Old 25th January 2023, 21:49   #31381  |  Link
RoyGBiv-inRI
Doing a search I found some posts from a few years ago with the same problem. That individual seemed to have resolution by changing to the "required" versions of AVISynth and LAV filters. I had been using those versions, but just to be sure I downloaded them again as well as a new copy of BDRB 21 zip file. I uninstalled AVISynth and LAV filters and reinstalled the newly downloaded versions from the first page and then extracted a new version of BDRB 21. The problem is still exactly the same.
In those earlier posts JDobbs referred to a possible issue with where the files were located or that the file names were too long. I have no idea what files he meant or where these files are located, but I can tell you that everything was installed onto its default folders. I also have done this exact setup a few times before with Win10 and have had no problems.
Your Obedient Servant
SMK
RoyGBiv-inRI is offline   Reply With Quote
Old 25th January 2023, 22:13   #31382  |  Link
nil
Hi. I posted this two weeks ago, unsure of whether to post it in this thread or not; I've not had any responses there, so here we go...
Short version: when reencoding to AAC audio, BD Rebuilder generates a temporary file called audio1.bat which runs faac.exe. This fails for me, because it includes the command line option -br 384000, when the online documentation and command-line help say the option should be -b 384.
What I don't understand is how it used to work fine for me; I had assumed I must have changed something on my PC (broken by a Windows update or something), but I'm running BD Rebuilder's faac.exe (which hasn't changed in a while anyway), and that option is definitely wrong. Utterly confused.
Full details in the other thread.
Many thanks for your help.
nil is offline   Reply With Quote
Old 28th January 2023, 00:14   #31383  |  Link
RoyGBiv-inRI
I don't know where JDobbs and the others who usually are in this thread are, but here is an interesting update. If I set BDRB to put the finished product on a different drive, it works fine. It doesn't matter which drive or how long the path is to that drive, but it works. OTOH, any time I try to put the finished product in the same drive the original files are in, no matter what folder, I get the above error message.
Strange, but since I have a work around, I can at least use BDRB.
SMK
Old 28th January 2023, 01:29   #31384  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Drive full ?
Old 29th January 2023, 18:48   #31385  |  Link
Mike-uk
@jdobbs
no solution but ive the same problem
"C:\Users\xxx\Desktop\BD_Rebuilder\tools\wavi.exe" "C:\USERS\xxx\DOCUMENTS\BD\WORKFILES\AUD_00000_4352.AVS" - | "C:\Users\xxx\Desktop\BD_Rebuilder\tools\faac.exe" - -br 128000 -o "C:\USERS\xxx\DOCUMENTS\BD\WORKFILES\AUD_00000_4352.AAC"
- [17:45:29] Reencoding: VID_00000, Pass 1 of 1
- [17:45:35] Video Encode complete
- [17:45:35] Processing audio tracks
- Track 4352 (eng): Reencoding audio to AAC...
[17:47:45] - Failed to reencode audio, aborted
Mike-uk is offline   Reply With Quote
Old 30th January 2023, 02:30   #31386  |  Link
AmigaFuture
AmigaFuture's Avatar
BD's with DTS-HD XLL - Error
Hello.
I've been going through some of my older BD rips and making MKVs. I've noticed some Movie & Menus processed BDs won't allow making an MKV. Star Wars - 1, 2, and 3 for example. So I got out my discs..and I reripped them. MKVs can by made from the fresh rip without a problem as long as they aren't processed by BD-RB. My logs..
[01/29/23] BD Rebuilder v0.61.28
[12:54:40] Source:  ATTACK_OF_THE_CLONES_O
  - Input BD size: 45.55 GB
  - Approximate total content: [02:51:24.606]
  - Target BD size: 46.26 GB
  - Windows Version: 6.2 [9200]
  - MOVIE and MENUS mode enabled
  - Quality: High Quality (Default), Two Pass
[12:54:40] PHASE ONE, Encoding
 - [12:54:40] Blanking: VID_00050 (1 of 73)
 - [12:54:40] Blanking: VID_00190 (2 of 73)
 - [12:54:40] Blanking: VID_00101 (3 of 73)
[...Snip...]
- [12:56:23] Processing: VID_00882 (72 of 73)
 - [12:56:23] Extracting A/V streams [VID_00882]
 - [12:56:30] Reencoding video [VID_00882]
 - [12:56:30] Keeping original video (no reencode)
 - [12:56:30] Processing audio tracks
   - Track 4353 (eng): Keeping original audio
   - Track 4358 (eng): Keeping original audio
   - Track 4359 (eng): Keeping original audio
 - [12:56:30] Multiplexing M2TS
 - [12:56:36] Processing: VID_00800 (73 of 73)
 - [12:56:36] Extracting A/V streams [VID_00800]
 - [12:59:56] Reencoding video [VID_00800]
 - [12:59:56] Keeping original video (no reencode)
 - [12:59:56] Processing audio tracks
 - [12:59:56] Multiplexing M2TS
[13:02:53]PHASE ONE complete
[13:02:53]PHASE TWO - Rebuild Started
 - [13:02:53] Rebuilding BD file Structure
[13:02:56] - Encode and Rebuild complete
 - WORKFILES folder removed.
[13:02:59] JOB: ATTACK_OF_THE_CLONES_O finished.
Make MKV from processed..
[13:08:09] Source:  ATTACK_OF_THE_CLONES_O_00800
  - Input BD size: 32.70 GB
  - Approximate total content: [02:22:27.872]
  - Mode: MKV, Intact Video, Intact Audio
[13:08:09] PHASE ONE, Encoding
 - [13:08:09] Processing: VID_00882 (1 of 2)
 - [13:08:09] Extracting A/V streams [VID_00882]
  - TSMUXER ERR: 0xFFFFFFFE
   - Extracting video streams [VID_00882]
   - Extracting audio/subtitle streams [VID_00882]
 - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: P:\ATTACK_OF_THE_CLONES_O\BDMV\\STREAM\00882.m2ts
   - Extracting audio streams [VID_00882]
 - Error in attempt to extract audio.
[13:09:09] - Failed to retrieve audio, aborted
Make MKV from fresh rip and not processed..
[13:11:28] Source:  ATTACK_OF_THE_CLONES_O_00800
  - Input BD size: 40.29 GB
[13:11:29] PHASE ONE, Encoding
 - [13:11:29] Processing: VID_00882 (1 of 2)
 - [13:11:29] Extracting A/V streams [VID_00882]
 - [13:13:29] Reencoding video [VID_00882]
 - [13:13:29] Keeping original video (no reencode)
 - [13:13:29] Processing audio tracks
 - [13:13:29] Processing: VID_00800 (2 of 2)
 - [13:13:29] Extracting A/V streams [VID_00800]
 - [13:16:35] Reencoding video [VID_00800]
 - [13:16:35] Keeping original video (no reencode)
[13:16:35]PHASE ONE complete
[13:16:35]PHASE TWO - Rebuild Started
 - [13:16:35] Building ALTERNATE OUTPUT Structure
[13:25:57] - Encode and Rebuild complete
[13:25:57] JOB: ATTACK_OF_THE_CLONES_O finished.
Old 30th January 2023, 03:16   #31387  |  Link
MrVideo
MrVideo's Avatar
You might need to replace the BDRB supplied tsmuxer with a newer snapshot. Yes, it might mean having to do some other workarounds, but it should handle the audio. Worth a try.
Old 30th January 2023, 13:52   #31388  |  Link
tebasuna51
tebasuna51's Avatar
Of course the faac syntax is -b 128 (instead -br 128000) with a max of 500 (kb) for a stereo input.
BTW the faac encoder is not recommended, use qaac or fdkaac with better quality and until 7.1 audio. Also ffmpeg (v3 or higher) until 5.1 audio.
Old 30th January 2023, 19:31   #31389  |  Link
AmigaFuture
I'm cool with workarounds. I noticed that if I disable the AC-3's and keep DTS..an MKV will be made okay. Then do it again in reverse, disable DTS and keep AC-3's..then put them together. There are other ways, also. I went checking for a newer TsMUXER..but then I got sidetracked by having to do some other stuff not computer related. I'll have another look.
Old 30th January 2023, 22:28   #31390  |  Link
AmigaFuture
Nope, the new TsMuxer is the problem. I got it and the GUI archive. It has the same error.
Old 30th January 2023, 23:20   #31391  |  Link
MrVideo
MrVideo's Avatar
Weird that there is an issue with the processed files. If directly going to a MKV file works, why not just use it?
Old 31st January 2023, 18:14   #31392  |  Link
nil
Ah... you may have just provided a clue to my problem. I rebuilt ffmpeg a while ago, and this may match with when my problems started. It may be BDRebuilder was using ffmpeg/fdkaac, I broke it, and it's using faac instead.
So two things, then:
1) How do I persuade BD Rebuilder to use ffmpeg/fdkaac again? It's there, on the path, and functional. Or do I need to build a specific exe or dll?
2) When BD Rebuilder uses faac.exe instead, looks like there's a bug with the command-line options it spits out in audio1.bat. (But possibly no-one notices because no-one uses faac if they can help it)
Cheers
Old 2nd February 2023, 04:19   #31393  |  Link
AmigaFuture
There isn't a problem from Source. It's BD-RB Backup...
Old 2nd February 2023, 13:53   #31394  |  Link
MrVideo
MrVideo's Avatar
I think you may have misunderstood my response. If I read your original posting correctly, if you used the BDRB processed files from the source, the result is a failure. But, if you made the MKV from the source, then all is well. So, why not just skip the BDRB processed files and just use BDRB to make the MKV directly from the source?
Old 5th February 2023, 00:15   #31395  |  Link
Mark_Venture
Originally Posted by cartman0208 View Post
Can you just replace the NVEncC used with NVENCCRE from git? any reason to, or not to? (I mean other than not being tested with NVENCCRE?)
I've been extremely happy so far with NVENCCRE, its ease of use and its output, so I don't want to mess with it. I'm more just curious.
Old 5th February 2023, 05:17   #31396  |  Link
Emulgator
Emulgator's Avatar
I would expect incompatibility only if parameters that matched once
are changed (added, deleted, renamed, ranged differently)
Old 8th February 2023, 21:43   #31397  |  Link
Exactly. Unfortunately I haven't been keeping up with changes -- so I can't say whether there are any that might create an incompatibility.
Old 8th February 2023, 21:45   #31398  |  Link
Cheers
I use it all the time without issue. When I get some extra time I'll go through the code and see how it can happen. It has to be something in the settings.
Old 9th February 2023, 04:01   #31399  |  Link
BTW: There is nothing wrong with FAAC. It encodes AAC fine. It's just not supported anymore.
If you have NeroAAC encoder installed you can use that instead of FAAC. Just collect the path and add it to the [Paths] area of the INI file. Then set the flag telling BD-RB to use Nero. Here is an example with a path from my settings:
[Options]
NEROAAC=1
[Paths]
NeroAACPath=C:\APPS\REENCODER\TOOLS\neroAacEnc.exe
Old 9th February 2023, 11:39   #31400  |  Link
tebasuna51
tebasuna51's Avatar
Of course NeroAacEnc can be used until 5.1.
Warning with 7.1, the default layout for 7.1 (from DTS-MA or TrueHD: L R C LFE Lb Rb Ls Rs) is converted to the default layout for AAC (C L R Ls Rs Lw Rw LFE). See here.
[EDIT]
I check the free versions of Faac 1.30 and Fdkaac 1.04 in https://www.videohelp.com/software/FAAC
The faac output 7.1 m4a is wrong for MediaInfo, NeroDec and ffmpeg:
[aac @ 0000012f3c5ac340] invalid default channel configuration (8)
The fdkaac output 7.1 m4a is correct.
