Old 10th September 2019, 19:39   #3521  |  Link
Jukus
Originally Posted by jackoneill View Post
There is some documentation: http://www.vapoursynth.com/doc/
Thank you, I know. But I'm interested, for example, the sequence of applications of filters, I think it is not always obvious. Changing the brightness and color need before QTGMC or after, maybe there is no difference? And other nuances of video processing that I don't know about.
Jukus is offline   Reply With Quote
Old 10th September 2019, 23:18   #3522  |  Link
MeteorRain
結城有紀
That sounds a bit more than a guide, but more of lesson(s) (of being an encoder).
QTGMC is a deinterlacer so it always comes at early stage (probably after delogo, but that depends also.)
And to us, we never change brightness and color of a mastered work (e.g. when backing up bluray discs). But if it's your own recording, things can be a lot different.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 12th September 2019, 04:09   #3523  |  Link
stax76
stax76's Avatar
I've been studying some tutorials at realpython.com and noticed the tutorial and vs code format code like so:
def foo(a=1, b=1):
foo(a=1, b=1)
In staxrip there is much avs/vs code that use spaces:
def foo(a = 1, b = 1):
foo(a = 1, b = 1)
What is more common? Is both OK or is one officially discouraged and what about AviSynth?
Old 12th September 2019, 08:29   #3524  |  Link
ChaosKing
This looks like the official style guide https://www.python.org/dev/peps/pep-0008/
Seems like def foo(a=1, b=1, ...) is recommended.
Old 12th September 2019, 08:51   #3525  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
def foo(a=1, b=1):
foo(a=1, b=1)
foo(a = 1, b = 1)
Use whatever you like as long as you're consistent.
Old 13th September 2019, 15:58   #3526  |  Link
aegisofrime
Gonna post this here as I don't think it deserves it's own thread, but what happen to Stephen R. Savage's post about his optimized MVTools?
aegisofrime is offline   Reply With Quote
Old 13th September 2019, 16:16   #3527  |  Link
Myrsloik
Myrsloik's Avatar
It got merged into normal mvtools and will be in the next release.
Old 18th September 2019, 13:20   #3528  |  Link
ChaosKing
Does get_read_array() return only "video data" without "meta data or something"?
I was comparing different source filters (ffms2, d2vsource, lsmash, dgdecnv) and noticed something strange with VOB files. I save every hash in a list. If the video file passes the "seek-test" the hashes of every source filters should the same. This was the case with many files.
But for vob files the hashes differ with every source filter. Is there something special with VOB files? I mean they can only be decoded in "one correct" way, right? They look all ok in vsedit...
example log
Seek linear order (hash, PicType, n-Frame)
d653d648d8e6407e507c6eaa0116ebe5 I 0
30ad6c41b89dfd8880a12bde6952e7b2 B 1
5e0cb8bad4ba2ec37b4f4db0d4a65691 P 2
#from seek-test.py
def hash_frame(frame):
    md5 = hashlib.md5()
    for plane in range(frame.format.num_planes):
        for line in frame.get_read_array(plane):
            md5.update(line)
    return md5.hexdigest()
Old 18th September 2019, 13:47   #3529  |  Link
Myrsloik
Myrsloik's Avatar
example log
#from seek-test.py
    md5 = hashlib.md5()
            md5.update(line)
It's not strange at all. It wasn't until h.264 the standard required (or even specified for that matter) how the DCT transforms should be done in a bit exact manner.
Old 18th September 2019, 13:54   #3530  |  Link
ChaosKing
Aha, ok good to know.
Old 18th September 2019, 14:17   #3531  |  Link
Jukus
What is the difference between ffms2 and lsmas?
I already realized that for mpeg 2 need to use only d2v.
Old 18th September 2019, 15:31   #3532  |  Link
ChaosKing
Both are based on ffmpeg. In addition lsmash has GPU support and can open MP4, MOV, ISO Base Media without creating an extra index.
From experience I would say lsmash is more often frame accurate then ffms2.
Old 18th September 2019, 22:13   #3533  |  Link
Jukus
How to specify the path to create the index file for ffms2 and lsmas? That is, if I mount the ISO, then I can not write anything in the same directory.
Old 18th September 2019, 22:43   #3534  |  Link
ChaosKing
It's all explained in the readme https://github.com/FFMS/ffms2/blob/m...ynth.md#source
ffms2.Source("video.mp4", cachefile="video.mp4.ffindex")
I think lsmash does not support a custom cache file path.
EDIT
Seems to be supported https://github.com/HolyWu/L-SMASH-Wo...er/VapourSynth
cachefile (default : source + ".lwi")
                    The filename of the index file (where the indexing data is saved).
Old 19th September 2019, 19:36   #3535  |  Link
Jukus
@ChaosKing
Unfortunately, it’s still not clear how this should work, can a specific example be provided?
Old 19th September 2019, 19:41   #3536  |  Link
ChaosKing
@ChaosKing
import vapoursynth as vs
core = vs.core
clip = core.lsmas.LWLibavSource(source=r"D:\video.mkv", cachefile=r"C:\folderxy\myCacheFile.iwi")
clip.set_output()
Old 19th September 2019, 19:47   #3537  |  Link
Jukus
@ChaosKing
vapoursynth.Error: LWLibavSource: Function does not take argument(s) named cachefile
Old 19th September 2019, 19:56   #3538  |  Link
ChaosKing
@ChaosKing
Use this version https://github.com/HolyWu/L-SMASH-Works/releases
Old 19th September 2019, 20:19   #3539  |  Link
Jukus
Ok, thanks. But is it possible to make an index without Vapour, as it is done for d2v?
Old 19th September 2019, 20:29   #3540  |  Link
ChaosKing
Only ffms2 has an indexer: ffmsindex.exe
Latest version: https://forum.doom9.org/showthread.p...05#post1883905
speed, vaporware, vapoursynth
