12th May 2020, 01:42 | #62 | Link |
VapourSynth R50 Installer is up, lots of things were updated, which includes Cython (0.29.17), FreeType (2.10.2), Fribidi (1.0.9), LibWEBP (1.1.0), Python (3.8.2), and VapourSynth (R50). As with the last update, since it's moving from 3.7 to 3.8 (should be the last shift for a while) you will need to backup site-packages (the scripts shortcut on the desktop) before installing.
17th May 2020, 00:52 | #65 | Link |
While everyone should be using R50, I went ahead and updated the R49 installer to have Python 3.8 as well. In addition to that, I started the move away from shared dependancies for most things so it's a bit less complicated. I will be looking into updating some plugins that can be compiled with the dependencies build in to reduce some complications for less experienced users.
17th May 2020, 01:33 | #66 | Link |
Thanks for release again! Hope VapourSynth 50 on macOS will work in Hybrid same as 49 worked.
I see you upload a folder with scripts "havsfunc-200414" Are those scripts required for VapourSynth-R50? Should i put them to python "site-packages" folder? Last edited by shph; 17th May 2020 at 02:06. |
17th May 2020, 02:04 | #67 | Link | |
Should i just download new versions from MediaFilre folder and replace them? This makes things even more complicated for new users... |
17th May 2020, 02:06 | #68 | Link |
No, R50 should have the latest version, however with those I chose to use the shared libs as it would have bloated the installer. The downloadable versions are just there so if someone compiles VapourSynth or uses brew to install it they can just snag those plugins without the need for also snagging dependancies.
17th May 2020, 02:16 | #70 | Link | |
I just uploaded that with the date I put the package together because someone on Twitter was having a hard time getting hasvfunc to work and I was trying to help them make sure they had everything. |
12th June 2020, 21:55 | #72 | Link |
BM3D, DCTFilter, DFTTest, EEDI3m, FFT3DFilter, MVTools, and NNEDI3CL were all just updated or recompiled using static libs for the dependancies so that the dependancies will not need to be downloaded separately. I have removed the previous versions and the dependancies to avoid confusion and issues.
13th June 2020, 01:07 | #73 | Link |
Thanks for update! Can you please explain further how to deal with your new "recompiled using static libs" updates? I just usually install all your plug-ins from MediaFire folder.
Is it enough just replace old versions with new versions of BM3D, DCTFilter, DFTTest, EEDI3m, FFT3DFilter, MVTools, and NNEDI3CL in vapoursynth folder? Could it be a conflict if i didn't delete old dependencies? I'm not sure which exact dependencies use each of these plug-ins. What if some same dependencies used by other plug-ins? |
13th June 2020, 02:20 | #75 | Link |
Ok, seems works. I updated VapourSynth + Plugins + Scripts + Hybrid package here as usual: https://forum.doom9.org/showthread.php?t=181299
17th June 2020, 04:36 | #78 | Link |
Noticed the FFMS2 included in the installer was the old copy that links to Libz even though I had removed it in favor of using the static lib. While it still works without it is possible it may have some issues with random stuff so I updated the R49 & R50 installers with a new copy and also updated LSMASHSource to the latest release. There is also a new copy of LSMASHSource in the plugin downloads location with the static libs as well and that copy uses FFmpeg 4.3.
18th June 2020, 01:45 | #80 | Link |
Small update, I've been working on a backlog of requests for a while and I'm close to finishing that, however there are a few that were requested that will not be added for following reasons:
depan: Depreciated bilateralgpu: Depreciated IT: Crashes RemoveGrainSP: Crashes DGMVSource: Windows Only vcfreq: Windows Only vcmod: Windows Only vcmove: Windows Only vctrans: Windows Only VSFilterMod: Windows Only This does not mean these will never be compiled and added, however I do not have the time right now to troubleshoot and submit pull requests or fixes for ones that are broken and some are just optimized for Windows so much that they might need to be entirely reworked. Last edited by l33tmeatwad; 18th June 2020 at 04:21. Reason: Updated Information. |
meatwadismagical, meatwadthegreat |
