7th January 2008, 00:43 | #262 | Link |
next time use searching ok?
http://forum.doom9.org/showthread.php?t=129697
7th January 2008, 09:10 | #264 | Link |
HDConvertToX author
... for ps3 qequing ?
maybe... i will look at this BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
18th January 2008, 16:20 | #265 | Link |
I have a feature request, but before I do, I wanted to say it's a great tool for me! I have been transcoding some of my anime files into PS3 compatible xvid files, and it helped me learn a lot of the parameters of mencoder itself.
Now, I would like to request... 1. AVISynth mode (activated by a check box) - all you need to do is to automatically create a file with the .avs extension with DirectShowSource("filename"); and then use that file as the input to mencoder. It's simple enough for me to create the file manually, but when you're doing upwards of 20+ episodes at once.... it gets tedious^^; Oh, the reason I want this is that this is the only way to hardsub mkv anime files with embedded .ass subtitles. 2. Have a place to force the audio sample rate For some reason when converting some files, mencoder complains the sample rate is too low, and I had to manually add "-srate 48000" to divx.bat... 3. Can the default of the video size be "original size"? The settings in the first two tabs can't seem to be saved... Thanks in advance! |
18th January 2008, 16:28 | #266 | Link | ||
HDConvertToX author
mencoder should be more reliable then directshowsource...
but i will look Quote:
i can suggest even to "play" with AutoFF BHH
18th January 2008, 17:41 | #267 | Link |
Problem is mencoder itself can't do mkv with embedded fonts/subtitles. It will transcode but you don't get the subtitles. Using AVIScript is the only way I know of right now. Thanks for taking a look at it.
Will try with autoFF when I go home tonight |
20th January 2008, 00:51 | #268 | Link |
I found a bug in AutoMEN 3.8. You can see that it lack a colon between crf and threads (marked in bold). This happen only when I choice Quality Great, all other Quality Encoding have went well.
"G:\AutoMen\mencoder.exe" -vf harddup,crop=704:448:8:70,scale=720:-2,hqdn3d=2:1:2 -sws 2 -priority idle -o "C:\Work in progress\Black Mask_automen.avi" -ovc x264 -x264encopts crf=16threads=auto:frameref=3:bframes=2:deblock:direct_pred=auto:level=41:partitions=p8x8,b8x8:me=hex:me_range=12:subq=5:chroma_me:mixed_refs:brdo:bime:trellis=0:weight_b:nr=0 -oac faac -faacopts br=144:mpeg=4:object=1 -channels 2 "K:\Redigering\Black Mask.mpg" "G:\AutoMen\mplayer.exe" "C:\Work in progress\Black Mask_automen.avi" -dumpaudio -dumpfile "C:\Work in progress\Black Mask_automen.aac" "G:\AutoMen\mencoder.exe" "C:\Work in progress\Black Mask_automen.avi" -o "C:\Work in progress\Black Mask_automen.h264" -of rawvideo -ovc copy -nosound "G:\AutoMen\mp4box.exe" -add "C:\Work in progress\Black Mask_automen.h264" -add "C:\Work in progress\Black Mask_automen.aac" -fps 25.000 "C:\Work in progress\Black Mask_automen.mp4" |
20th January 2008, 05:53 | #269 | Link |
Actually I found a similar error today... when you use the advance option to set the sample rate, the 2nd pass will fail because the option will become "-srate 48000-oac mp3lame" (there needs to be a space between 48000 and -oac)
21st January 2008, 14:00 | #271 | Link |
I have found a little bug in the 9th video quality profile (copy from the batch file generated by automen) :
first mencoder line :bframes=32: second mencoder line :bframes=3: |
3rd February 2008, 20:37 | #273 | Link |
hi buzzqw,
thanks for your nice prgramm. I like the option to manually select if the clips should be deinterlaced or not. This is a feature I miss in many other programms - they do it almost all automaticly. The only thing that is difficult for me in AutoMen 4.1 is the handling of the queue. I'm used to do it like in AutoGK: work on a job, do the settings (crop etc.), have a preview and then put it in the queue. This does only work in AutoMen for the first job. if I work on the second job and want to control the crop-settings by a quick preview I always see a preview of the first job in the queue. I'm only able to get a preview of the second job if I put this one into queue, use the P-button and cancel the preview of the first shown job. This is not very comfortable even if you cannot delete a job of the queue-list. Is there a simple way to make this easier? Thanks again for your work! Spreeni |
3rd February 2008, 22:20 | #274 | Link | |
HDConvertToX author
thanks Spreeni, i will check!
and about Quote:
BHH
4th February 2008, 12:54 | #275 | Link |
HDConvertToX author
update to 4.2 http://www.64k.it/andres/data/automen/AutoMen42.exe
now preview is based on what file is "selected" on queue window also update a new full package http://www.64k.it/andres/data/autome...Men42_FULL.rar BHH
4th February 2008, 20:29 | #277 | Link | |
Hello Buzzqw,
Unfortunately there seems to be a bug in the preview of the main window. If I drag an mpeg-file into it and try to get a preview (P-button or crop-preview) the command-window gets up and vanish and no mplayer appears. If this job is then put into queue, there is missing the filename for this job and of course no preview is shown, too. Encoding is also not possible - I think it's because of the missing filename. If I put a job into queue without doing a preview before, everythings working normal (encoding and queue-preview). Spreeni |
4th February 2008, 23:17 | #279 | Link | |
5th February 2008, 08:14 | #280 | Link |
HDConvertToX author
update to 4.3
http://www.64k.it/andres/data/autome...Men43_FULL.rar http://www.64k.it/andres/data/automen/AutoMen43.exe is a file on queue is selected the preview is on this file, if no file on queue is selected the preview is based on actual input file BHH
automen, ffmpeg, handbrake, mencoder, x264 |
