7th August 2015, 17:18 | #261 | Link |
Soul Architect
OK. Testing with AVSMeter.
With device_type="GPU" I get 32fps with a simple script @ 50% CPU usage, and without it, I get 11fps @ 100% CPU usage. Yet, MSI Afterburner still doesn't show any GPU usage. Perhaps it doesn't detect and report it properly, is there a better software to use to measure GPU usage? |
7th August 2015, 17:45 | #263 | Link |
Soul Architect
GPU-Z reports a 2% load on the Intel HD 4000... AVSMeter is rendering at 36fps
Increasing MT mode from 8 threads to 16 threads increases CPU usage and lowers performance to 22fps, with same 2% GPU usage. Disabling MT results in 32fps with only 7% CPU usage, still 2% GPU usage. It seems MT mode doesn't work well with KNLMeans, and that it's not making efficient use of the GPU. Since MT provides no performance improvement whatsoever with KNLMeans, is there a way to disable MT only for that command? I'm using both AviSynth 2.6 and AviSynth+ so I'd need both syntaxes.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 7th August 2015 at 17:50. |
7th August 2015, 18:37 | #264 | Link | |
2) Are you sure you are using the AMD discrete and not the integrated GPU? EDIT. If you want a technical explain, OpenCL provides parallel computing using task-based and data-based parallelism. MT only creates unnecessary queues. Last edited by Khanattila; 7th August 2015 at 18:54. |
7th August 2015, 19:04 | #267 | Link | |
EDIT. Or edit HKEY_LOCAL_MACHINE \ SOFTWARE \ Khronos \ OpenCL \ Vendors. More or less. Last edited by Khanattila; 7th August 2015 at 19:13. |
7th August 2015, 21:25 | #268 | Link | |
Yet, you somehow seem dissatisfied. |
7th August 2015, 22:14 | #269 | Link |
Soul Architect
I tried running it on the Radeon, and can't get it to run on the Radeon. On a dual-graphics system, I set the application as "High Performance" for the Radeon or "Power Saving" for the Intel HD.
This time I'm getting 7-10% usage on the Intel HD 4000. If I set AVSMeter.exe to run on High Performance, or on Power Saving, it's still running on the Intel HD 4000 either way with exactly the same performance. I tried changing it for cmd.exe, and that still doesn't switch it to the Radeon. With that low usage, it's not really an issue. What makes more of a difference is the very high CPU usage when running in MT mode. I don't have any issues with MT so far; only this performance issue here. The output looks good, but is this plugin compatible with MT, or is there side-effects in terms of quality? Here's the script, when running in MT mode. It gives 30-32fps no matter if it's High Performance or Power Saving, and with or without MT. The only difference is that without MT CPU usage is 7%, with MT it goes up to 50%. The rest of the script is very CPU intensive and requires MT. Cores=8 SetMTMode(3,Cores) AviSource("Preview.avi", audio=false, pixel_type="YV12") SetMTMode(2) ColorMatrix(mode="Rec.601->Rec.709") Crop(0, 0, -10, -0) KNLMeansCL(D=2, A=1, h=3, device_type="GPU") Distributor() |
7th August 2015, 23:29 | #270 | Link | |
Why? Because it's written in OpenCL, as if it were already multithreaded. In addition, the GPU works in a different way, it is not that simple. Try uninstalling "OpenCL™ Driver for Intel® Iris™ and Intel® HD". So it is forced to use only the AMD.
github.com |
8th August 2015, 01:10 | #272 | Link | ||
--- Groucho2004: Imagine Donald Trump and Usain Bolt going for a run together. Who do you think will sweat less? LOL, good one Last edited by Reel.Deel; 8th August 2015 at 03:49. Reason: add off topic coment |
8th August 2015, 03:30 | #273 | Link | |
Soul Architect
Yet I can't throw away MT for what I'm doing. I'm developing this for a redistributable application; starting to play with drivers and registry is a bad idea. Not something I'd do on other machines. |
8th August 2015, 07:07 | #274 | Link |
Angel of Night
Just use SetMTMode(5) or 6 before KNLMeans. That's a necessary step for any filter that doesn't support external multithreading.
Or use VapourSynth, KNLMeans works correctly with its automatic multithreading. |
8th August 2015, 10:17 | #275 | Link | |
github.com |
25th August 2015, 22:18 | #276 | Link |
I got a problem when i open a script with KNLMeans.
The loading is taking long time and when i click on VirtualDub and MeGUI it just crashes with message "Not Responsing" I have tried with different version of KNLMeans and Geforce drivers. And i also tried a clean installation of Windows 10 x64 |
26th August 2015, 11:57 | #277 | Link |
v0.6.0 release: https://github.com/Khanattila/KNLMeansCL/releases.
github.com |
26th August 2015, 11:59 | #278 | Link | |
github.com |
26th August 2015, 12:47 | #279 | Link |
LoadPlugin("C:\Video\MeGUI\tools\dgindexnv\DGDecodeNV.dll") DGSource("C:\Video\Video.dgi",fieldop=0, deinterlace=1) crop(24, 0, -8, -6) Spline36Resize(768,576) Levels(5, 1, 255, 0, 255) SmoothContrast(contrast=0.2, sat=0.1) LSFmod(defaults="slow") KNLMeansCL(D=1, A=1, h=4.5) |
26th August 2015, 13:33 | #280 | Link | |
It is possible that MeGUI uses its version included.
github.com |
