19th May 2013, 08:02 | #17241 | Link |
J, are you sure? Hehe...perhaps I should have chuckled here when I noticed. He (Eddie) was cool, a nice bit of contrast. Age...is whatever you make it to be.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 19th May 2013 at 08:12. |
19th May 2013, 16:47 | #17242 | Link |
I did turn them off, for each re-rip (yesterday), but I like to keep them on for other reasons...since I sometimes decide the compressed results just aren't good enough and decide to burn a DL version instead. And for that, I want those settings on. And since I ONLY do "Movie Only" encodes, I'm trying to figure out why your software would care. I'm not doing any blanking or any other actions related to other titles. Just the main title for a "Movie Only" encode.
And I tried the AVC encode and that failed as well. Though I did keep the AnyDVD settings off, so did not see that error again. But looking in the registry is not remotely a guarantee, as I might have something I ripped a year ago (with those settings on). In any case, Re-Install what? Those components you mentioned or BD Rebuilder? Because if so, why? Nothing else in my system has changed...except for BD Rebuilder. And I hate to reinstall stuff, as really I have to Uninstall those components, go into the Registry and clean up the garbage their uninstalls leave behind (which is usually EVERYTHING), and then reinstall them. Otherwise my Registry just gets more cluttered up. Windows is just not smart enough to reuse entries. But if that's what's needed, I can do that. Just want to be sure the mechanic is just not unplugging wires and plugging them back in just to see if that's the problem. But in any case, what changed in BD RB between the time this issue was not be reported as an issue and now. And why would there be a potential conflict or configuration issue in my system with DirectShow? Also, there was reference to looking in some DirectShowxxxxx.txt file for instructions on possibly resolving a DirectShow related issue...but where can I find that? Thanks. |
19th May 2013, 17:29 | #17243 | Link |
@Winenut
Those options in AnyDvd are great for straight playback but they can mess up an encode by possibly affecting playlists, etc. Nothing has changed in your system? No media player updates, encoding software, codec packs, windows updates, WMP updates. Uninstall FFDshow, Haali, avisynth, and delete BD_RB. Reinstall all of them to eliminate any issues on your computer. |
19th May 2013, 17:46 | #17244 | Link |
Yes. No updates (period). No installs. Nothing except the new version of BD Rebuilder...and so I'm not convinced this is a problem related to FFDSHOW, Haali, or Avisynth. I have the recommended versions installed, and Inspect flags everything as ok. So call me stubborn, I don't take out the engine and put it back when it won't start...just because I don't know what else to do.
In checking through my accumulated logs, it does seem I've been using DirectShow for a long time...but perhaps some of the changes related to BD Rebuilder's handling 3D discs differently (and I don't use 3D discs) might have altered the options and perhaps that's the issue. And perhaps I need to change something. But what? But one day (under 43.04) it worked, and the next (under 44.06) it didn't. For any disc I've tried. BD Rebuilder is not really installed per say. Just unzipped into the it's folder...which my shortcut points to. And I tried running it as an Administrator, in case this latest version needed that. But that's didn't help. But I'll see if can download a prior version (before 44.04, which the problem seems to have started to be reported)...and it that's works... |
19th May 2013, 18:15 | #17245 | Link |
I downloaded and am running verrsion 44.03...and its seems to be working very nicely. Much farther along on this particular title than 44.06 got. And unlike 44.06, I see the 2 pair (3 each) of FFdshow and Haali in the tray (since I'm running DirectShow as a 3-way)...just as I'm used to seeing.
So once again...what changed with 44.04 (iinto the 44.06 version that would not work for me) that makes it different in how it works from 44.03? |
19th May 2013, 18:24 | #17246 | Link |
Is this it? Because it appears to only be applicable to 3D ?
- Added support for output of 3D source BDs to SBS 3D via the SETUP dialog. This option only supports movie-only (including ALTERNATE) mode and will only function if you have separately installed and properly configured the DirectshowMVCSource() DLL according to it's accompanying documentation. BD-RB must also have write access to it's folder. This feature should be especially useful in making 3D MKV and MP4 files or even DVDs from 3D BDs. The output, of course, requires a monitor or TV that supports SBS 3D.(v0.44.2) - Added a new hidden option "TYPE_OF_3D" that will allow you to specify an alternate output type for 3D (other that the default SBS). Options include Over/Under and Anaglyph. (v0.44.2) Is this saying that I need to do something with the DLL for DirectshowMVCSource() to 2D discs? Because i did not install it. Because as far as I can see I don't have this particular DLL installed. All I have is the DirectShowSource.dll. |
19th May 2013, 21:36 | #17247 | Link |
I use 44.06 and it works fine. You don't need to worry about Directshowmvcsource unless you are encoding to 3D. The installation of the helper apps might have become corrupted. Try uninstalling and reinstalling, or hope that JDobbs starts making house calls.
19th May 2013, 22:49 | #17248 | Link | |||
20th May 2013, 00:18 | #17249 | Link | |
Mr
20th May 2013, 08:24 | #17250 | Link |
Hi all,
I have made an interesting discovery I think regarding BD3D re-encoding/re-authoring, I recently asked jdobbs to add a alternate profile to output Full SBS 3D to MKV which results in a SBS Output of 3840x1080 which do work very well on PC, I was looking for a way to play this result in Blu-Ray Format and what I done was I put the created MKV into tsMuxer and set it to output to a Blu-Ray Disc and after it created it I tried to open it with TotalMedia Theatre 6 and it didn't like it much but PowerDVD 13 auto switched to 3D mode and played it back as if it was a original 3D Disc and reported it was outputting in 1920x1080 and its size was under BD25 so I can burn it to smaller media. Thought this was interesting and thought I would share, I doubt it will work on standalone players but I will try later. Edit: Tried the result burnt on RE media on my Samsung BD3D standalone player and as expected no Video out but HD Audio was being output perfect on a good note it still worked perfect from the PC using a software player, I was able to get TotalMedia Theatre 6 working by manually switching to 3D but PowerDVD 13 works flawless with auto 3D Switching. Last edited by sojourner353; 20th May 2013 at 14:32. |
20th May 2013, 14:58 | #17251 | Link | |
20th May 2013, 19:00 | #17254 | Link |
Mr
Trying to create 3D mkv from the movie Dredd and got the following mkvmerge error at the end. Looks like the problem seen by AmigaFuture because there is a zero-length AC3 file in the workfiles (AUD_00201_4353.AC3).
Log file: Code:
[05/20/13] BD Rebuilder v0.44.06 (beta) [07:41:12] Source: DREDD_00800 - Input BD size: 23.61 GB - Approximate total content: [01:35:51.787] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, 640Kbs DD5.1 - 3D conversion mode enabled - Decoding/Frame serving: DirectShowMVC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [07:41:12] PHASE ONE, Encoding - [07:41:12] Processing: VID_00201_3D (1 of 1) - [07:41:12] Combining multiple 3D segments. - [07:57:48] Extracting A/V streams [VID_00201] - [08:10:16] Reencoding video [VID_00201] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 137,905 frames - Converting output to Side-By-Side 3D Format - [08:10:16] Reencoding: VID_00201, Pass 1 of 1 - [09:50:42] Video Encode complete - [09:50:42] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (eng): Keeping original audio [09:52:35]PHASE ONE complete [09:52:35]PHASE TWO - Rebuild Started - [09:52:35] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [09:55:01] - Failed to REBUILD Code:
[Status] LABEL=DREDD VERSION=v0.44.06 (beta) SOURCE_SIZE=25346598912 SOURCE_VIDEO_SIZE=25346598912 TARGET_SIZE=8422162432 REDUCTION=.33227978480429 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng;fra;ger;spa; BACKUP_MODE=1 MOVIEONLY_TYPE=10 USE_LAVF=0 INSTANCES=4 DGDECNV=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=0 [00201] AUDIO=110 PGS=101 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=3540969373 SPLITS=1 NSIZE=0 FLINK=-1 MLINK=0 Last edited by dfsooner; 20th May 2013 at 19:06. |
21st May 2013, 00:27 | #17256 | Link | |
Is that what happens when eyes become code-crossed?? Haw, haw!
21st May 2013, 02:09 | #17257 | Link |
I am really sorry if this has been asked before I went back quite a few pages and even tried the forum search and found nothing, but I do remember a long time ago this being talked about, but does BD-RB have a problem with PIP audio? I ran it on a title and everything on the BD works but the PIP audio, and I see that when I load the BD into BD-RB and I click on full some audio files are still "x" out, so I click on them to un "x" them but one file stays "x" is this the audio for the PIP? which I think it read DTS Express, and again sorry for bringing this up now because like I said I do remember quite some time ago this being discussed but I cannot find it now, but it would be nice to have audio with the PIP lol.
Thanks *EDIT, never mind, I googled some more and found my answer at the Slysoft forums lol, I read that I needed to enable a hidden setting in my ini file, DTSX_ENABLE=1, so I am trying it out now. Thanks and sorry to bring up and old subject. Last edited by thegame; 21st May 2013 at 02:32. |
21st May 2013, 02:30 | #17258 | Link |
you need to enable the hidden options for them to be processed. Enter the following into the bdrebuilder.ini file in it's installation folder "ENABLE_TEST=1" and "DTSX_ENABLE=1". That will allow them to be processed. Remember though, not all standalone players like the way how BDRB does it's magic. Some play the audio, some don't (even if your player is setup properly to allow for mixed audio). More often then not software players like powerdvd don't play the pip stream at all, if they do. Usually without audio aswell.
dts-e or pip audio streams in general can easily be identified. they'll be labelled something like "AUD_008 (2nd) DTS-Express, Stereo, English". note that the "DTS-Express" part can also be AC3. There will also be an entry under the main video title for "Secundairy Video". That's the pip stream video. Last edited by Ch3vr0n; 21st May 2013 at 02:33. |
