22nd July 2010, 12:46 | #8261 | Link | |
22nd July 2010, 12:50 | #8264 | Link |
@RottenNecro
Why don't you send me 50-100 mb sample to www.mediafire.com. Use DGsplit.
22nd July 2010, 12:54 | #8265 | Link | |
22nd July 2010, 13:08 | #8267 | Link |
Without physical (source) sample we can't help you.
22nd July 2010, 14:03 | #8268 | Link |
Hi all,
I was just wondering ;-) Does ripbot have the ability to create two audio streams? I'd like to convert a movie from one of my blu-rays to 720p mp4 so I can play it on both my PS3 and iPad. Unless both the PS3 and iPad supports 5.1 AAC? If not I'd have to use 5.1 AAC for the PS3 and 2.0 AAC for the iPad. The reason for me posting this question is that I don't get the iPad till next week so can't test it. Thanks |
22nd July 2010, 20:56 | #8270 | Link |
Should I have xvid decoded by xvid or libavcodec in ffdshow video decoder config?
Could you tell me what I should have set for Other MP4, Raw Video (it's disabled at the moment - Should it be set to YV12?) VC1 (set to wmv9 at the moment) H.264/AVC (set to ffmpeg-mt). Would really appreciate the help. Last edited by RottenNecro; 22nd July 2010 at 21:00. |
23rd July 2010, 02:21 | #8272 | Link |
Hi, first off great program, nice and easy and gives awesome quality..
I have a problem though and a few questions I hope some one can help me with, sorry if its been gone over before, 400+ pages is a bit much to go through Ok, I cant use the denoise filter at all, every time I select Film or Ani the preview wont work (just gives a blank screen in MPC, and the movie wont encode (click start and it says done after a couple of seconds with no error) Obviousy with some blurays being a little noisey having this filter would be nice. If I turn the filter off it all works fine. And why cant we select 640 kbps 5.1 audio with MP4 ? can with the other options like MKV etc.. can only pick 320 kbps 5.1 for some reason. Am unsure of the quality difference but im guessing it would be a bit. And last question, what file size should I be aiming at ? I know that depends on a lot like the movie time etc.. but with 1.5 hour movies I get around 5800 KBPS when I set the size at 4gig for converting blurays to 720p MP4.. is this over kill ? can anyone tell me what KBPS I shouldnt go under ? like would 2400 KBPS give the same quality ? Just wondering if it was overkill and I might be able to fit 2 movies on a dvd instead of just one. Thanks for any help with the above. |
23rd July 2010, 05:09 | #8273 | Link |
@atak;
I've got and installed my Western Digital SSD drive 128GB!!!! Installed windows 7 took about 17 minutes! I install all my softwares and updates and will be back soon!! I can't wait to see if ssd can help a little bit for conversion issue. I don't think it makes a differences, it's the processor and overall windows used loaded thru the processor, but if hard disc save time of seeking for his files, it can help a little bit for a couples of processes.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 23rd July 2010 at 07:17. |
23rd July 2010, 07:22 | #8274 | Link | |
It's what i do. Sometimes, when DTS tracks, before- project is done, i convert it with eac3to GUI to AC3 640 and calculate before starting the project. after project finsished, i took the m2ts converted and add the other language and remuxed in a new folder. DTS = 8125MB - other language size = conversion size and approximate to 25,50,75 mb ex. (7125mb, 6050mb etc). They have HDConvertToX offer multiples languages, but a little more complated to use then ripbot264. I prefer ripbot264 because i've got better conversion quality and less brain pain for getting worked thoes softwares. Ripbot264 is so easy and great to work. Also, atak offer great support with many members here helping peoples. *sorry for bad english* ;-p
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 23rd July 2010 at 07:25. |
23rd July 2010, 10:30 | #8275 | Link | |
And that's why I wanted to use RipBot for my little project over here. I love this GUI but for me there are some features missing! |
23rd July 2010, 11:15 | #8276 | Link | |||
23rd July 2010, 13:29 | #8277 | Link | |
More infos here |
23rd July 2010, 15:27 | #8278 | Link | |
Cheers. |
23rd July 2010, 16:41 | #8279 | Link |
This GUI is great. Much faster and easier to use than AutoMKV and a few others I've tried.
I've had no real issues with it yet, once I familiarized myself with it. One thing I have noticed, MKV to MKV conversion is not very fast, as opposed to AVI/MP4 to MKV. Aside from that, this is the best GUI around. I've converted about a dozen films so far, and only had trouble with one, but that was my fault. Also, I've had better results using the 2-pass method. The CQ works well, but the 2-pass is better quality for me. |
23rd July 2010, 18:57 | #8280 | Link | ||
