Old 18th September 2012, 01:30   #81  |  Link
blaster00
"Auto-load Subtitles" sometimes don't work. Have to enable manually.
x64 build. Both external and internal, srt and ass.
blaster00 is offline   Reply With Quote
Old 18th September 2012, 02:02   #82  |  Link
@blaster00
Discussion of torrents is not allowed per forum rule 6. Your attachment was deleted.
Old 18th September 2012, 06:52   #83  |  Link
NiFa
Audio & video enthusiast
I have problem with MPC-BE 1.0.3.0, when I enable launch files in fullscreen and exit player middle of playback. After that when I start MPC-BE it starts in fullscreen mode, and I can't get it in to windowed mode, it stays in fullscreen, no matter what I do.
NiFa is offline   Reply With Quote
Old 18th September 2012, 09:25   #84  |  Link
Zingerus
Zingerus's Avatar
Try Ctrl + C
Most likely you have enabled D3D fullscreen.
Zingerus is offline   Reply With Quote
Old 18th September 2012, 09:53   #85  |  Link
NiFa
D3D fullscreen is disabled, tried Ctrl+C and Ctrl+Enter, it still won't return to windowed mode.
Old 18th September 2012, 10:15   #86  |  Link
naoan
I don't get the problem. I'm using madvr though if it's relevant.
naoan is offline   Reply With Quote
Old 18th September 2012, 10:18   #87  |  Link
NiFa
I use EVR custom, tried with all other too, but still not working.
Old 18th September 2012, 10:35   #88  |  Link
Zingerus
Zingerus's Avatar
NiFa
Uncheck "Remember last window position"
Old 18th September 2012, 10:44   #89  |  Link
NiFa
Thanks Zingerus that helped and now it works like it should.
Old 18th September 2012, 13:35   #90  |  Link
ZoNi
ZoNi's Avatar
Originally Posted by Keiyakusha View Post
Small suggestion. Maybe you want to hide menu by default and instead make this button that firefox (and some other software) uses? But using black color of course =)
This is GREAT idea
Now it is little weird - bottom toolbar is black (or another custom color) and menubar is in default color (silver, blue-ish...).
BTW, even in FF you can make it black with Stratiform.
ZoNi is offline   Reply With Quote
Old 18th September 2012, 19:58   #91  |  Link
ceb
I used the "old" MPC-BE and I knew that updates to MPC-HC would be included in it, so is it still the same?
Also a small suggestion, I think the option "Auto-zoom" should be enabled at default (at 100%), I find it more "natural" to see the opened video in its actual size. Also I don't know if it's a bug or intended but the OSD doesn't show on music while it does for videos, since the album art is shown the window is open and so it makes sense to show the OSD.
Thanks and continue with the great work!
ceb is offline   Reply With Quote
Old 19th September 2012, 12:46   #92  |  Link
ney2x
Does MPC-BE Team still affiliated with http://www.xvidvideo.ru/ ? Latest version of MPC-BE at xvidvideo.ru is mpc-be.1.0.0.0.1165 wherein at sourceforge is mpc-be.1.0.3.0.1164. I'm a little confused.
ney2x is offline   Reply With Quote
Old 19th September 2012, 13:36   #93  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Thank you for having found this bug. Now, on the site xvidvideo.ru posted files of the version 1.0.3.0.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 19th September 2012, 13:49   #94  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by ikarad View Post
Will you work on sub renderer with mpc BE?
The sub renderer of mpc-hc is broken with some blu-ray since the start of blu-ray subs support two or 3 years ago.
The same problem is still present in mpc Be.
Try this test build. And if you can - upload another video with the same PGS subtitle. Or give a link to download a full lenght video.
http://aleksoid.tosei.ru/Test/mpc-be/mpc-be_PGS_TEST.7z
Old 19th September 2012, 14:40   #95  |  Link
alexins
MPC-BE DEV
alexins's Avatar
We invite to cooperation of developers, experienced and novice. We will be very glad to see everyone, and happy to welcome You in our friendly family!!!
Now in our team 33 people.
Old 19th September 2012, 15:40   #96  |  Link
ikarad
I try and it seems to work with the sample that I give.
Could you add this correction of bug at mpc-hc versions in the same time?
ikarad is offline   Reply With Quote
Old 19th September 2012, 17:38   #97  |  Link
Sylt
I would use the MPC-BE, but I missing some important changes/fixes introduced in MPC-HC:
1) MPC-BE don't use the new MPC-HC output page from Armada651
2) There is no update checker
3) The "zoom auto fit larger" option is missing in MPC-BE
4) The embedded resources viewer of MPC-HC is missing
5) minidump improvement are missing (Click here)
6) icon libary improvements are missing (Click here)
7) missing seperator patch (Click here)
8) many indentation cosmetics and fixed compiler warnings of mpc-hc are missing in mpc-be
Sylt is offline   Reply With Quote
Old 19th September 2012, 19:28   #98  |  Link
alexins
MPC-BE DEV
alexins's Avatar
This we have added in the source code of June 1, 2012, and we have the best location of the controls.
We're going to do this element on the other, with the ability to automatically update
At the request of users, by default this entry is disabled. If this option is needed, then everyone can enable it in the settings.
Alas, but the function "Save Thumbnails" works badly, many attempts might fail with the transition to a minidump.
Don't want to offend anyone, but 90% of these cosmetic fixes - it's a real nonsense.
You should personally compare the real work of the two players, операясь not on the log of changes, and based on real facts. At the current stage of development, now MPC-HC is a very strong backlog of MPC-BE, by its quality and functionality, and stability in the work.
Old 19th September 2012, 20:47   #99  |  Link
starla
Could I have the source code please?
starla is offline   Reply With Quote
Old 19th September 2012, 21:15   #100  |  Link
alexins
MPC-BE DEV
alexins's Avatar
OK, no problem, a complete version of the source code, you will be able to get on September 24-26. If need be, even just for this test build, with a complete coincidence.
