Old 20th April 2013, 11:04   #1021  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by wanezhiling View Post
http://pan.baidu.com/share/link?shar...&uk=3558042035
Another problem on this H264i file is slow seeking speed, extremely slow... o.O
Jump on the seekbar quickly, mpc-be crashed...
What about this ??
Old 20th April 2013, 11:19   #1022  |  Link
wanezhiling
Improved much, no crash now.
Still a little slow though compared to PotPlayer.
Old 20th April 2013, 15:33   #1023  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2521 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2521 (Nightly Builds) (Dev. MPC-BE)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 22nd April 2013, 12:24   #1024  |  Link
wanezhiling
Can't have a normal playback, seems to be latest FFmpeg's problem?
MPC-HC is fine.
Old 22nd April 2013, 14:38   #1025  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-HC is fine.
Yes, this is a problem in ffmpeg.
Old 22nd April 2013, 17:39   #1026  |  Link
therock003
When you use file->save as to save the video, does it use direct streeam copy? I mean is there any rencoding?
Cause i want to use avisynth scripts to open a file from and to certain frames and save some video sequences, the same way i used to do this on vdub.
therock003 is offline   Reply With Quote
Old 23rd April 2013, 05:55   #1027  |  Link
Aleksoid1978
No any rencoding. Direct streeam copy only.
Old 23rd April 2013, 19:45   #1028  |  Link
isamu
OK silly question time..... does MPCBE or *ANY* software media player for that matter allow you to use it when watching streamed videos on the net, instead of Adobe Flash Player? Please let me know.
isamu is offline   Reply With Quote
Old 23rd April 2013, 20:52   #1029  |  Link
paradoxical
You'd have to write a browser plugin that encapsulates the player and uses it to play the video instead. This wouldn't work if the streamed video is using any sort of encryption/DRM that requires Flash Player, though.
Old 23rd April 2013, 22:41   #1030  |  Link
turbojet
mpc-be plays youtube videos with open file/url without using flash. It would be nice if there were browser plugins that would allow mpc-be to hook into the browser.
PC: FX-8320 GTS250 HTPC: G1610 GTX650
PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0
Old 24th April 2013, 16:06   #1031  |  Link
paradoxical
Because they don't use any encryption/DRM. If Youtube did it wouldn't work because those would require using the Flash player.
Old 27th April 2013, 11:37   #1032  |  Link
Lord Maius
Italian txt language file updated (rev. 2542)
http://sdrv.ms/ZNVPIe
Lord Maius is offline   Reply With Quote
Old 27th April 2013, 14:54   #1033  |  Link
alexins
MPC-BE DEV
alexins's Avatar
OK! Thanks!
Old 27th April 2013, 15:35   #1034  |  Link
Lord Maius
Originally Posted by alexins View Post
OK! Thanks!
Thanks to you all for this amazing player!
Old 27th April 2013, 18:27   #1035  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2568 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2568 (Nightly Builds) (Dev. MPC-BE)
Old 28th April 2013, 10:54   #1036  |  Link
bozek
when can we expect the next stable release?
bozek is offline   Reply With Quote
Old 28th April 2013, 15:38   #1037  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2574 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2574 (Nightly Builds) (Dev. MPC-BE)
Old 28th April 2013, 17:06   #1038  |  Link
pie1394
Tested with build 2568... "starting in FSE" mode with madVR now works better than previous builds. Now it keeps screen blank instead of flashing back to desktop screen before the playback is truly started.
Build 2574 runs fine on my nVidia ION system --- But I does not use MPC-BE built-in FFMPEG decoder.
pie1394 is offline   Reply With Quote
Old 29th April 2013, 17:46   #1039  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2582 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2582 (Nightly Builds) (Dev. MPC-BE)
Old 1st May 2013, 19:05   #1040  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2591 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2591 (Nightly Builds) (Dev. MPC-BE)
