Old 25th February 2018, 17:52   #1321  |  Link
Khanattila
Khanattila's Avatar
I never used vseditor, but I suspect it could slow things down.
RX 480 8GB (1330MHz / 2000MHz) ~1,29 FPS with 90-100% GPU Load.
script.vpy
import vapoursynth as vs
core = vs.get_core()
clip = core.lsmas.LWLibavSource("Sample.mkv", format="YUV420P8")
# 1920x1080 clip from a Blu-ray.
clip = core.knlm.KNLMeansCL(clip, d=3, a=6, channels="Y",  device_type = "GPU")
clip = core.knlm.KNLMeansCL(clip, d=3, a=6, channels="UV", device_type = "GPU")
clip.set_output()
launcher.bat
vspipe script.vpy NUL -p
PS. Furthermore, there is the possibility LWLibavSource has decoding problems in that particular situation.
You should use a blank clip rather:
core.std.BlankClip(width=1920, height=1080, format=vs.YUV420P8, length=1000)
github.com
Khanattila is offline   Reply With Quote
Old 26th February 2018, 07:47   #1322  |  Link
fadedmaple
fadedmaple's Avatar
script.vpy
clip.set_output()
launcher.bat
Thanks for you explain and advise,i find a very strange thing.
I record a short video here https://youtu.be/yvW8pOkl2_I
I have use a BlankClip in the video,you can see the GPU load change after I close and reopen the chrome .
fadedmaple is offline   Reply With Quote
Old 26th February 2018, 13:48   #1323  |  Link
fadedmaple
fadedmaple's Avatar
You should really use something like GPU-Z instead of Win10's task manager for measuring GPU Load.
A rookie mistake ...
It works well with 90-100% GPU Load.
Old 26th April 2018, 12:45   #1324  |  Link
tuanden0
Could you give me a link to download onpencl for AMD? I can't find it anywhere
tuanden0 is offline   Reply With Quote
Old 26th April 2018, 13:07   #1325  |  Link
In general, a hardware accelerated OpenCL driver should be part of a current graphic card driver (not knowing AMD, but nVidia drivers do install OpenCL.dll and additional hardware specific DLL files in the system director{y/ies}).
Old 26th April 2018, 13:49   #1326  |  Link
OpenCL is a part of AMD GPU driver.
Old 26th April 2018, 15:25   #1327  |  Link
tuanden0
thank you, I installed
Old 17th November 2018, 11:15   #1328  |  Link
tormento
Acid fr0g
tormento's Avatar
@Khanattila what about trying to create a FFT3DCL filter?
@turment on Telegram
Old 21st November 2018, 09:54   #1329  |  Link
Arhu
I'm seeing some weird frame order issues that appear to be happening with KNLMeansCL for me. I'm not sure for how long it has been happening because I only noticed recently with some UHD encodes. It may go back a few months.
1. Without KNLMeansCL frames seem to be fine in the output.
2. With d=0 and some values vor s, a and h sometimes a frame is skipped and later on another frame is repeated.
3. With d>0 and particularly with some UHD sources I occasionally but repeatedly get jumbled frames. E.g. for frames 1, 2, 3, 4, 5, 6 I'd get 1, 2, 3, 2, 5, 6 or something like that.
I didn't have time for more tests yet, but wanted to ask if this is a known problem or if anyone knows why this could be happening? Maybe something with the GPU or some buffer? I'm using a Geforce 1060, currently updating drivers.
Here's a sample script from staxrip:
import os
import sys
ScriptPath = 'D:/stax/staxrip/Apps/Plugins/VS/Scripts'
sys.path.append(os.path.abspath(ScriptPath))
core.std.LoadPlugin(r"D:\stax\staxrip\Apps\Plugins\both\ffms2\ffms2.dll")
core.std.LoadPlugin(r"D:\stax\staxrip\Apps\Plugins\vs\fmtconv\fmtconv.dll")
core.std.LoadPlugin(r"D:\stax\staxrip\Apps\Plugins\both\KNLMeansCL\KNLMeansCL.dll")
clip = core.ffms2.Source(r"D:\clip.mkv", cachefile = r"D:\clip_temp\clip.ffindex")
clip = core.fmtc.bitdepth(clip, bits=16)
clip = core.knlm.KNLMeansCL(clip, d = 2, s = 4, a = 4, h = 0.5)
clip.set_output()
Arhu is offline   Reply With Quote
Old 21st November 2018, 13:34   #1330  |  Link
import os
import sys
clip.set_output()
I suspect that FFms2 plugin is unable to deliver frames in right order for knlmeanscl.
Old 21st November 2018, 14:30   #1331  |  Link
ChaosKing
Test your source with seek-test https://gist.github.com/dubhater/3a2...ae25cd47ff78d2
Old 21st November 2018, 16:14   #1332  |  Link
Arhu
Originally Posted by ChaosKing View Post
I'm too much of a newbie to get it to work, but I found an old post of yours where you describe the issue I'm having. Switched to LWLibavSouce in staxrip and frames look accurate now. Guess I'll use that one from now on.
Bummer. I suppose I won't have to redo all of my earlier encodes as most of them look fine. It's just a select few that suffer from relatively obvious jerkiness where isolated frames weren't just repeated or skipped but came out in the wrong order.
Anyway, thanks for the quick help.
Old 22nd November 2018, 00:20   #1333  |  Link
ChaosKing
Try the FATpack here https://forum.doom9.org/showthread.p...98#post1858098 (need to download seek-test zip AND the latest zip from the 1st page)
You literary just need to extract it and drag&drop your video file onto the bat file.
Old 15th February 2019, 03:24   #1334  |  Link
Katie Boundary
Katie Boundary's Avatar
I just gave this a spin. What's interesting is that it delivers extremely uneven results from one frame to the next. On most, it'll deliver stronger denoising than blur(1.0) without the actual blurring, but on some frames (maybe 20 or 25%?), it seems to do nothing at all.
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 19th February 2019, 15:43   #1335  |  Link
SaurusX
What are the parameters you're using? This is my go-to denoiser, but the choice of parameters makes a big difference.
SaurusX is offline   Reply With Quote
Old 24th February 2019, 15:30   #1336  |  Link
Selur
Selur's Avatar
Small question for clarification: What color spaces are supported when using Vapoursynth?
Because when loading an 8bit 4:2:0 source, I get no problem, but when loading a 10bit 4:2:0 source I get 'only YUV444P10 and RGB30 are supported!'
So does KNLMeansCL only support 4:2:0 when using 8bit?
script I used:
# Loading Plugins
core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/DenoiseFilter/KNLMeansCL/KNLMeansCL.dll")
core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/LSmashSource/vslsmashsource.dll")
# Loading E:\Output\10bitTest.mkv using LWLibavSource
clip = core.lsmas.LWLibavSource(source="E:/Output/10BITT~1.MKV", format="YUV420P10", cache=0)
# making sure input color matrix is set as 470bg
clip = core.resize.Point(clip, matrix_in_s="470bg",range_s="limited")
# making sure frame rate is set to 25/1
clip = core.std.AssumeFPS(clip, fpsnum=25, fpsden=1)
# Setting color range to TV (limited) range.
clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1)
# denoising using KNLMeansCL
clip = core.knlm.KNLMeansCL(clip=clip, device_type="gpu", device_id=0)
# adjusting output color from: YUV420P10 to YUV420P8 for x264Model (i420)
clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P8, range_s="limited")
# Output
clip.set_output()
also adding:
clip = core.resize.Bicubic(clip=clip, format=vs.YUV444P10, range_s="limited")
doesn't seem to fix the issue, when using:
# Imports
# Loading Plugins
# denoising using KNLMeansCL (bit depth: 10)
# adjusting output color from: YUV444P10 to YUV420P8 for x264Model (i420)
# Output
clip.set_output()
I still get:
Python exception: knlm.KNLMeansCL: only YUV444P10 and RGB30 are supported!
using:
clip = core.resize.Bicubic(clip=clip, format=vs.RGB30, matrix_in_s="470bg", range_s="limited")
does the trick for me, so from the looks of it bitdepth > 8 bit requires a conversion to RGB30.
Cu Selur
Old 25th February 2019, 17:03   #1337  |  Link
littlepox
Looks like AMD's new Radeon 7 doesn't like it
Processing under YUV444P16 gives weird output, similar to the problems with Vega.
littlepox is offline   Reply With Quote
Old 26th February 2019, 12:21   #1338  |  Link
DJATOM
DJATOM's Avatar
Tried with rtx2070 and I don't see any artifacts besides lost details from denoising: https://slowpics.org/comparison/ed6f...f-0a5f18a34bff
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 26th February 2019, 12:38   #1339  |  Link
ChaosKing
Khanattila Last Activity: 26th October 2018 19:54
@selur maybe it would be better to open a github issue.
Old 5th March 2019, 21:01   #1340  |  Link
Selur
Selur's Avatar
@ChaosKing: Thanks for the heads-up.
-> https://github.com/Khanattila/KNLMeansCL/issues/42
