Old 13th October 2019, 06:39   #41  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffxvid 1.4.2
* Use readlink -e and realpath -e where needed
* Cosmetics
Old 14th October 2019, 15:35   #42  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.4.3
* Support scanning for multiple video tracks in the input file
Old 15th October 2019, 05:00   #43  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.4.4
* Bugfix: use correct video mapping for crop detection
Old 16th October 2019, 06:24   #44  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.4.5
* Support the fftdnoiz denoise filter
Old 17th October 2019, 06:42   #45  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.4.6
* Support the WMV container format
Old 18th October 2019, 06:02   #46  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.4.7
* Bugfix: use correct video track for crop preview with MPlayer
* Bugfix: missing ;; in the additional container formats code
* Renamed variable SCAN_MULTIPLE_VID_TRACKS to SCAN_MULTI_VID_TRACKS
* Some reordering in the config file
* Set Catmull-Rom as default Bicubic/Spline tuning
* Add LPCM detection for audio copy
* Support the mp4/m4v containers
* Add support for cover art for the mp4/m4v/mov containers. Requires MP4Box from GPAC
* Some code optimization
Old 19th October 2019, 08:20   #47  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.4.8
* Use atomicparsley to add cover art for the mp4/m4v containers. This removes dependence on MP4Box and makes it possible to copy over metadata info in an easy way
* Add +frag_keyframe to the -movflags option when output is mp4
* Renamed variable METACOVER to MKVCOVER
* Updated the man page
Old 20th October 2019, 05:44   #48  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.4.9
* Added support for embedding of SRT/SSA/ASS subtitles in the MP4/M4V containers
* Moved back to MP4Box for adding cover art to MP4/M4V/MOV. Apparently, after lots of testing, atomicparsley creates files that hang during playback
* Cosmetics
Old 21st October 2019, 04:42   #49  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.0
* Add support for verbose logging to a log file
* Bugfix: -map_metadata and -map_chapters where not set to 0 when the respective options in the config file were set to "y"
Old 21st October 2019, 09:48   #50  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.1
* Renamed variables $MDATA and $CHPS to $METADATA and $CHAPS
* Add $METADATA and $CHAPS to the remuxing code
Old 22nd October 2019, 05:25   #51  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.2
* Add support for SRT/SSA/AAS subtitles for the MOV container
* Remove the colorprim lines from the video_colorspace_func() function. They are not used
Old 23rd October 2019, 04:22   #52  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.3
* Set default audio codec based on output container format
* Add colr option for MP4Box to the video_colorspace_func() function and the color primaries code. Only used for MOV
* Add -color_primaries, -color_trc and -colorspace to the FFmpeg command line options
Old 24th October 2019, 06:20   #53  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.4
* Add constant/non-constant matrix option to the video_csmisc_func() function
Old 25th October 2019, 06:36   #54  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.5
* Detect audio bit depth and add it to the audio metadata
* Added detection for DTS Express and DTS-HD HR for audio copy
* Use -show_entries instead of -show_streams for detecting audio properties with ffprobe. Removes piping to grep and awk
* Support setting the FLAC bit depth for encoding
* Minor restructuring and variables renaming in the audio code
Old 26th October 2019, 08:09   #55  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.6
* Renamed audio variable aid[i] to aidx[i] and moved it outside of the if conditional that decides the audio codec. This removes the same code in three places and now uses the global aidx[i] variable
* HE-AACv2 only supports 2 channels. Update the audio code to reflect that
* When running in batch mode, add a warning about automatic audio metadata and offer an option to enable/disable it
* Added -tmp option to MP4Box to store temp files in the output directory
* Some minor improvements to the audio options
Old 27th October 2019, 09:32   #56  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.7
* Use 16 bits as bit depth metadata when encoding to TrueHD audio
* Removed an unneeded if conditional in the audio bit depth code
* Add director and cast metadata for the MKV container
* Reorder some code for the output shell file
* Cosmetics
Old 28th October 2019, 06:34   #57  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.8
* Added support for director/cast metadata for MP4/MOV/M4V
* Added +use_metadata_tags to the $movflags variable for MP4/MOV/M4V
* Support ADPCM encoding for DTS audio
* Fixed an issue where asking for director/cast occured multiple times if remuxing to other containers was enabled
Old 29th October 2019, 07:18   #58  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.5.9
* Removed an unneeded check for audio codec in the conerror_func() function
* Removed a stale "" in the case statement that checks the channels for AC3
* Support setting the matrixed stereo type when resampling stereo input
* Support setting the filter type of the audio resample filter
* Cosmetics
Old 4th November 2019, 17:32   #59  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.6.0
* Merged two case statements in the metadata code for mkv/mp4/mov
* Bugfix: Using ADPCM encoding for DTS audio wasn't possible due to wrong variable used in the if conditional
Old 11th November 2019, 14:52   #60  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.6.1
* Added support for the (newer) deblock filter
