5th December 2015, 22:51 | #4841 | Link |
I was just able to index and load an MKV with the new L-SMASH Source. But I have all MSVC runtimes installed. I collected them once with WSUS Offline Update...
6th December 2015, 02:11 | #4843 | Link | |
Am I missing anything? I wish I could use FFMSindex but apparently every time I extract the package, there's a virus in it according to my anti-virus software. |
6th December 2015, 10:02 | #4844 | Link |
OK, all runtimes installed, that's not the reason. So it may be the UAC or some other issue with the dynamic build of LSMASHSource.dll not being able to load its libav component DLLs. I believe Zathor will try to prefer a static build for the next update.
6th December 2015, 21:41 | #4847 | Link | ||
https://www.dropbox.com/sh/3i81ttxf0...VhYLasmwa?dl=0 Dynamic build maybe because of: https://github.com/VFR-maniac/L-SMAS...1ed95be9a8a233 Quote:
Because of this I have reverted a few hours ago L-SMASH in MeGUI so that agin r804 is used. Last edited by Zathor; 7th December 2015 at 18:16. |
8th December 2015, 03:31 | #4852 | Link |
https://en.wikipedia.org/wiki/Heuristic_analysis
Maybe the software has a setting for it's "taking a guess" level you could dial back a bit. |
8th December 2015, 10:48 | #4854 | Link |
You are never sure (and not secure either). With or without AV software. If you don't trust first-hand sources of your software, then don't trust AV heuristics either.
You can check more heuristics at virustotal and malwr, and if the number of suspicions is low, the probability of a false alarm is high. In this case, send a sample to your AV author to have this false alarm removed. |
8th December 2015, 19:41 | #4855 | Link |
I wanted to recompress video with Blindehalo3 filter using MeGui.
LoadPlugin("C:\Program Files\Avisynth 2.5\plugins\masktools2.dll") LoadPlugin("C:\Program Files\Avisynth 2.5\plugins\RgTools.dll") Import("C:\Program Files\Avisynth 2.5\plugins\BlindDeHalo3_mt2.avs") BlindDeHalo3( 3,3,125 ) I've checked the path like ten times, so everything is in right place. And every time MeGui give me some error: Unable to Load "C:\Program Files\Avisynth 2.5\plugins\RgTools.dll", module not found But it's there. If I remove that line from the script, I get following error: Invalid arguments to function Blinddehalo3 If I remove that line I get this: The script's returns was not a video file. Any suggestions? Just for clarification: I've never used MeGui before. |
8th December 2015, 21:44 | #4856 | Link |
Where is your source filter? You never loaded any video to be filtered.
Not being able to load a plugin ... are all necessary compiler runtimes installed? And check if you don't try to load an AviSynth 2.6+ plugin in AviSynth 2.5.x; try if it works if you enforce MeGUI using its internal AviSynth copy, instead of the version installed in your system. Usually it is helpful to publish a log file of such a failed attempt. Last edited by LigH; 8th December 2015 at 21:47. |
9th December 2015, 04:23 | #4857 | Link | ||
According to the info here, Avisynth 2.6 or higher is required for RGTools. MeGUI currently uses Avisynth 2.6.0.6 for it's portable version. Did you download the 64 bit version of RGTools instead of the 32 bit version? Maybe try Avisynth Info Tool. Quote:
BlindDeHalo3(3.0, 3.0, 125) or BlindDeHalo3(rx=3.0, ry=3.0, strength=125) Mind you those values appear to be the defaults, so you'd get exactly the same result with this: BlindDeHalo3() Last edited by hello_hello; 9th December 2015 at 04:51. |
10th December 2015, 16:51 | #4858 | Link |
Informational only.
Just got 'Unclassified Malware' alert from Comodo Internet Security for ffmsindex.exe (updated MeGUI development, earlier today) . I've submitted as false +ve to Comodo. Here, results from Virustotal today:- https://www.virustotal.com/en/file/a...is/1449762152/ EDIT: Anyone who would like to give opinion to VirusTotal can vote on their Votes TAB.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 10th December 2015 at 17:01. |
10th December 2015, 19:47 | #4859 | Link |
Very interesting that it gets detected as "Downloader", but I doubt a pure file indexer uses any networking functions. Maybe except UNC file access? Or unused functions in a bigger linked library?
P.S.: malwr / Cynomix Last edited by LigH; 10th December 2015 at 20:36. |
10th December 2015, 21:01 | #4860 | Link | |
Probably just part of some library as LigH suggests.
