24th January 2018, 08:14 | #101 | Link |
Unfiltered: 30MB
smdegrain(thsad=200,lsb=true,lsb_in=false,lsb_out=true) = 21MB smdegrain(thsad=200,lsb=true,lsb_in=false,lsb_out=true, plane=0) = 28MB smdegrain(thsad=200,lsb=true,lsb_in=false,lsb_out=true, plane=3) = 81MB smdegrain(thsad=200,lsb=true,lsb_in=false,lsb_out=true, plane=1) = 83MB Umm.... eh, 3.1.2d does it too. Last edited by kuchikirukia; 24th January 2018 at 08:22. |
25th January 2018, 14:34 | #102 | Link | |
See My Avisynth Stuff |
11th February 2018, 16:37 | #103 | Link |
days ago I did update stab3, now it's should be more stable with mirror=15
16th February 2018, 13:36 | #104 | Link |
Acid fr0g
SMDegrain 16 bit
I want to ask you a curiosity: is SMDegrain written to work with the 16 bit depth capabilities of MaskTool, MVTool and KNLMeansCL or does it use some kind of workaround?
AFAIK they are the only filters I use with the following: PHP Code:
@turment on Telegram |
16th February 2018, 15:09 | #105 | Link | |
edit: it will not be faster in native 16 unless you did this workaround Code:
#8bit source c=last SMDegrain(globals=3,tr=4,PreFilter=4) global fv1 = fv1.MScalevect(bits=16) global fv2 = fv2.MScalevect(bits=16) global fv3 = fv3.MScalevect(bits=16) global fv4 = fv4.MScalevect(bits=16) global bv1 = bv1.MScalevect(bits=16) global bv2 = bv2.MScalevect(bits=16) global bv3 = bv3.MScalevect(bits=16) global bv4 = bv4.MScalevect(bits=16) c ConvertBits(16) SMDegrain(globals=1,tr=4,thSAD=600,contrasharp=false,refinemotion=false,truemotion=true,plane=4) ConvertBits(8,dither=1)
See My Avisynth Stuff Last edited by real.finder; 16th February 2018 at 15:26. |
18th February 2018, 09:14 | #106 | Link |
Acid fr0g
Thanks for your clear reply.
To clarify my question: will be possible one day to have a SMDegrain (bitdepthworkingspace=8/10/16,outputbitdepth=8/10/16) without the need of LSB? Would like also to try if a pure 16 bit processing would be more precise than a "fake" one.
18th February 2018, 16:31 | #107 | Link | |
See My Avisynth Stuff Last edited by real.finder; 18th February 2018 at 16:36. |
10th March 2018, 12:21 | #108 | Link |
Acid fr0g
@real.finder
Could you please tell me which is the difference between PHP Code:
PHP Code:
10th March 2018, 13:40 | #109 | Link | |
10th March 2018, 13:51 | #111 | Link |
back then and still KNLMeansCL can't process chroma with luma in subsampling Chroma (new KNLMeansCL can do process chroma alone) so dogway use stacking method, you can see the code yourself, or back to dogway posts in videohelp forum
10th March 2018, 15:58 | #112 | Link |
Eurobeat Fan
Hi real.finder,
Is there any way to run srestore in AVS+ x64? At first sight, it won't run because there doesn't seem to be a x64 version of GScript. Since I have read AVS+ supports GScript's functionality natively, I tried to replace the call to GScriptClip in srestore.avsi with ScriptClip, but a "I don't know what 'dm' means" error is the farthest I got. Thanks. |
10th March 2018, 17:55 | #113 | Link |
GScriptClip is from Grunt plugin, not GScript.
10th March 2018, 20:59 | #115 | Link | |
and I think the error related to something else (not Grunt) you use mt "Prefetch()"? cuz it will not work, runtime things (srestore use it) not compatible with mt yet
11th March 2018, 09:00 | #116 | Link | |
Acid fr0g
What does this line !lsb && lsb_in ? Ditherpost(mode=6,slice=false) : last means? As I am using SMDegrain_KNLMeansCL as a prefilter (just to have more control over prefilter parameters), is it useful to dither when SMDegrain already dither again at some point? Wanting to use KNLMeansCL as a plain prefilter, would it be sufficient to use: pre =KNLMeansCL (d=0, a=3, h=7.0, channels="Y") pre2=KNLMeansCL (d=0, a=3, h=7.0, channels="UV") SMDegrain (tr=6, thSAD=400, refinemotion=false, lsb=true, mode=0, contrasharp=false, PreFilter=pre2, truemotion=false, plane=4, chroma=true) or the very complex prefilter script is necessary?
@turment on Telegram Last edited by tormento; 11th March 2018 at 09:07. |
11th March 2018, 12:15 | #117 | Link |
remember that I told you that mvtools don't has lsb_in anywhere, it's just has lsb parameter in mdegrainX, so you must dither any stacked input clip
yes, you can use pre =KNLMeansCL (d=0, a=3, h=7.0, channels="Y") pre2=KNLMeansCL (d=0, a=3, h=7.0, channels="UV") SMDegrain (tr=6, thSAD=400, refinemotion=false, lsb=true, mode=0, contrasharp=false, PreFilter=pre2, truemotion=false, plane=4, chroma=true) or anything give you what you want but I think you need to added "pre." before KNLMeansCL in pre2, so it should be pre2=pre.KNLMeansCL (d=0, a=3, h=7.0, channels="UV")
See My Avisynth Stuff Last edited by real.finder; 11th March 2018 at 12:18. |
11th March 2018, 12:22 | #118 | Link | |
Acid fr0g
11th March 2018, 12:25 | #119 | Link |
why? lsb is hack, he already did support native avs+ HBD, and he will add out16 as replacement for lsb method, see last posts in his mvtools Thread
See My Avisynth Stuff Last edited by real.finder; 11th March 2018 at 12:27. |
avisynth, avs script, avs+, banding, generator, hbd, mod |
