6th September 2020, 20:14 | #225 | Link |
Updated AddGrain, CTMF, DFTTest, & ZNEDI3. DFTTest r7 does not work on Sierra or High Sierra & I do not have a test machine with Mojave, so it's possible it only works on Catalina or higher. These are the last plugins I had on my list that were out of date. If there are any other plugins out there feel free to link them here and I can look into them. Here is the updated list of plugins I've looked into that are not currently available:
bilateralgpu - Depreciated DGMVSource - Windows Only MVTools-Float - Needs C++2a vcm - Windows Only vcfreq - Windows Only VSFilterMod - Windows Only waifu2x-w2xc - Depriciated xy-VSFilter - Windows Only Last edited by l33tmeatwad; 7th September 2020 at 23:09. |
6th September 2020, 20:45 | #226 | Link |
Waifu2x-ncnn-vulkan
Last updated Jul 2020 https://github.com/Nlzy/vapoursynth-waifu2x-ncnn-vulkan Waifu2x-caffe Last updated March 2020 https://github.com/HomeOfVapourSynth...-Waifu2x-caffe Thanks meatwad |
6th September 2020, 22:00 | #227 | Link | |
7th September 2020, 23:08 | #230 | Link |
Revisited compiling IT direct from source without modifying it to be compatible with older version of macOS. It does work, however it uses aligned_alloc which is introduced in Catalina so it will not be compatible with older versions of the OS.
8th September 2020, 00:43 | #231 | Link |
Thanks meatwad
Is this available? https://github.com/dubhater/vapoursynth-awarpsharp2 Because it is a must, when upscaling 80s animation.. Last edited by AdamCarter; 8th September 2020 at 08:27. |
9th September 2020, 01:48 | #232 | Link |
Waifu2x-ncnn-vulkan is now available, you will have to install the Vulkan SDK for it to work. As with any GPU based plugin, performance & stability will vary based on your system.
9th September 2020, 16:55 | #234 | Link |
Finally got around to testing tc2cfr & VFRtoCFR, both load, however tc2cfr does not appear to recognize any files as a valid Timecode V1 files so I have removed it for now. The original copy of VFRtoCFR was actually corrupted so it has been replaced with a working version.
11th September 2020, 15:23 | #235 | Link |
Event though it is considered depreciated/obsolete by the developer, I went ahead and compiled Waifu2x-w2xc and the download also includes waifu2x-converter-cpp. The main reason was due to the CUDA support for older machines with NVIDIA cards, however I was unable to test that portion. If you have a newer machine I would recommend waifu2x-ncnn-vulkan instead as it is twice as fast as this plugin.
12th September 2020, 08:07 | #237 | Link |
Small question: Does someone have list of all the direct download paths for the latest plugins?
I would like automate the download and extraction of the plugins with something like: Code:
curl http://download1477.mediafire.com/qcddf8lnv8zg/4s0vfvl5ql8e2oz/AddGrain-r8.tar.gz | tar -xz The simple idea is to put all those links in a simple shell script to download and extract them into the current directory. Last edited by Selur; 12th September 2020 at 09:24. |
12th September 2020, 09:33 | #238 | Link |
I think this will only work for a while as you need the pro version for direct links.
But there is downloader you can try which worked very good for me https://github.com/pythonoma/mediafire-dl EDIT repo with latest fix https://github.com/gilcu3/mediafire-dl
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 12th September 2020 at 09:36. |
12th September 2020, 09:35 | #239 | Link |
Okay, here's a quick script:
#!/bin/bash urls=' http://download1477.mediafire.com/qcddf8lnv8zg/4s0vfvl5ql8e2oz/AddGrain-r8.tar.gz http://download1339.mediafire.com/bpplbdjmwydg/7xakbsoec4cld77/Anime4KCPP-2.3.0.tar.gz http://download1350.mediafire.com/bbchyqn3qt4g/uj90d1z2ped6xnr/ASharp-v1.tar.gz http://download939.mediafire.com/qm83ub9ov8fg/dfdpbdre81qz2p6/AutoCrop-0.1.tar.gz http://download1500.mediafire.com/mehafz1qlxeg/3jhrjb60c2o0b6a/aWarpSharp2-v4.tar.gz http://download942.mediafire.com/w0k4szandfpg/6a5mbrdyfu53r98/Bifrost-2.2.tar.gz http://download941.mediafire.com/9r97sxj4rz9g/30qqptntug4lnjd/Bilateral-r3.tar.gz http://download1590.mediafire.com/jvxjljqs8blg/l7bi7dqyso7ltxl/BM3D-r8.tar.gz http://download1649.mediafire.com/c246g6l483qg/rlnv03fe8u35cx5/Bwdif-r2.tar.gz http://download1653.mediafire.com/c34jup0z9apg/90t8zhq9mqoizlh/CAS-r2-%28macOS-10.15%2B%29.tar.gz http://download941.mediafire.com/wbboqr6bkmyg/dp37j6bx7mqbp61/CNR2-v1.tar.gz http://download1509.mediafire.com/8pmd7ab7dcpg/cfrbj6vqt4acnbj/ColorBars-R2.tar.gz http://download1583.mediafire.com/wfn7zsixddmg/7gktm7qlcrw4pfe/CombMask-1.1.0.tar.gz http://download1590.mediafire.com/achykynu19fg/h96228hwd8ulh9p/ContinuityFixer-v6.1.tgz http://download1499.mediafire.com/fdplkw8oshlg/4zdxtdhvyeg28pv/CTMF-r5.tar.gz http://download1484.mediafire.com/n133xg3ctv8g/wmupgaxuftfznjd/D2VSource-1.2.tar.gz http://download1583.mediafire.com/utwq2dwytpkg/nxduz47pe2egpf5/DCTFilter-r2.1.tar.gz http://download1646.mediafire.com/udkm86u49fhg/opi1rfkis45kt9v/Deblock-r6.tar.gz http://download1589.mediafire.com/i9zkbd21aiog/etc1et689lc6ay9/DeblockPP7-r4.tar.gz http://download944.mediafire.com/f3v6p5tvzgvg/ayr1w1fpil5l1mg/DeCross-v1.tar.gz http://download1654.mediafire.com/bwgptq96jlig/p3xe8mc9byq4dl4/Dedot-v1.tar.gz http://download1337.mediafire.com/djb4edityo9g/td9a6nve59ktbc3/DegrainMedian-v1.tgz http://download1589.mediafire.com/d3h178z25lug/j116js5ak6i7a45/DeLogo-v0.4.tar.gz http://download856.mediafire.com/ror4p36m7jog/r4rw1d55g87rnuk/DePan-r1.tar.gz http://download1649.mediafire.com/qjdpscfy4sfg/8lzjkgu27ee7ld2/Descale-r6.tar.gz http://download1327.mediafire.com/0wgupj3onlug/p0v6bdubf1sk00f/DFTTest-r7.tar.gz http://download1334.mediafire.com/w8ytfawzh3hg/hy2jg8d1ad6v2vy/DotKill-R2.tar.gz http://download1653.mediafire.com/9a4f9hhvodjg/amexapvkzl2j6t9/DPID-r4.tar.gz http://download1979.mediafire.com/ib2bqnhxx8yg/i845a4ju0vut4sr/EdgeFixer-r2.tar.gz http://download1652.mediafire.com/qc1483we81ng/j67ql11yzbasku6/EEDI2-r7.tar.gz http://download1507.mediafire.com/9evkxr3hj0lg/5eeloh7cz92b80w/EEDI3m-r4.tar.gz http://download1492.mediafire.com/urajw3ej38lg/ucf622ic18kutbi/FFMS2-2.40.tar.gz http://download941.mediafire.com/bsrzhel0c49g/bhzsdhk4ajbvg2t/FFT3DFilter-R1.tar.gz http://download943.mediafire.com/uhure2e3qfqg/yg9zw6rjccy517d/FieldHint-r3.tar.gz http://download941.mediafire.com/na36ccbcz9vg/w1aeawkebsal2iw/FillBorders-v1.0.tar.gz http://download1647.mediafire.com/takippffmhtg/8jlz0hxjqkabsyx/FTF-r5.tar.gz http://download1980.mediafire.com/0186qag7lahg/bbk5p5ej0ve8xw8/Flash3KyuuDeband-2.0.0-1.tar.gz http://download941.mediafire.com/0ctxhnxzd1qg/j54a54ana2qpk0j/FluxSmooth-v2.tar.gz http://download1073.mediafire.com/rpsgv4c2jh6g/5he9ce9gu5xp8o2/LibFocus-r4.tar.gz http://download1476.mediafire.com/j0qbhu4qfr4g/k471du5ywumuxk3/FmtConv-r22.tar.gz http://download855.mediafire.com/n95h6hrut17g/dtfg5ya7g02t7ya/GradCurve-170201.tar.gz http://download1980.mediafire.com/ybfm6mxrifog/n76k56rojqcb5tq/Histogram-v2.tar.gz http://download1592.mediafire.com/fxv1xl0fufjg/dmmzsxmw7htxmfv/HQDN3D-20180629.tar.gz http://download946.mediafire.com/gko1lia5hdkg/crfcgodu9xrme2u/IT-v1.2.tar.gz http://download1647.mediafire.com/tevkjy8wlrkg/prcybaizipt28rw/JincResize-r7.2.tar.gz http://download1503.mediafire.com/97aufz6fdxog/7g9n6ea93bkmg9v/KNLMeansCL-1.1.1.tar.gz http://download2283.mediafire.com/rvynpe5hpqpg/5ljjd5fwmq714tv/LGhost-r1.tar.gz http://download1502.mediafire.com/zhjatay6hrwg/23v8lfoc8hmyzgv/LSMASHSource-20200728.tar.gz http://download856.mediafire.com/5c08xj4mbckg/ls8r0jusdsp5s4v/MiniDeen-r1.tar.gz http://download1584.mediafire.com/oc1jfiur9r0g/ahoayzazsjoh698/MinSharp-r4-f90c5a7.tar.gz http://download942.mediafire.com/wk177q4539mg/yoy8h8b1u43urbu/MotionMask-v2.tar.gz http://download1518.mediafire.com/rbmm7w8s9ncg/5n4w4cu318qt3sn/MSmoosh-v1.1.tar.gz http://download1505.mediafire.com/neydysuwdp7g/031maaehwnks748/MVTools-v23.tar.gz http://download847.mediafire.com/b4e04ujrc0qg/tafv6pitkcjhjom/NNEDI3-v12.tar.gz http://download1482.mediafire.com/vl02d0ndj8vg/kb381l2dmmpbdqd/NNEDI3CL-r8.tar.gz http://download1649.mediafire.com/iny8w07rw80g/ptgauv3ry240qfy/QRCodeSource-1.0-b5ce453.tar.gz http://download1654.mediafire.com/3lugszeph9vg/c6f91nnl82mte7m/RawSource-160426.tar.gz http://download1474.mediafire.com/o3fe9hi01jdg/qy0eg1pw7cllmy8/ReadMpls-r4.tar.gz http://download1083.mediafire.com/xikzedmyo7ag/ab64cwj6sanolab/RemapFrames-v1.1.tar.gz http://download1475.mediafire.com/ct7ym8ps02kg/76j6ip0prteiabt/RemoveDirt-ddc78e5.tar.gz http://download1649.mediafire.com/h56rrgg5s5cg/avi7cgbqi9qip13/Retinex-r4.tar.gz http://download1350.mediafire.com/sjpk7152lelg/my1ahd0q5o86jxu/librgsf-r5.tar.gz http://download1588.mediafire.com/8dzhtt3uyesg/jh2sv2co7hiix3x/SangNom-r42.tar.gz http://download1503.mediafire.com/mlts5jvrnsvg/v0wtzfkhb5qjyef/SangNomMod-v0.1-fix.tar.gz http://download853.mediafire.com/i3wotavpnwwg/jf9gfgn8g7f173z/SceneChange-0.2.0-2.tar.gza http://download1522.mediafire.com/icmynjhbk1ig/wf81jpyn4liizoq/scrawl-1.0.tar.gz http://download1642.mediafire.com/n9n5oe64rshg/xadd8jg2x88em5n/SCX-v1.tar.gz http://download1478.mediafire.com/n6qcf4n1loeg/ltc9xx2zl0cz3o6/SmoothUV-v2.tar.gz http://download941.mediafire.com/f5fdeu2sbmag/73zj88u67jc77rk/SSIQ-v1.0.tar.gz http://download1496.mediafire.com/2kg8133u3wxg/22mnw8v9srtt6nj/SurfaceBlur-r0.tar.gz http://download1338.mediafire.com/woh0kj1ibelg/uk4gs511a81jfha/TBilateral-v3.tar.gz http://download1484.mediafire.com/ue1u1nwgk5sg/a5stqtecpqu3zoc/TCanny-r12.tar.gz http://download1351.mediafire.com/x4r8uxvos7kg/8l82thg5uj4a88u/TComb-v4.tgz http://download944.mediafire.com/5l8zvvb016mg/5p4d3cjh3e5yh8h/TDeintMod-r10.1.tar.gz http://download1581.mediafire.com/3r87gmbdbrkg/op6ltasy1425hti/TempLinearApproximate-r3.tar.gz http://download1337.mediafire.com/284cbdwlhvsg/dm7jplg9ylecp8y/TemporalSoften-v1.0.tar.gz http://download1323.mediafire.com/u78hc9bi138g/sh5vbvf6y1ay910/TemporalSoften2-v1.tar.gz http://download1482.mediafire.com/nuan90ot7cdg/8pr8mm9a6rzlyy4/TimeCube-r3.tar.gz http://download939.mediafire.com/crkudfapu8tg/pjxgxic88ae9dnp/TNLMeans-r40.tar.gz http://download852.mediafire.com/ai8z2gvu3skg/hklmtdbza9p9a5a/ToneMap-R2.tar.gz http://download948.mediafire.com/ygzv6z13alzg/t2pze52gq152aa9/TTempSmooth-r3.tar.gz http://download1585.mediafire.com/0x29an09yaag/2hn6vurq42d12lz/VagueDenoiser-r2.tar.gz http://download937.mediafire.com/hrjbwhtutepg/2y8gw5lb8flu74c/libvcmod-0720.tar.gz http://download1084.mediafire.com/pq62xt6vdj4g/h35cx6czf78pqrw/vcmove_0820.tar.gz http://download942.mediafire.com/l55bo1r3wnbg/s01j1y4u0zw11l7/vctrans-0915.tar.gz http://download851.mediafire.com/jls8qqpcidfg/2re4fn5w4kewdup/VFRToCFR-1.0.tar.gz http://download1580.mediafire.com/9hdjmejryphg/tfar0lnclr6vqty/VideoScope-v1.0.tar.gz http://download1980.mediafire.com/jhyuk37g32ug/ak1g11hb2ruyxnb/W3FDIF-r1.tar.gz http://download1644.mediafire.com/7tf5pcuqnoug/vrcs3h363g5qbqi/waifu2x-ncnn-vulkan-r3.tar.gz http://download2271.mediafire.com/n5xumfnqyqfg/vlpzbhafkjevhkx/Waifu2x-w2xc-r8-a9f064a.tar.gz http://download1474.mediafire.com/2r710xp0c0gg/nr3c6vs3ozv7w2x/Yadifmod-r10.1.tar.gz http://download1324.mediafire.com/hykixh4el82g/qp3ob9sppbdeqls/ZNEDI3-r2.tar.gz ' for url in $urls; do curl $url | tar -xz done Cu Selur |
12th September 2020, 09:38 | #240 | Link |
Your direct links don't work for me. It first shows a page "Generating new download key" and then redirects me to the page with a download button. So you absolutely need the script I posted above.
meatwadismagical, meatwadthegreat |
