24th October 2020, 16:12 | #1121 | Link |
Big Bit Savings Now !
Many thanks ! MPC-HC is still my first player of choice, followed by MPC-BE.
24th October 2020, 17:17 | #1122 | Link |
Because it is used in MPC-HC: Be aware of the RIAA takedown of the original youtube-dl repo on github; there is a fork: yt-dlc.
26th October 2020, 02:35 | #1124 | Link |
EDIT: SOLVED. For any Googlers searching for a fix, here is what fixed it for me. In the nVidia Control Panel, navigate to Manage 3D Settings and set "Vertical sync" to On.
Had anybody else had the following issue and know of a fix? I'm running the lastest version of MPC-HC with madVR 113 and the latest LAV filters. When attempting to play a 4K video in full screen I'm seeing intermittent frame drops that are not recorded by the madVR debug OSD. But as soon as I bring up a context menu or play in a window, playback is perfectly smooth. I'm not running madVR in fullscreen exclusive mode. The same madVR and LAV filters settings in Kodi 17.7 with DSPlayer is perfectly smooth. Some specs: Geforce RTX 2070S Latest nVidia drivers Windows 10 w/ latest updates Desktop 3840x2160, YCbCr 422 @ 10bit 16GB RAM
My HT: JVC X790R | 120" CineWhite | madVR 169 RTX 2070S | mpv 0.36.x | UB420 | Denon X3600H @ 5.2.4 | Totem Tribe | 4 x ADX Maximus w/ Dayton Audio SA230 | 40" HDTV w/ MoviePosterApp Last edited by *MidnightWatcher*; 28th December 2020 at 06:48. |
27th October 2020, 15:35 | #1127 | Link |
Already on adaptive.
My HT: JVC X790R | 120" CineWhite | madVR 169 RTX 2070S | mpv 0.36.x | UB420 | Denon X3600H @ 5.2.4 | Totem Tribe | 4 x ADX Maximus w/ Dayton Audio SA230 | 40" HDTV w/ MoviePosterApp |
27th October 2020, 16:04 | #1128 | Link |
It is not a bug in MPC. Similar issues also happen in other apps and with Intel/AMD, so most likely bug in Windows 10 or a driver.
Another thing you can try is to disable fullscreen optimizations in the Windows compatibility settings for MPC. Also use LatencyMon to check for DPC latency issues caused by drivers. |
27th October 2020, 19:09 | #1129 | Link |
Hello.
I'm trying to figure out what "ctrl+3" called "Information" function offers. I could be blind but I can't see anything after I select this option.
27th October 2020, 19:36 | #1130 | Link | |
cosmic entity
hey there,
can anyone confirm this or knows whats going on? Thanks.. Quote:
27th October 2020, 19:56 | #1131 | Link |
Something Else
No idea on how to solve this problem but I can confirm it happens on my end but using MPC-BE with the 456.71 drivers. It is annoying because my screen blanks twice rather than once when I open an HDR video and again when I close it.
27th October 2020, 21:10 | #1133 | Link |
This issue has nothing to do with MPC-HC or any player, actually. It is well known at this point and has been around for a while. See here: https://forum.doom9.org/showthread.php?t=176013
27th October 2020, 21:15 | #1134 | Link | |
cosmic entity
28th October 2020, 04:06 | #1135 | Link |
Something Else
It seems that the 20H2 windows update has nullified that problem since I installed it 30 minutes ago. When I now play content that matches or is divisible by my refresh rate (96hz) it does not do that silly bullocks anymore......what a result. Is it the same for you BetA13?
1st November 2020, 17:45 | #1136 | Link |
Is there any chance to see a "flybar" similar to that of mpc-be? https://i.imgur.com/0q0Z9Hh.png
2nd November 2020, 11:54 | #1138 | Link |
Good morning,
I have a question, please, about the ways mpc-hc can be programatically controlled. For instance, mpv supports, on Windows, JSON IPC through a named pipe, making it possible to write wrappers to extend its capabilities (for UPnP support as a DLNA renderer for example). I have spotted that mpc-hc offers a rather elaborated web interface, and investigated the javascript codes tied to the different web pages, but all I have found relies on HTTP requests. In particular, the update of the display of the status of the player is realized through polling (statusLoop function) if I understand correctly how the script works (I am far from mastering this language). Does that mean that there is no eventing management nor websocket support ? Thanks in advance for any indication. |
2nd November 2020, 16:12 | #1139 | Link | |
https://github.com/clsid2/mpc-hc/tre...src/MPCTestAPI
