12th November 2013, 15:28 | #342 | Link |
Life's clearer in 4K UHD
Hi Neil,
I've just discovered some of your work on my 'Yes - Close to the Edge' Blu-ray disc, that arrived this morning... There you were in the sleeve notes. Nice one
3rd February 2014, 11:58 | #343 | Link |
Video compressionist
Dear experts
According to Blu-Ray spec. (9.5.1.5) buffering period and picture_timing SEI are not mandatory. If a stream does not contain these SEI messages how a decoder should choose initial_cpb_removal_delay (which is sgnaled in the buffering_period)? |
15th February 2014, 02:38 | #346 | Link |
Not the first PCR but the PCR that's associated with the packet containing the beginning of the first frame. The PCR can pretty much be construed as the arrival time of the data into the buffer. This is explained in more detail in the T-STD part of the MPEG-TS specification.
23rd February 2014, 16:10 | #348 | Link |
There are a few I believe such as:
http://www.dvdverification.com/public/101.cfm However, I don't know how low-level they are. I think there is now parity between the BDAV-STD model and the MPEG-TS T-STD model but you'd have to check the related documents. However, most MPEG-TS analysers are designed for CBR whereas Blu-Ray is VBR with a PCR attached to every TS Packet. |
10th March 2014, 10:28 | #349 | Link |
Dear BluRay practitioners
i have several questions on BDAV-STD. 1) What the error MUX_SN_E_TS_UNDERFLOW_ERR means? ERROR: TSWrapper.dll::CTSWrapper::ProcThreadMain::Video buffer underflows. - @8 seconds :: [MUX_SN_E_TS_UNDERFLOW_ERR] My conjecture is underflow of MB1 buffer. Am i right? 2) How data enters to MB1 buffer? In T-STD model the data enters to multiplexor buffer according to transport_rate which is derived from successive PCRs. In BDAV-STD each TS packet is extended by the time-stamp. i conjecture that the TS packet in BDAV-STD enters to TB1 according to these timestamps. |
10th March 2014, 22:56 | #350 | Link |
Sounds like you're using either Scenarist or DVD Architect? Which software are you authoring with?
1: do you have a lot of audio tracks? I'll get this error usually when having a large DTS-HD Master Audio track. The solution is to limit the maxrate from 40000 down to something like 38000 which is usually enough. 2: I'll let someone else answer that. |
11th March 2014, 01:29 | #351 | Link | |
11th March 2015, 15:00 | #352 | Link |
Antronio's DV ambassador
What about AVCHD 2.0?
I want to encode my 1080p60 footage that is going to be authored to a AVCHD 2.0 blu-ray disc, as is the only standard that supports this resolution and frame rate. Given that purpose, I did some search and came with these x264 settings:
x264 --bitrate XXXXX --preset veryslow --tune film --bluray-compat --vbv-maxrate 25000 --vbv-bufsize 25000 --level 4.2 --keyint 120 --open-gop --slices 4 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 1 -o out.264 input.file x264 --bitrate XXXXX --preset veryslow --tune film --bluray-compat --vbv-maxrate 25000 --vbv-bufsize 25000 --level 4.2 --keyint 120 --open-gop --slices 4 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 2 -o out.264 input.file Does these x264 settings conform with AVCHD 2.0 standard on blu-ray media? Last edited by Alex-Kid; 11th March 2015 at 18:41. Reason: spelling errors ;) |
11th March 2015, 16:46 | #353 | Link |
I'm not sure all the parameters and constraints on AVCHD Progressive/2.0 are well-known, since it's not intended as a distribution format and more intended for use in camcorders, so keep that in mind. Hopefully someone who has tried this before can share their results.
You need to constrain bitrate to under 28000. If AVCHD 2.0 closely follows Blu-ray constraints, you will need to reduce keyint to 60 (1 second GOP), but this is a guess. Also, AVCHD format is intended for SD cards and DVD discs, and as seemingly trivial as it would be to support it on Blu-ray discs, not all players seem to do so; maybe try burning to BD-RE first and see if that will play back in the target device. If you want to target all Blu-ray players, consider converting to 1080i, as you'll retain the high-motion aspect (60 Hz) if properly done, and only lose some (maybe acceptably-small) visual fidelity from the interlacing/deinterlacing. |
12th March 2015, 07:19 | #354 | Link | |
I've been doing some more searching and I came up with this (from http://www.sony-asia.com/microsite/c.../04/01/01.html):
12th March 2015, 09:35 | #355 | Link |
DVD-R can be understundable because of physical drive limitation (and maybe DVD spec), but BD-R... It's strange... It seems more like a restriction to not allowing to play too much good quality BD-R (preventing for exemple playing even legal copy) than a real physical limit.
13th June 2015, 02:41 | #356 | Link |
x264 Parameters for single frame .264 file
I'm about to setup an x264 encode for a still image menu background on a Blu-ray disc.
What parameters would be used to create a single frame Blu-ray compliant .264 file? Input would be 1920x1080 jpeg or png. I was not able to find information on this in any of the guides. |
15th June 2015, 08:20 | #358 | Link | |
An important thing to consider with Blu-ray is that even for menus, they are nothing like how we understand them from DVD as in BD everything is a movie, even menus. How we attack this is to set up a 30 second "film" with the still (please do not use JPEG - use either TIF or BMP and keep those graphics lossless - avoid data reducing forms like JPEG) with your source at 23.976fps at 72DPI if using 10920x1080. Encode as a regular movie at around 5Mbps CBR using highest quality options, although if you do want to use slideshow tuning this will not hurt but in all honesty I do not think it makes much difference - treat as a movie.
www.opusproductions.com Multichannel Audio Productions DVD-Audio/Video Authoring specialists |
15th June 2015, 18:41 | #359 | Link | |
Angel of Night
15th June 2015, 20:15 | #360 | Link |
I analyzed the m2ts that Adobe Encore creates for a Blu-ray still image background and it is only 1 frame in duration, not 30 seconds. I completely understand that Blu-ray backgrounds need to be videos per the Blu-ray spec, even when they are just still images. This is why I wish to convert my still image (png) background to a single frame video (.264) using x264 or ffmpeg + libx264. I was wondering if there are any special settings I should be using to create a 1 frame .264 file that is Blu-ray compliant or will the normal settings of x264 be compliant for a single frame?
