11th January 2012, 07:18 | #10501 | Link |
Atak, I will try and get something to you in a couple days as I will be out of town until Thursday evening. I will need to encode a new test subject and then clip out the problem. As for source, well, I am not sure if there is some correlation or not. I have tried both VC-1 and AVC with equal effect.
11th January 2012, 08:44 | #10502 | Link |
I have the latest RipBot and find it useful for converting mkvs that will not play on my TV that plays MKV from USB - I guess the TV just a bit too fussy with some MKV settings.
Anyway, it works perfectly except for one file where I get Exception EConvertError in module RipBot264.exe at 000093E2, "is not a valid floating point value. Previous versions did not report this error and simply hung gathering information. The file seems to be normal and plays correctly apart from the TV with built-in mkv player. The frame size maybe causing the problem as it is 1802x1080. The correct aspect ratio in this case 1.75:1, so it probably should be 1890x1080. First though, I need to open the file in RipBot264. Any help would be appreciated. |
11th January 2012, 09:13 | #10503 | Link | |
Practising Schemer
11th January 2012, 11:46 | #10504 | Link | |
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 16 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 27mn Bit rate : 5 170 Kbps Width : 1 802 pixels Height : 1 080 pixels Display aspect ratio : 1.669 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.111 Stream size : 3.09 GiB (71%) Writing library : x264 core 112 r1834 a51816a Encoding settings : cabac=1 / ref=16 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=5170 / ratetol=1.0 / qcomp=1.00 / qpmin=2 / qpmax=41 / qpstep=2 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Language : English Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 |
11th January 2012, 11:52 | #10505 | Link |
why did you encoded your file at such bizzare resolution????
11th January 2012, 12:43 | #10507 | Link |
where did you get that file?
12th January 2012, 01:05 | #10510 | Link |
Do we have to use CQ for distributed encoding or can we use 2 pass encoding as well? I'm trying to get distribution going but when I connect to the second computer; it keeps saying Encoding Started... and then like 5 seconds later it says Encoding Terminated... Doesn't seem to want to send the data over to the second computer
*EDIT* Okay for people having issues where encoding goes from Encoding to Idle: 1. Both computers MUST BE IN THE SAME HOMEGROUP(for some reason it doesn't work if it's not) 2. Check that both O/Ses run the same Bit version (i.e. if one of your computers is 32bit and your hosting server is 64bit, you will have to force the 64 bit server to use the 32bit version of x264) Last edited by james2432; 12th January 2012 at 04:13. |
12th January 2012, 11:29 | #10511 | Link |
1. did you use updatd files from soneca's post? what happens if you share ripbot264temp folder with Guest (READ/WRITE) instead of EVERYONE?
12th January 2012, 13:20 | #10512 | Link |
Yes I tried the update, no I did not try Guest, but I did have everyone read/write
also when I tried 2-pass encoding on sequence 5 it said invalid first frame (empty) and kept looping and the sequence before that only processed 1 out of 14400 frames, so far CQ is working |
12th January 2012, 13:22 | #10513 | Link |
Basically ripbot264temp folder MUST be accessible for all computers . You can manually check if you can see content of ripbot264temp folder via explorer.
12th January 2012, 13:25 | #10514 | Link | |
http://www.mediafire.com/?4znoczfey7m7b63
12th January 2012, 16:20 | #10515 | Link |
im getting this in some cases:
eac3to v3.24 command line: "...\RipBot264v1.17.0\Tools\eac3to\eac3to.exe" "X:\..." 1) 2: "X:\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 4: "X:\Temp\RipBot264temp\job1\audio_German.thd.w64" -down16 1: "X:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="X:\Temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 8 audio tracks, 29 subtitle tracks, 1:37:59, 24p /1.001 1: Chapters, 16 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48kHz (embedded: AC3, 5.1 channels, 448kbps, 48kHz, dialnorm: -29dB) 4: TrueHD/AC3, German, 5.1 channels, 48kHz (embedded: AC3, 5.1 channels, 448kbps, 48kHz) Creating file "X:\Temp\RipBot264temp\job1\chapters.txt"... [a04] Extracting audio track number 4... [a04] Extracting TrueHD stream... [a04] Decoding with libav/ffmpeg... [a04] Reducing depth from 24 to 16 bits... [a04] Writing W64... [v02] Extracting video track number 2... [v02] Muxing video to Matroska... [a04] Creating file "X:\Temp\RipBot264temp\job1\audio_German.thd.w64"... [v02] [1:18:56] The source file seems to be damaged (sync byte missing). <WARNING> [v02] [1:18:56] The source file seems to be damaged (discontinuity). <WARNING> [a04] [1:18:55] The source file seems to be damaged (sync byte missing). <WARNING> [a04] [1:18:55] The source file seems to be damaged (discontinuity). <WARNING> [a04] This track is not clean (2). <WARNING> [a04] [1:18:56] The source file seems to be damaged (sync byte missing). <WARNING> [v02] [1:18:57] The source file seems to be damaged (sync byte missing). <WARNING> [a04] [1:18:56] The source file seems to be damaged (discontinuity). <WARNING> [a04] The libav decoder reported error -1 while decoding. <ERROR> Aborted at file position 21596471296. <ERROR> Is the Source realy damaged or is it a bug of Ripbot ? Last edited by Goldman; 12th January 2012 at 16:38. |
12th January 2012, 16:39 | #10516 | Link |
Try with CORE
12th January 2012, 17:00 | #10517 | Link |
I am curious, has anyone actually looked at their encodes thoroughly after using distributed encoding? I didn't and only realized after doing numerous movies that they each had glitches in different 10 minutes spots. I find it hard to believe that I am the only person with the problem, but then again nothing would surprise me.
12th January 2012, 17:03 | #10518 | Link |
