Old 3rd December 2017, 23:44   #22321  |  Link
Any image processing in LAV Video happens on the CPU. As such any advanced techniques are too expensive performance wise. The random or ordered dithering methods are as good as they can be, given the constraints.
If you convert a high-bitdepth image to ordinary 8-bit before the renderer, there will always be a loss, this cannot be avoided.
Old 3rd December 2017, 23:49   #22322  |  Link
Soulnight
Ok. Well.
Now I have to hope that AMD will support AMD FLUID Motion with 10bits in the near future...
Is a i7 7700K that limited for a better dithering in Lavvideo?
I mean right now, it's doing nothing and is letting madvr do all the heavy lifting with the GPU.
Soulnight is offline   Reply With Quote
Old 5th December 2017, 18:24   #22323  |  Link
ashlar42
nevcariel, do you think there'll be a new supported release by the end of the year? Is there lots of worthy stuff in the nightlies?
Old 5th December 2017, 18:33   #22324  |  Link
sneaker_ger
https://github.com/Nevcairiel/LAVFil...60572060e534ca
Do you need them? We don't know.
Old 5th December 2017, 21:57   #22325  |  Link
Hopefully I get some more time over the holidays to finish some things and make a release then.
Old 5th December 2017, 23:42   #22326  |  Link
Bad news from Microsoft: W10 Fall Creators Update removes HEVC codec (which is required to play e.g. Netflix 4K HDR); you could purchase it in the store if you need it ...
I don't know about Netflix. I don't know which combo of hardware and software it requires. Is it bound to MS Media Foundation decoders? Or would LAV Filters be a supported free alternative?
Old 5th December 2017, 23:45   #22327  |  Link
Except its free and not for purchase.
https://www.microsoft.com/en-us/stor...n/9n4wgh0z6vhq
But nothing can replace that, since only it will support the required DRM for Netflix etc.
On that note, as of today there is also a second one for Vorbis/Theora, called "Web Media Extension"
https://www.microsoft.com/en-us/stor...s/9n5tdp8vcmhs
Old 7th December 2017, 09:43   #22328  |  Link
sat4all
hi nevcairiel,
when playing hdr movies my external .srt and .ass subtitles look blindingly bright while embedded bluray subs looks fine. tried to lower sub renderer primary colors but it have no effect with hdr files.
is it madvr fault or xysubf? anything to do with lav filters? sorry i dont know where to ask!
any idea?
ZOTAC MAGNUS EN1060K: Win 10 x64 + Kodi DSPlayer x64
LG OLED65C8 / Denon AVR-X3200W / KEF E305+ONKYO SKH-410 / Synology DS2415+ / Logitech Harmony 950
sat4all is offline   Reply With Quote
Old 7th December 2017, 09:45   #22329  |  Link
Definitely not LAV Filters.
Old 7th December 2017, 09:52   #22330  |  Link
sat4all
good to know, thanks.
Old 8th December 2017, 01:02   #22331  |  Link
bcec
YADIF deinterlacing is not working when DXVA is enabled as hardware decoder (native or copy-back doesn't matter). Is this expected?
- Using the latest nightly (0.70.2.80)
- 1080ti with 385.69
- tried nVidia settings deinterlacing inverse telecine checked on and off, no change.
EDIT: copy-back works!
bcec is offline   Reply With Quote
Old 8th December 2017, 01:10   #22332  |  Link
Yadif is a pure software deinterlacer. You cannot make DXVA deinterlace with Yadif in the GPU.
Oh, wait, you expected Yadif to deinterlace after pure hardware decoding ... sorry, it is late already.
Old 8th December 2017, 01:15   #22333  |  Link
bcec
yup, I am assuming after doing hardware decoding, software YADIF should be able to kick in. But it doesn't.
At least the way it is presented in the UI, I was expecting it to work because I can select software deinterlacing after enabling hardware decoding.
Is it not supposed to work?
Old 8th December 2017, 01:32   #22334  |  Link
With Copy-Back YADIF should be working fine. With Native it cannot work.
The reason options dont grey out is simple: Not every clip can be hardware decoded, and for those all software options always apply.
Old 8th December 2017, 01:45   #22335  |  Link
bcec
you are absolutely right (why wouldn't you )
copy back works fine. Thank you for the quick follow-up.
Old 8th December 2017, 13:01   #22336  |  Link
ashlar42
Thanks. I didn't want to put pressure on you in any way. Take all the time needed.
Old 8th December 2017, 13:39   #22337  |  Link
mclingo
Hi, can anyone tell me if FSE (full screen exclusive) is required for Full frame packed MVC playback using AMD cards, I cant get it to work without using MADVR with FSE turned on.
Old 8th December 2017, 14:26   #22338  |  Link
This is not related to LAV Filters, it only performs decoding.
Old 8th December 2017, 16:14   #22339  |  Link
Klaus1189
Originally Posted by Klaus1189 View Post
I use LAV Filters for watching MXF-Files, but in MXF files the audiochannels are stored as single mono streams. My NLE detects the files correctly as stereo.
How do I configure LAV Filters to use left and right mono streams as one stereo stream?
Do not forget about me ...
Old 8th December 2017, 16:23   #22340  |  Link
There are no plans to handle those.
