Old 12th June 2013, 03:38   #1201  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by ontherocks View Post
I have a whole bunch of these various types of multichannel audio files, obtained by scouring through the internet. I used these long back to test my AVR's capabilities.
Thanks for the build.
1. http://www.sr.se/laddahem/multikanal...dpirat_dts.zip - Still No Audio
2. http://www.masterpinguin.de/surround...Hotel19dld.wav - Plays fine
3. http://www.sr.se/laddahem/multikanal/dts/opalcity.zip - No Audio
I am not sure what settings am I missing, since it has been reported by z_mashine that all the 3 files play fine with this build.
PS: I do not use any external filters (and do not intend to use).
My settings:
1 - Try use audio renderer - System Default.
2 - make screenshot of filters on problem files.
you try this build - MPC-BE v1.2.0.0 -dev build 2865 ??
Old 12th June 2013, 07:49   #1202  |  Link
z_mashine
z_mashine's Avatar
I have no way to test bitstrimming. These files play fine for me on:
System Default
High Definition Device
DirectSound: High Definition Device
MPC Audio Renderer with System Default and High Definition Device
z_mashine is offline   Reply With Quote
Old 12th June 2013, 19:18   #1203  |  Link
ontherocks
I tried this. Did not solve the problem. Results are the same as previously mentioned.
Sorry, didn't quite get what exactly you are looking for.
Do you mean for example the screenshot from Play-->Filters-->MPC Audio Renderer-->Pin Info/Status?
I tried this too. Did not solve the problem. Results are the same as previously mentioned.
ontherocks is offline   Reply With Quote
Old 12th June 2013, 20:26   #1204  |  Link
Lord Maius
Updated Italian text translation --> Rev 2871
http://sdrv.ms/13DEctW
Lord Maius is offline   Reply With Quote
Old 12th June 2013, 22:37   #1205  |  Link
Reino
Reino's Avatar
ontherocks, just to be sure, you do have the internal DTS Audio Decoder enabled, haven't you?
DTS_Hotel19dld.wav plays fine over here with the internal DTS/AC3 Source Filter + internal DTS Audio Decoder / FFDShow / LAV.
My hobby website
Reino is offline   Reply With Quote
Old 13th June 2013, 00:59   #1206  |  Link
mindbomb
I'm having trouble here trying to tell mpc be to open fullscreen on a second monitor. The setting keeps reverting back to the default value.
mindbomb is offline   Reply With Quote
Old 13th June 2013, 02:43   #1207  |  Link
Aleksoid1978
I do not know what's wrong at you side. All 3 files play fine:
Old 13th June 2013, 10:35   #1208  |  Link
ontherocks
I have reported that DTS_Hotel19dld.wav plays fine. Please see this post http://forum.doom9.org/showpost.php?...postcount=1200
Old 13th June 2013, 10:40   #1209  |  Link
ontherocks
I will post screenshots with the 2 problematic files as you have shown.
Just to make sure......
The 2 problematic files do not produce any errors. They play like any other file, i.e. the play progresses. But there is no audio. It's silent. I cannot hear anything.
Old 13th June 2013, 10:45   #1210  |  Link
wanezhiling
@ontherocks, reset mpc-be
Old 14th June 2013, 03:51   #1211  |  Link
ontherocks
Ok.
I found out what was causing the problem.
Its an issue with bitstreaming.
If I do not select (S/PDIF,HDMI) Passthrough for DTS then MPC BE decodes and sends out multichannel PCM to my AVR. I can hear the tracks.
But if I select Passthrough for DTS (i.e. prevent MPC BE from decoding), there is no audio from my AVR.
Old 14th June 2013, 07:29   #1212  |  Link
Aleksoid1978
Ok.
P.S. Fixed at rev. 2894.
Old 14th June 2013, 16:21   #1213  |  Link
wanezhiling
http://pan.baidu.com/share/link?shar...&uk=3558042035
build 2881, stop playback since 4sec
lav splitter and mpc-hc work fine.
Old 14th June 2013, 23:35   #1214  |  Link
Aleksoid1978
All ok:
Old 15th June 2013, 03:23   #1215  |  Link
ontherocks
Wow! That was fast.
Old 15th June 2013, 06:07   #1216  |  Link
wanezhiling
All ok:
I figured out why. DXVA is fine.
Please try internal sw mpeg2 decoder
Old 15th June 2013, 06:59   #1217  |  Link
Aleksoid1978
Ok - a see. Thanks for report
P.S. Fixed at rev. 2903;
Old 16th June 2013, 02:39   #1218  |  Link
73ChargerFan
73ChargerFan's Avatar
alexins,
Can you edit the first post and add a link to nightly builds?
73ChargerFan is offline   Reply With Quote
Old 16th June 2013, 03:43   #1219  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Originally Posted by 73ChargerFan View Post
alexins,
I put the links to the "Nightly Builds" at the bottom of the first post.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 16th June 2013, 03:59   #1220  |  Link
73ChargerFan
Thanks, much easier! It took me 10 minutes to find earlier.
Great work everyone, I really like how BE is coming along.
