2nd January 2009, 14:09 | #101 | Link |
н∂-ƒαиαтι¢
oh, btw.. i selected yellow for subs yesterday and it was white.. the code for yellow in your prog is diff from JAMAT.
JAMAT = 720p-fontcolor=0xFFFF00 MulTiAVCHD = 720p-fontcolor=0x0000FFFF Last edited by ~bT~; 2nd January 2009 at 14:12. |
2nd January 2009, 17:42 | #104 | Link |
Do you just drag the whole AVCHD folder to a usb and the PS3 should be able to play it
I get a black screen for about 1 minute and then it goes back to the XMB bar i am in Canada so i don't know if its the PAL menu or not,anyway i downloaded the ntsc version(The menu is Pal and i can't change it)and i get the same thing i am not even sure how to play AVCHD from usb so this post could be useless thanks |
2nd January 2009, 17:47 | #107 | Link | |
Programmer (or just 教务长)
I don't know how you could determine if menu is PAL or NTSC. It is coded in NTSC format in the ntsc version. Do you use HDMI connection from your PS3 to your TV? edit: PAL system in drop-down is disabled and not affecting anything... it is just a gui addon that is not used for now. |
2nd January 2009, 18:00 | #108 | Link |
thanks
I tested with a different .mkv and now it works on the ntsc version ,the first mkv was transformers that i made from HD DVD using ripbot and the second is just a 20 second clip using the same evo file i will test the 20 second clip with the pal version to see if works edit multiAVCHD pal version skips the menu and goes right into the first movie Last edited by bigggt; 2nd January 2009 at 18:23. |
2nd January 2009, 22:02 | #112 | Link |
Well, i think i've found some kind of bug, i got the latest build and i've made a 3 titles avchd from 3 mkvs.
only the first 2 menu links are good, 3rd link gives me nothing. all the process went well and all files are in the structure as well. |
2nd January 2009, 22:38 | #113 | Link |
You can PM me the LOG... I guess some of the MKVs are not tsMuxer friendly.
I guess, I'll add some error counter at the end of the log. If mkv's are missing that means that tsmuxer was unable to detect/remux some of the MKVs selected. Please let me know of your case, zoner. p.s. Do you see the third MKV somewhere in the MTSs in the output folder? ... p.s.X And something else... Do you see somewhere in log "Setting menu for XXX titles..."? XXX should reflect the real count - i.e. tsmuxer's output + avchd folders (if you didn't touch cut start/end settings). Dean Last edited by deank; 2nd January 2009 at 23:19. |
3rd January 2009, 11:28 | #115 | Link |
In latest build (92) I added error checking on tsmuxer's output.
Also warning is issued if video height is not avchd compliant (720 or 1080). --- Fixed playlist files generated by tsmuxer with ID:MPLS0200, now set to MPLS0100. Last edited by deank; 3rd January 2009 at 12:04. |
3rd January 2009, 19:07 | #118 | Link |
н∂-ƒαиαтι¢
updates not working...
Checking... Downloading... URL: http://multiavchd.deanbg.com/multiavchd.exe HttpSendRequest error HttpQueryInfo: 12019 Error! (0) |
3rd January 2009, 20:10 | #120 | Link |
Life's clearer in 4K UHD
Hi Dean,
Is there any possibility you could provide an option to directly "Add Transport Streams", ie: something like this: -
