8th October 2010, 20:23 | #8621 | Link |
Thanks, I have been enjoying without issue
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
9th October 2010, 10:14 | #8622 | Link |
Iam still trying to figure out what happens to the original DTS-MA track.
I have checked the FLAC option and when I read the demux log I see the original track is downconverted from 24 bits to 16 bits. Why? I found a readme under Tools\Ax\ArcSoft DTS Decoder that I followed. Is something wrong with my decoding? Here is the log: Code:
eac3to v3.24 command line: "E:\Dokument\Videoredigering\RipBot264v1.16.3\Tools\eac3to\eac3to.exe" "E:\Dokument\AnyDVDHD\SHERLOCK HOLMES\" 2) 2: "E:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 4: "E:\temp\RipBot264temp\job1\audio_English.dtsma.flac" -down16 23: "E:\temp\RipBot264temp\job1\23_subtitles_Swedish_1080.sup" 1: "E:\temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="E:\temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 2 video tracks, 7 audio tracks, 23 subtitle tracks, 2:08:24, 24p /1.001 1: Chapters, 30 chapters 2: VC-1, 1080p24 /1.001 (16:9) 3: VC-1, 480p24 /1.001 (3:2) 4: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) 5: AC3, English, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB 6: AC3, French, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB 7: AC3, German, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB 8: AC3, Italian, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB 9: AC3, Spanish, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB 10: DTS Express, English, 2.0 channels, 16 bits, 192kbps, 48kHz 11: Subtitle (PGS), English 12: Subtitle (PGS), French 13: Subtitle (PGS), German 14: Subtitle (PGS), German 15: Subtitle (PGS), Italian 16: Subtitle (PGS), Italian 17: Subtitle (PGS), Spanish 18: Subtitle (PGS), Dutch 19: Subtitle (PGS), Danish 20: Subtitle (PGS), Finnish 21: Subtitle (PGS), Norwegian 22: Subtitle (PGS), Portuguese 23: Subtitle (PGS), Swedish 24: Subtitle (PGS), French 25: Subtitle (PGS), German 26: Subtitle (PGS), Italian 27: Subtitle (PGS), Spanish 28: Subtitle (PGS), English 29: Subtitle (PGS), French 30: Subtitle (PGS), German 31: Subtitle (PGS), Italian 32: Subtitle (PGS), Spanish 33: Subtitle (PGS), Dutch Creating file "E:\temp\RipBot264temp\job1\chapters.txt"... [v02] Extracting video track number 2... [v02] Muxing video to Matroska... [a04] Extracting audio track number 4... [a04] Decoding with ArcSoft DTS Decoder... [a04] Reducing depth from 24 to 16 bits... [a04] Encoding FLAC with libFlac... [s23] Extracting subtitle track number 23... [a04] Creating file "E:\temp\RipBot264temp\job1\audio_English.dtsma.flac"... [s23] Creating file "E:\temp\RipBot264temp\job1\23_subtitles_Swedish_1080.sup"... [a04] The original audio track has a constant bit depth of 24 bits. [a04] The processed audio track has a constant bit depth of 16 bits. [a04] Audio overlaps for 8ms at playtime 0:01:09. <WARNING> [a04] Audio overlaps for 11ms at playtime 0:11:33. <WARNING> [a04] Audio overlaps for 5ms at playtime 0:15:42. <WARNING> [a04] Audio overlaps for 7ms at playtime 0:18:09. <WARNING> [a04] Audio overlaps for 6ms at playtime 0:29:45. <WARNING> [a04] Audio overlaps for 10ms at playtime 0:32:43. <WARNING> [a04] Audio overlaps for 8ms at playtime 0:37:08. <WARNING> [a04] Audio overlaps for 9ms at playtime 0:51:38. <WARNING> [a04] Audio overlaps for 10ms at playtime 0:54:00. <WARNING> [a04] Audio overlaps for 8ms at playtime 1:11:14. <WARNING> [a04] Audio overlaps for 12ms at playtime 1:23:18. <WARNING> [a04] Audio overlaps for 7ms at playtime 1:26:04. <WARNING> [a04] Audio overlaps for 9ms at playtime 1:35:55. <WARNING> [a04] Audio overlaps for 7ms at playtime 1:49:56. <WARNING> [a04] Audio overlaps for 5ms at playtime 2:01:33. <WARNING> [a04] Starting 2nd pass... [a04] Extracting audio track number 4... [a04] Decoding with ArcSoft DTS Decoder... [a04] Reducing depth from 24 to 16 bits... [a04] Encoding FLAC with libFlac... [a04] Realizing RAW/PCM gaps... [a04] Creating file "E:\temp\RipBot264temp\job1\audio_English.dtsma.flac"... [a04] The processed audio track has a constant bit depth of 16 bits. Added fps value (24 /1.001) to MKV header. Video track 2 contains 184729 frames. Video track 3 contains 184729 frames. Subtitle track 23 contains 1382 captions. eac3to processing took 27 minutes, 7 seconds. Done. |
9th October 2010, 10:19 | #8623 | Link | |
9th October 2010, 10:35 | #8624 | Link |
I've used this app a lot before, it's great and I never had any problems with it .
Until today with a specific video, the x264 application crashes at about 60% through the 2nd pass. The video is an HDTV recording I made at a high bitrate so I could trim out adverts and compress it (with Ripbot) later. Mediainfo shows this about the file: Code:
General ID : 0 Complete name : D:\Temp\2010_10_8_17_36_2.M2TS.12.M2TS Format : MPEG-TS File size : 9.73 GiB Duration : 1h 37mn Overall bit rate : 14.3 Mbps Maximum Overall bit rate : 18.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 1h 37mn Bit rate : 12.9 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16/9 Frame rate : 50.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.280 Stream size : 8.79 GiB (90%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Duration : 1h 37mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Video delay : -28ms Stream size : 268 MiB (3%) The Ripbot log is as follows: Code:
D:\>"D:\Program Files\RipBot\tools\avs2yuv\pipebuf.exe" "D:\Program Files\RipBot\tools\avs2yuv\avs2yuv.exe" "D:\temp\RipBot264temp\job1\job1.avs" - : "D:\Program Files\RipBot\tools\x264\x264_x64.exe" --pass 1 --bitrate 3767 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 50 --force-cfr --min-keyint 50 --keyint 500 --frames 292694 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "D:\temp\RipBot264temp\video.264" - : 2 y4m [info]: 1280x720p 1:1 @ 50/1 fps (cfr) x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (25000) > level limit (20000) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [info]: profile Main, level 4.0 D:\temp\RipBot264temp\job1\job1.avs: 1280x720, 50 fps, 292694 frames x264 [info]: frame I:1407 Avg QP:17.90 size: 62572 x264 [info]: frame P:107967 Avg QP:22.08 size: 19716 x264 [info]: frame B:183320 Avg QP:24.51 size: 2897 x264 [info]: consecutive B-frames: 3.0% 30.4% 26.8% 39.8% x264 [info]: mb I I16..4: 52.5% 0.0% 47.5% x264 [info]: mb P I16..4: 13.8% 0.0% 0.0% P16..4: 57.9% 0.0% 0.0% 0.0% 0.0% skip:28.4% x264 [info]: mb B I16..4: 1.9% 0.0% 0.0% B16..8: 15.3% 0.0% 0.0% direct: 8.8% skip:74.0% L0:31.8% L1:53.6% BI:14.6% x264 [info]: final ratefactor: 21.90 x264 [info]: coded y,uvDC,uvAC intra: 33.2% 33.1% 6.6% inter: 13.9% 9.6% 0.2% x264 [info]: i16 v,h,dc,p: 49% 23% 19% 9% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 20% 17% 3% 8% 6% 6% 6% 7% x264 [info]: i8c dc,h,v,p: 65% 14% 19% 2% x264 [info]: Weighted P-Frames: Y:6.4% x264 [info]: kb/s:3755.23 encoded 292694 frames, 128.09 fps, 3755.23 kb/s D:\>"D:\Program Files\RipBot\tools\avs2yuv\pipebuf.exe" "D:\Program Files\RipBot\tools\avs2yuv\avs2yuv.exe" "D:\temp\RipBot264temp\job1\job1.avs" - : "D:\Program Files\RipBot\tools\x264\x264_x64.exe" --pass 2 --bitrate 3767 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 50 --force-cfr --min-keyint 50 --keyint 500 --frames 292694 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "D:\temp\RipBot264temp\video.264" - : 2 y4m [info]: 1280x720p 1:1 @ 50/1 fps (cfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [info]: profile High, level 4.0 D:\temp\RipBot264temp\job1\job1.avs: 1280x720, 50 fps, 292694 frames Output error: wrote only 1304132 of 1382400 bytes D:\>"D:\Program Files\RipBot\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Paul\Desktop\2010_10_8_17_36_2 M2TS 12.mkv" --compression 0:none --title "2010_10_8_17_36_2 M2TS 12" --default-duration 0:50fps -d 0 -A -S "D:\temp\RipBot264temp\video.264" --compression 0:none --language 0:und --sync 0:0 -a 0 -D -S "D:\temp\RipBot264temp\job1\audio_Undetermined.ac3" mkvmerge v4.3.0 ('Escape from the Island') built on Sep 5 2010 10:30:51 'D:\temp\RipBot264temp\video.264': Using the AVC/h.264 ES demultiplexer. 'D:\temp\RipBot264temp\job1\audio_Undetermined.ac3': Using the AC3 demultiplexer. 'D:\temp\RipBot264temp\video.264' track 0: Using the MPEG-4 part 10 ES video output module. 'D:\temp\RipBot264temp\job1\audio_Undetermined.ac3' track 0: Using the AC3 output module. The file 'C:\Users\Paul\Desktop\2010_10_8_17_36_2 M2TS 12.mkv' has been opened for writing. 'D:\temp\RipBot264temp\video.264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1280/720. The cue entries (the index) are being written... Muxing took 38 seconds. 'D:\temp\RipBot264temp\Job1\Job1_RemoveEmptyFolders.cmd' is not recognized as an internal or external command, operable program or batch file. ------------------------- Elapsed Time: 09h:43m:46s Any idea where I'm going wrong? |
9th October 2010, 11:46 | #8626 | Link |
When I add a job (1080p MKV) while RipBot is encoding, it takes a long time for demuxing. When I set "low priority" on, demuxing is much faster. RipBot should automatically activate "low priority" when adding a job, and change to normal priority when the "add job" window is closed. Just an idea.
9th October 2010, 16:09 | #8627 | Link | |
9th October 2010, 16:38 | #8628 | Link | |
9th October 2010, 16:56 | #8629 | Link | |
The Black Reaper
However, could you trim out 50mb of the file as sample and upload it to mediafire so that I could test what happens when I try to encode it on my machine? |
10th October 2010, 14:48 | #8631 | Link |
Couldn't open input file in HIDE mode! Exiting
This is the message it gives me when I simply try to load ANY type of VOB in RipBot. What should I do? EDIT: I forgot to mention... After closing the dialog window this error appears: MPEG2Source : unable to load D2V file "C:\temp\RipBot264temp\job1\job1.d2v" (C:\temp\RipBot264temp\job1\getinfo.avs, line 2) |
11th October 2010, 09:39 | #8632 | Link |
@Atak,
I know you are against using TrueHD/DTS-HD, and go the route of flac, however i thought i would beg again! Please would you reconsider, and add support for retaining TrueHD/DTS-HD audio? I'm sure there are plenty of users out there who have to go the long route of encoding video with RipBot, demuxing TrueHD/DTS-HD, remuxing the lot to MKV. Of course, there are other video encoding tools out there that can do this, however as a compliment to you, i'm only interested in using RipBot! You could save people a stack of time! Surely this is a legit feature request and would be well served? Many thanks |
11th October 2010, 15:17 | #8633 | Link |
12th October 2010, 15:14 | #8636 | Link |
Hi Atak,
The RipBot is crashing when I try to normalize the audio using the base 3.0 for iPod. Showing "Please wait... Initializing" forever. Without normalization have no problems. Edit Working perfectly. How is the first time I had to normalize the audio, I did not know who took the time(Please wait... Initializing) to scan the file. Last edited by soneca; 12th October 2010 at 23:08. |
12th October 2010, 17:41 | #8637 | Link |
Help
Hello.
Im a beginner using this app, This is the only free app I found so Im very interesting in making the job. When I try to add my .m2ts files, ripbot 264 display this error : (Cannot Open Files c:\temp\ripbot264temp\job1\blu-ray_structure_info.txt. This file is not found) Do you know what happen ? Thanks. |
12th October 2010, 20:13 | #8638 | Link | |
12th October 2010, 20:32 | #8639 | Link | |
Knowing my luck, it'll probably start failing again using this method too. |
13th October 2010, 15:45 | #8640 | Link |
Just out of curiosity... Why would I prefer 2-Pass mode over CQ, other than to limit file size? (No criticism meant, at all. Just curious. I always use CQ mode by default, but just now had to use 2-Pass to limit file size, and was wondering what other advantages it might have.)
