Old 17th October 2013, 20:59   #2341  |  Link
manolito
manolito's Avatar
Thanks very much MrC for the new version...
Everything works nicely here, I just found a (purely cosmetic) issue which might have been present for some time...
What I did was trying to just author and burn a fully DVD compliant MPEG2 file which was small enough to fit on one DVD. My settings are to keep compliant video and audio, so all AVStoDVD had to do was demux the source and author it using MuxMan.
After importing the source file the main window told me that the final size would be 9.5 GB (source file was 2.9 GB) and the status line was very red. A novice user might have given up at this point, but I started the process anyways, and it finished successfully.
This time it is not MediaInfo's fault, I tried three different versions.
Here's the log:
<17.10.2013 20:35:55>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 1
DVD Size: 9526/4450 MB (214%)
DVD Output Setup: DVD-Ordner
DVD Label: DVD
DVD Menu: No Menu
Output Folder: I:
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: No
Post Process Task: Fortschrittsfenster anzeigen (Voreinstellung)
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Spline36Resize/Spline36Resize
Frame Adjust Strategy: 1
PAL SpeedUp: 1
Video Resolution: 0
Video BitRate Min: 2000
Video BitRate Level 1: 6500
Video Profile Level 2: 3500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 224
Keep DVD Compliant Audio: 1
Normalize Audio: 1 (@ 0.98)
Auto Delay Audio: 1
DVD Audio Language (Primary): DE - German
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): DE - German
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 16pt (255,255,255)
Chapters Interval: 6
Use Source Chapters: 1
DVD Burning Drive: H: BENQ DVD DD DW1620 B7W9
DVD Burning Speed: 8x
Auto Erase DVD RW: 0
Unload ActiveMovie library: 0
Adjust ffdshow at runtime: 1
Save General Settings: 0
TITLE 1 SOURCE FILES
Video: I:\test.mpg
Info: MPEG-2 Video - 2507 kbps - 720x576 - DAR 1,778 - 25 fps (CFR) - Interlaced (TFF) - 2:28:38 hours - 222966 frames
Audio 1: I:\test.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 2 ch - 48000 Hz - 2:28:38 hours (0 ms delay)
[MediaInfoLib - v0.7.58]
AVISYNTH SCRIPT
Import("E:\Programme\AVStoDVD\Lib\A2DSource.avsi")
# Video is frameserved by AviSynth just for Preview and Edit purposes.
Video = A2DVideoSource("I:\test.mpg", CacheFolder="I:", FrameRate=25, VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("I:\test.mpg", CacheFolder="I:")
Video = Video.ConvertToYV12(interlaced=true)
AudioDub(Video, Audio)
START VIDEO DEMUXING OPERATIONS
Target Video FileSize: 9037,4 MB
FFmpeg Parameters: -i "I:\test.mpg" -vcodec copy "I:\DVD_0_test.m2v"
<17.10.2013 20:43:11>
END VIDEO DEMUXING OPERATIONS
Created File: I:\DVD_0_test.m2v (2637,7 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2480 kbps - 720x576 - DAR 1,778 - 25 fps (CFR) - Interlaced (TFF) - 2:28:38 hours - 222966 frames
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "I:\test.mpg" -acodec copy -map 0:1 "I:\DVD_0_test_1.ToFix.mp2"
<17.10.2013 20:45:29>
END AUDIO DEMUXING OPERATIONS (Track 1)
Created File: I:\DVD_0_test_1.mp2 (204,1 MB)
OUTPUT AUDIO INFO: MPEG-1 Audio layer 2 - 192 kbps - CBR - 2 ch - 48000 Hz - 2:28:38 hours (0 ms delay)
<17.10.2013 20:45:30>
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "I:\DVD_0_BatchMux.ini"
BatchMux ini file:
-d "I:\DVD_0\VIDEO_TS"
-mxp "I:\DVD_0_MuxMan.mxp"
-l "I:\DVD_0_MuxMan.log"
-muxman "E:\Programme\AVStoDVD\MuxMan"
-prio LOW
-palette "I:\DVD_0_Palette.txt"
-v "I:\DVD_0_test.m2v"
-vidmode LB
-a1 "I:\DVD_0_test_1.mp2"
-a1lang de
-cellfr "I:\DVD_0_test_Chapters.txt"
-progfr "I:\DVD_0_test_Chapters.txt"
-chapfr "I:\DVD_0_test_Chapters.txt"
<17.10.2013 20:58:51>
END DVD AUTHORING OPERATIONS
Created Folder: I:\DVD_0 (2926,4 MB)
CHECK DVD SIZE
DVD Folder (actual) Size: 2926,4 MB
vs Estimated Size: 9526 MB -> 69,3% undersize
vs Assets Size: 2841,9 MB -> Warning!
Log file created by AVStoDVD Release 2.7.2
As i said, it is purely cosmetic...
Cheers
manolito
Old 17th October 2013, 22:23   #2342  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Well, not so cosmetic, at least for a less experienced user.
Use following hotfix
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 18th October 2013, 03:35   #2343  |  Link
manolito
manolito's Avatar
Wow, this is hard to believe...
At 10 PM I report a non-critical issue for some software I use to its author.
At 11:30 PM the author sends me a working hotfix.
You would think that I must have paid good money for this software, plus I purchased priority gold support. And even then this kind of customer service would seem extraordinary.
But this just happened with AVStoDVD which happens to be free...
MrC, you are amazing...
Thank you so much,
Cheers
manolito
Old 18th October 2013, 09:03   #2344  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Wait, wait, thanks for the kind words... but actually the hotfix was already ready...
Bye
MrC
AVStoDVD Homepage
Old 6th November 2013, 05:03   #2345  |  Link
Fishman0919
FishmanMod Android Dev
Fishman0919's Avatar
ffmpeg 2 pass support?
@MrC...
Any chance of seeing 2-pass ffmpeg video support?
ffmpeg ver 2.0.2 and 2.1 are pretty good.
"Cinderella story, out of nowhere,
former greenskeeper, now about
to become the Masters champion.
It looks like a mirac- it's in the hole!"
Fishman0919 is offline   Reply With Quote
Old 6th November 2013, 05:03   #2346  |  Link
netmask
netmask's Avatar
Is it possible to set subtitles default ON if so how?
SONY 75" Full array 200Hz LED TV
Yamaha A1070 amp
Zidoo UHD3000, Popcorn Hour A-500
BeyonWiz PVR T3 & V2 (Enigma2 clone)
Chromecast
Pioneer Bluray BDP-150-K
Windows 7 Ultimate
QNAP NAS TS851
netmask is offline   Reply With Quote
Old 6th November 2013, 08:09   #2347  |  Link
manolito
manolito's Avatar
Originally Posted by Fishman0919 View Post
@MrC...
I just tested ffmpeg 2.1 a little bit, and I agree that it is pretty good...
First of all it does play along nicely with AviSynth 2.57 and 2.58 again (thanks qyot27 ). I used it within AVStoDVD for a couple of test conversions and did not run into any problems.
But I do not see any reason to include 2-pass ffmpeg support in AVStoDVD. First of all it would not be a simple matter of just changing 1 or 2 command line parameters. Instead ffmpeg would have to be called twice with different parameters.
And second I do not see any benefit. If you need 2-pass for higher quality, you already have the HC encoder. Do you believe that ffmpeg 2-pass would give you higher quality than HCenc 2-pass? Or do you think that ffmeg would be faster than HC? I doubt it in both cases.
Cheers
manolito
Old 7th November 2013, 05:42   #2348  |  Link
Fishman0919
Cheers
manolito
I agree... somewhat.
Faster... no
Better... On most stuff I encode below 3500k, I feel Yes. Anything above 3500k, mostly No.
Calling ffmpeg for multi passes can be done with just 1 command line bat file with different settings.
ffmpeg.exe -i "####.avs" -framerate 23.976 -aspect 16:9 -dc # -g 12 -maxrate 7500k -q:v 2 -b_strategy 2 -brd_scale 2 -bf 2 -profile:v 4 -pass 1 -passlogfile ffmpeg -an -f mpeg2video pass1.m2v
ffmpeg.exe -i "####.avs" -framerate 23.976 -aspect 16:9 -dc # -g 12 -lmin 0.01 -mblmin 1 -qmin 1 -qmax 31 -maxrate 7500k -b:v ####k -bf 2 -pre_dia_size 5 -dia_size 5 -qcomp 0.7 -qblur 0 -preme 2 -me_method dia -sc_threshold 0 -sc_factor 4 -bidir_refine 4 -profile:v 4 -mbd rd -mbcmp satd -precmp satd -cmp satd -subcmp satd -skipcmp satd -pass 2 -passlogfile ffmpeg -an -f mpeg2video pass2.m2v
But this is just a thought for the back burner.
Old 7th November 2013, 07:01   #2349  |  Link
manolito
manolito's Avatar
Faster... no
Wow, your command line for the second pass is really impressive! Also quite slow probably... And still no adaptive matrix, no auto GOP adjustment. Requires extensive tests to determine which decoder has the edge at these low bitrates...
For me whenever I am not happy with low bitrate encodes, usually Procoder does the trick. Not that sharp, but very pleasant to watch.
Cheers
manolito
Old 7th November 2013, 07:21   #2350  |  Link
Fishman0919
Cheers
manolito
Slow... kinda Yes... about 40-45fps on my PC... where HC is about 65fps. not to bad if you remove "-mbd rd" but with somewhat of a drop in quality... about 50fps.
adaptive matrix... No... never looked into setting it.
auto GOP adjustment... Yes.
I was a Procoder fan for low bitrates, but i liked the ability to change what I wanted with ffmpeg. I believe it delivers as good of, if not better then, quality.
This was just a quick 2-pass sample that looks pretty good.
Old 7th November 2013, 20:55   #2351  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@netmask
see Help/FAQ/Subtitles/Q5.7 :sorry:
@Fishman0919
good point, FFmpeg is making big improvements in latest releases. Does Hank have to be worried?
What about adding an easter egg (a registry subkey under AVStoDVD main key) to swap HCenc 2-pass with FFmpeg 2-pass? Encoding profile label will remain HCenc 2-pass, but FFmpeg will be launch instead.
Bye
MrC
AVStoDVD Homepage
Old 8th November 2013, 04:14   #2352  |  Link
Fishman0919
@netmask
@Fishman0919
Bye
Sure.
I like ffmpeg for long...... movies. 2 1/2 hrs where the bitrate can get down to around 3500k or lower.... ffmpeg seems to do well when/where HC may not.
Old 9th November 2013, 11:14   #2353  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Release 2.7.3 Alpha 131108 is out. For testing purpose only!
Change log:
- Some bugs fixed
- Added 'Preferred DirectShow Codecs Setup' section
- Added SetACL 2.0.3.0 (LGPL by Helge Klein) to AVStoDVD package
Feedbacks on Codecs selection new section (for Win7/8) are very appreciated.
Bye
MrC
AVStoDVD Homepage
Old 10th November 2013, 06:02   #2354  |  Link
manolito
manolito's Avatar
Tested the 2.7.3 Alpha version a little bit under WinXP (I know this will not help you a lot...) just to see if there are any incompatibilities.
Clicking every option on the new DirectShow Codecs selection page resulted in the expected error messages. But so far no damage was done, FilMerit cannot find any inconsistencies in my DS Filter chain. Very cool...
At the bottom of this codec selection page there is a link to the Win7 filter tweaker tool. This link is hardcoded to use IE. Bad... Could you change this to use whichever browser is defined as the default browser?
One minor cosmetic thing:
Somehow you must have reduced the width for this item in the main program window:
140020 AviSynth FrameServing-Test des Titels zur Laufzeit ausführen
The translated text does not fit any more, a line break is introduced. Peanuts...
Cheers
manolito
Old 10th November 2013, 12:06   #2355  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@manolito
thanks for the quick feedback! Very appreciated, as usual. The retro compliance with XP is very important. I still have a XP Virtual Machine, but a regularly used OS is a different stuff.
About the default browser, I check the following reg key
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.htm\OpenWithList
On my systems (both Win7 and XP) that key returns FIREFOX.EXE. If the read routine fails for any reasons, it falls back to IEXPLORE.EXE.
About the checkbox label width, I will enlarge it again.
Bye
MrC
AVStoDVD Homepage
Old 10th November 2013, 13:17   #2356  |  Link
manolito
manolito's Avatar
I think you are using the wrong reg key. On my computer I have SRWare Iron set as my default browser, but the reg key you are checking will return IE.
IMO you should check this key instead:
"HKEY_CLASSES_ROOT\http\shell\open\command"
The "Default" entry contains the default browser (at least on my XP SP3 machine).
Cheers
manolito
//Edit//
Maybe this key is more "correct" for a multi-user OS:
"HKEY_CURRENT_USER\Software\Classes\http\shell\open\command"
Old 11th November 2013, 06:40   #2357  |  Link
Fishman0919
Change log:
- Some bugs fixed
Bye
On Win 8.1 Pro I get an endless loop when trying to change mpeg1 support from "Microsoft" to "ffshow".
Click "ffshow", "change yes or no" then error... back to "change yes or no" and continues to repeats no matter what I pick.
http://i467.photobucket.com/albums/r...pse8d210d9.jpg
Old 13th November 2013, 14:17   #2358  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@manolito
good point, I will add that key as primary check, the currently used as backup.
@Fishman0919
thanks for the loop bug report. Easy to fix.
Does the error 'Preferred Codec NOT updated' happen only on mpeg1 codec or on all codecs?
Bye
MrC
AVStoDVD Homepage
Old 14th November 2013, 05:58   #2359  |  Link
Fishman0919
@manolito
@Fishman0919
Bye
All of them.
Old 14th November 2013, 09:56   #2360  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
All of them.
I assume you are administrator of your Win8 system, aren't you?
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
