tsMuxeR)... [18:57:21] Media split set at 4000MiB point... tsMuxeR (Version 1.10.6) output: =============================================================================== Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1920:1080p Frame rate: 23.976 H.264 stream does not contain fps field. Muxing fps=23.976 Decoding DTS-HD stream (track 2): Bitrate: 1536Kbps core + MLP data.Sample Rate: 48KHz Channels: 5.1 (DTS Master Audio) Decoding DTS stream (track 3): Bitrate: 768Kbps Sample Rate: 48KHz Channels: 5.1 Decoding DTS stream (track 4): Bitrate: 768Kbps Sample Rate: 48KHz Channels: 5.1 Decoding PGS stream (track 6): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 7): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 9): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 5): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 8): Resolution: 1920:1080 Frame rate: 23.976 H264 bitstream changed: insert SPS/PPS units Processed 220091 video frames Creation of Blu-ray playlist Creation of Blu-ray stream info and seek index Mux successful complete. Muxing time: 16 min 18 sec =============================================================================== =============================================================================== tsMuxeR meta: =============================================================================== MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000;00:12:44.916;00:25:29.833;00:38:14.750;00:50:59.666;01:03:44.583;01:16:29.500;01:29:14.416;01:41:59.333;01:54:44.250;02:07:29.166;02:20:14.083 --split-size=4000MiB --vbv-len=500 V_MPEG4/ISO/AVC, "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts", insertSEI, contSPS, track=4113, fps=23.976 A_DTS, "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts", track=4352, lang=und, timeshift=0ms A_DTS, "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts", track=4353, lang=und, timeshift=0ms A_DTS, "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts", track=4354, lang=und, timeshift=0ms S_HDMV/PGS, "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts", fps=23.976, track=4608, lang=und S_HDMV/PGS, "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts", fps=23.976, track=4609, lang=und S_HDMV/PGS, "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts", fps=23.976, track=4610, lang=und S_HDMV/PGS, "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts", fps=23.976, track=4611, lang=und S_HDMV/PGS, "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts", fps=23.976, track=4612, lang=und =============================================================================== [19:11:16] Media transfer: 00000 -> 00000.m2ts [19:11:16] Media transfer: 00001 -> 00001.m2ts [19:11:16] Media transfer: 00002 -> 00002.m2ts [19:11:17] Media transfer: 00003 -> 00003.m2ts [19:11:17] Media transfer: 00004 -> 00004.m2ts [19:11:17] Media transfer: 00005 -> 00005.m2ts [19:11:17] Media transfer: 00006 -> 00006.m2ts [19:11:17] Media transfer: 00007 -> 00007.m2ts [19:11:17] Media transfer: 00008 -> 00008.m2ts [19:11:17] Processing playlist... [19:11:17] Title #1 added: "00010" [19:11:17] Verifying title... [19:11:45] Title has: 3 audio tracks and 5 subtitle tracks [19:11:45] Preparing authoring information... [19:11:45] Creating NTSC top menu. [19:11:45] Setting pop-up menu... [19:11:47] *** [00000.mpls] - Adding pop-up menu [1080p]... [19:11:47] *** Completed! [19:11:47] Authoring menu (NTSC). [19:11:47] Creating title thumbnails for 1 titles (XMB)... [19:12:09] Using 12 thumbnail/chapter links for title #1... [19:12:09] *** Extracting 12 chapter thumbnails... [19:15:06] Image processing for XMB menu completed! [19:15:06] Preparing menu pages... [19:15:07] Encoding motion XMB menu page [1/1] [Motion title thumbnail]. [19:17:03] Encoding motion XMB menu page [1/1]: Chapter page [1/1]. [19:17:42] Encoding motion XMB menu page [1/1]: Setup page (audio/subtitle). [19:18:16] Menu authoring completed. [19:18:17] Encoding Title List menu page [1/1]. [19:18:26] Authoring welcome screen (NTSC). [19:18:29] Encoding welcome screen... [19:18:43] Authoring welcome screen completed. [19:18:43] Setting main menu for 1 titles... [19:18:43] Playback will end after title #1. [19:18:43] Setting menu properties... [19:18:43] Selected TV system: [NTSC] [19:18:43] Processing clip (CPI/CLPI) files... [19:18:43] Completed. [19:18:43] Setting Blu-ray format... [19:18:46] Done! [19:18:46] Saving multiAVCHD quick-load project (mpf): [19:18:46] C:\multiAVCHD\AVCHD_INGTEST12\multiAVCHD.mpf (OK!) Compilation summary: Format: Blu-ray player (BD-R/BD-RE disc) Name : INGTEST12 =============================================================================== 1. 00010 [02:32:59] =============================================================================== Overall duration : 02:32:59 Output size : 35689 MiB (34.853 GiB) [19:18:46] C:\multiAVCHD\AVCHD_INGTEST12 folder created (AVCHD/Blu-ray output)! [19:18:46] Burn its CONTENTS to BD-R/RE UDF 2.50/2.60 disc! [19:18:49] You may now remove temp folder (c:\multiAVCHD\_TEMP\multiTEMP-20100402\). [19:18:49] Your compilation contains 2hrs 32min 59sec of video material. [19:18:49] multiAVCHD finished in 1291.064 seconds (00:21:31.063)! [19:18:49] End of log. [19:18:49] Cleaning up... [19:18:50] Done! [19:18:50] For technical support, bug reports and questions: [19:18:50] http://multiforum.deanbg.com/ [19:18:50] http://multiAVCHD.deanbg.com/ [19:18:50] http://forum.doom9.org/showthread.php?t=143744 edit: I'm replacing the x264 version included by mAVCHD with the MeGUI one and trying again. Let's see if it crashes. edit2: Huh, even with a totally different executable it crashes. Last edited by Adub; 3rd April 2010 at 03:42. |
3rd April 2010, 10:38 | #5184 | Link | |
3rd April 2010, 12:33 | #5186 | Link |
Some menu playlists contain over 100 (or 500 until recently in multiAVCHD) playitems (m2ts files). multiAVCHD reports the first 10 and the last 10 - they are all the same, so no need to full the log with this information. This is done so the menu will play almost indefinitely (like 5-10 hours) if you leave your player unattended.
3rd April 2010, 14:35 | #5187 | Link |
Latest test of Planet Earth to BD-RE with 744+ works perfectly on my S360.
Thanks for a quick find and fix! Regarding chapters created/used from tsMuxeR, I found that on some episodes the chapter lands on a frame before it should, or at least I see a quick seen change after the chapter selection starts. It seems it should have been a few frames later, so that it is already at this next scene. Not a big deal though, and it happens on backups of almost every Blu-Ray I have done. Now I am looking forward to if/when the motion menu capabilities are greater than 32 seconds. |
3rd April 2010, 14:37 | #5188 | Link |
Well... that may be not that easy to implement, but I'll get to it next week. Good to know your PE disc works now
About the chapters - it has nothing to do with multiAVCHD. The discussion above is when you use multiAVCHD to re-encode your source and is not related to the muxing part with tsMuxeR of videos you brought into multiAVCHD Last edited by deank; 3rd April 2010 at 14:43. |
3rd April 2010, 14:57 | #5189 | Link | |
I am perfectly content with the motion menu/motion title thumbnails as is! Maybe it's just presumptuous, but your quick changes/fixes and feature additions and enhancements have spoiled me! I realise it is not multiAVCHD regarding chapters issues, but was just relaying an observation, not trying to imply a bug. |
3rd April 2010, 16:06 | #5190 | Link | |
Regards Puki And btw: fantastic additions during the last two weeks! |
3rd April 2010, 18:00 | #5191 | Link | |
Aging Video Hobbyist
I don't pretend to understand how any of this works (!), only that IME the chapter marks from the original will, many times, not match-up with an I-frame in the re-encode, which results in the "shows a frame or two from the previous scene when advancing to a chapter" as Capsbackup said too. |
3rd April 2010, 20:57 | #5192 | Link |
Hi Dean,
Well I just finished LOTR Trilogy (one 25gig BDR) , although I rarely change settings I thought I would give the new Mpeg2 Menu encoding a go. The Reason for this is I usually have issues when I get to this point. I basically get a stall and the program timer instead of counting down as its encoding menu the timer goes higher. I just use the handy dandy Break button and skip to the next taskat hand to which MultiAVCHD uses Title menu. OK so now when I get to Menu encoding time with Mpeg2 Ticked , My Counter didnt show any activity for about 10 minutes, So I used the Break button again and have a Nice Title Menu ( No Biggie ). I know youhave posted about Menu encoding in the past, Mind you Im the guy with the Actual Super PC Core I7 950 OC 4.2 with 12 Gigs of RAM , I dont usually report anything because with 12 updates a week you usually fix whatever is wrong too fast. , I will try the tried and true reload AVISYNTHHAALIFFDSHOW fix. I hit the break button so I donth think the Log Would really help. I'll keep you posted FB |
3rd April 2010, 23:12 | #5193 | Link |
I never use the BREAK and ABORT buttons... I don't really know what they actually do (seriously... don't use them).
The MPEG-2 menu encoding option requires 2-pass processing. Just to be on the safe side - make sure you enable [x] Show spawned tools option in SETTINGS tab. Then you'll see all tools and what they are doing. |
4th April 2010, 12:08 | #5196 | Link | |
I got this e-mail this morning from a multiAVCHD user:
file_name|trim_start|trim_end|poster_frame_in_seconds Example: Code:
00001.m2ts|12.041|96.811|4.555 F:\AVCHD\BDMV\STREAM\00002.m2ts|12.041 D:\00003.m2ts|||1813 C:\00004.m2ts .mpf - project file .mlf - language file .mmt - menu template .mfl - file list Dean |
4th April 2010, 13:33 | #5197 | Link |
Hi Dean, been having a few issues since the last few updates.
In the old version whenever I hit start it would come up with the options menu for what type I would like, I always used the AVCH to dvd for panasonic players and this worked flawlessly! Since the update this option is gone and is replaced with AVCHD (strict) and AVCHD (loose) I havent been able to get an AVCHD burned to dvd that works since. The dvd loads and then says play on the br player(panny bd30) and then imediately syas stop? What am I doing wrong Thanks P.S. also I never did get the fit to all to work, it ALWAYS seems to create a disk that is 101% of the dvd size therefore rendering the convertion useless. I must admit this mainly happens when I am trying to encode video streams that are over 4500MB in the first place, any suggestions? |
4th April 2010, 13:55 | #5198 | Link |
AVCHD (strict) should work... If you can't make it work, you'll have to use version 3.0. FIT-ALL does not take into account menu files and in version 4 motion menus may take up to 30MB per title.
4th April 2010, 14:02 | #5199 | Link |
Ok dean thanks for the quick reply. do you think if I disable all menus this will make the fit to all work for files larger than 4500MB?
Also I have tried about 3 different projects with strict, none fo them work? I am currently writing a project with loose to see if this solves the problem. Will update if succesful on both counts. CHP |
4th April 2010, 14:20 | #5200 | Link |
Just noticed something and being a noob Im probably way of track BUT worth asking, I have noticed that I have img burn set to autostart and in settings the default is use img burn with drd/bd-r output as apposed to what I BELIEVE I used to use was the ISO settings when launching imgburn manually and adding the folders, it would autamatically adjust to this, could this be the case that imgburn is buring the disc in the wronf format?
