14th May 2017, 05:10 | #4301 | Link |
What you mean "not working" ??
14th May 2017, 07:11 | #4302 | Link |
@S3Ri0US
GTX980TI does not have a full-fledged HEVC decoder. Therefore, you have problems with playing HEVC 4k with hardware acceleration. The second file can not be decoded on a video card, so the CPU is always used here. To understand the reason, you need to look at the statistics (Ctrl+J) and the task manager.. Possible reasons: there is not enough CPU power, one of the CPU cores is overloaded, there is not enough video memory for the built-in GPU.
14th May 2017, 10:56 | #4303 | Link | |
Ok thanks ! but both files have the same codec ? HEVC
14th May 2017, 12:03 | #4304 | Link |
@S3Ri0US
There is a very significant difference. Code:
ColorSpace : YUV ChromaSubsampling/String : 4:2:0 BitDepth/String : 8 bits Code:
ColorSpace : YUV ChromaSubsampling/String : 4:2:2 (Type 2) BitDepth/String : 10 bits
19th May 2017, 20:37 | #4305 | Link |
Wasapi exclusive mode doesn't release audio device
Using 1.5.1 beta, built-in Wasapi exclusive mode doesn't release audio device, only if I close the player (e.g. winamp can't play audio via directsound output).
- sound device: Primary Sound driver - wasapi mode: Exclusive - allow bit exact output: checked (although it doesn't matter regarding to this problem) - sync method: sync audio to video It doesn't matter whether video file includes bitstreamable audio (e.g. AC3) or decodeable audio (e.g. aac). It doesn't releases it when: - playback ends (same with Sanear) - playback stopped with stop button (Sanear release it) - playback paused with pause button (Sanear states that it should release it but it only works with decodeable audio but not with bitstreamable ones) Thanks, guys!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 19th May 2017 at 21:57. |
20th May 2017, 02:11 | #4306 | Link | |
20th May 2017, 12:31 | #4307 | Link |
Playback or player? If playback, how did you close playback?
For me only release it when you close the player. No worries about the rest
20th May 2017, 13:29 | #4308 | Link |
20th May 2017, 16:18 | #4310 | Link |
Trying to figure out this. I'm on a full hd monitor 1920*1080. Now, i've two videos, same resolution, not full hd. One has letterbox, the other doesn't, and it's enlarged on all monitor area. Why this? Can i solve?
Ex. a video 720*304 has letterbox, and it's ok because i think it's not stretched. Another video 720*404 has no letterbox and it seems stretched. If i use 'Normal' in video frame, the video is not stretched and is displayed to it native resolution, in the middle of the screen. So i think all video are always stretched, but why the difference in letterbox?
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 20th May 2017 at 16:25. |
20th May 2017, 16:43 | #4311 | Link |
@steakhutzeee
1. Check the layout mode of the frame. The default should be - View->Video Frame->Touch Window from Inside. 2. Check the aspect ratio of the video frame - File->Properties->MediaInfo
20th May 2017, 20:43 | #4313 | Link |
@steakhutzeee
2. I repeat. This is called the aspect ratio of the frame.
21st May 2017, 05:34 | #4315 | Link | |
To fill any monitor without croping the frame, use "Strech to Window".
23rd May 2017, 07:15 | #4316 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 24th May 2017 at 02:02. |
24th May 2017, 12:36 | #4317 | Link |
Hello,
I'm not sure if MPC-BE is even concerned by this but it's better to ask i guess : http://blog.checkpoint.com/2017/05/2...n-translation/ https://torrentfreak.com/malicious-s...s-warn-170523/ Thank you. Last edited by Yanak; 24th May 2017 at 12:45. |
25th May 2017, 16:30 | #4318 | Link |
Yanak
I think it is not necessary to report VLC vulnerabilities in this topic. Answer: https://trac.mpc-hc.org/ticket/6169
26th May 2017, 02:28 | #4319 | Link |
yes sorry , also asked in MPCHC thread after asking here and got the answer there , forgot to report back here, sorry for that . It ain't only a vlc problem, most articles published on the first day mentioning multiples media player affected, i just wanted to be sure and asked ... Sorry for the disturbance and thank you for your great media player. |
26th May 2017, 19:09 | #4320 | Link | |
With both bitstreamable audio (e.g. AC3) and decodeable audio (e.g. aac), now it releases the audio device when: - playback ends - playback stopped with stop button - playback paused with pause button !!!! Thanks so much! And please let me know if this feature will be available in a nightly (I'm using the x64 version). And I love the mute feature as well!
