18th December 2009, 05:32 | #6361 | Link | |
PROCESS_SECONDARY=0 |
18th December 2009, 05:37 | #6362 | Link |
ok, I set it and it X'ed out both secondary files. Let me run this and I'll get back with you. Thanks for the fast/helpful responses.
18th December 2009, 18:17 | #6365 | Link | ||
I ran BD_RB each time after playing with various ffdshow settings and discovered that switching VC-1 to libavcodec allowed BD_RB to process the problem videos. I do not know why this works, though I'm sure you do Mr. Dobbs, but I ran a second file just to ensure that the first successful run was not a fluke. It was not and all is well. Thanks again, and I hope this helps out other users. |
18th December 2009, 18:27 | #6366 | Link | |
18th December 2009, 18:37 | #6367 | Link |
I have absolutely no doubt that you are correct. I can only respond that the first two of five problem sources have both played perfectly, with video quality on par with when VC-1 was set to disabled for the "non-problem" movies.
18th December 2009, 20:10 | #6369 | Link |
There should be no discs that can't be backed up -- if the system is configured properly. The only exception would be DTS-Express secondary audio -- and even with that, the disc will still backup without the secondary audio.
19th December 2009, 01:05 | #6374 | Link | |
Still no go. I got the same PGS error. Here's my .ini [Options] MODE=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=1 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 VERBOSE_STATUS=1 TARGET_SIZE=7910 AUTO_BURN=0 PROCESS_SECONDARY=0 [Paths] WORKING_PATH=C:\WORKING\ SOURCE_PATH=C:\USERS\JOSH\DESKTOP\MADAGASCAR 2\ No idea why these 5 movies won't process. But ok, 5/135 isn't that bad at all...
19th December 2009, 02:06 | #6375 | Link | |
@jr08toy
Hi! Quote:
Try changing your setting so that only one PGS file is selected for inclusion regarding the primary movie - and NO PGS files are selected for any other titles... |
19th December 2009, 02:34 | #6376 | Link | |
19th December 2009, 07:38 | #6377 | Link |
Okay, I re-ran Bleak House disk 1, not sure what you need, so here is the log;
----------------------- [16:45:50] BD Rebuilder v0.31.05 (beta) - Source: BLEAK_HOUSE_D1US - Input BD size: 26.21 GB - Approximate total content: [02:50:36.226] - Target BD size: 22.46 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [16:45:50] PHASE ONE, Encoding - [16:45:50] Extracting A/V streams [VID_00004] - [16:58:12] Reencoding: VID_00004 (1 of 5) - [22:24:17] Extracting A/V streams [VID_00005] - Error in attempt to MKVMERGE. [22:25:52] - Failed to retrieve audio, aborted and here is the INF; [Status] LABEL=BLEAK_HOUSE_D1US VERSION=v0.31.05 (beta) SOURCE_SIZE=28137768960 SOURCE_VIDEO_SIZE=28137768960 TARGET_SIZE=24117248000 REDUCTION=.857113015402341 RESIZE_1080=0 AUDIO_TO_KEEP=eng SUBS_TO_KEEP=all BACKUP_MODE=1 QUICK=0 ENCODE_STEP=0 COMPLETED=1 [00004] AUDIO=100 PGS=1 M2TS_TARGET=7799376708 RATE=17367 NSIZE=7460868096 FLINK=0 MLINK=0 Thanks, Marty. |
19th December 2009, 12:25 | #6378 | Link | |
[Status] LABEL=MADAGASCAR_2 VERSION=v0.31.05 (beta) SOURCE_SIZE=45435188714 SOURCE_VIDEO_SIZE=45394673664 TARGET_SIZE=8294236160 REDUCTION=.181821355762836 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; BACKUP_MODE=0 QUICK=1 ENCODE_STEP=1 COMPLETED=110 - Video: 1920x1080, 23.976fps, 17,470 frames - [22:28:37] Reencoding: VID_00010, Pass 1 of 1 - [22:36:12] Video Encode complete - [22:36:12] Reencoding audio tracks (if req'd) - [22:36:17] Multiplexing M2TS - [22:36:43] Extracting A/V streams [VID_00011] - [22:37:55] Reencoding: VID_00011 (110 of 111) - [22:37:55] Collecting video information - Video: 1920x1080, 23.976fps, 17,501 frames - [22:37:55] Reencoding: VID_00011, Pass 1 of 1 - [22:45:25] Video Encode complete - [22:45:25] Reencoding audio tracks (if req'd) - [22:45:30] Multiplexing M2TS - [22:45:52] Extracting A/V streams [VID_00003] - [23:00:59] Reencoding: VID_00003 (111 of 111) - [23:01:00] Collecting video information [06:20:13] - Failed video encode, aborted
19th December 2009, 16:39 | #6379 | Link | |
19th December 2009, 16:44 | #6380 | Link | |
