3rd April 2014, 04:12 | #25621 | Link |
I noticed the same thing. It seems madVR is trying to use the HD4000 for openCL. I even tried deleting the HD4000 value and added a new value for my nVidia gpu but as soon as I started a video it added the HD4000 right back.
3rd April 2014, 05:19 | #25622 | Link | |
Broadband Junkie
HKEY_CURRENT_USER\Software\madshi\madVR\OpenCL\forceVendor REG_SZ "nVidia" |
3rd April 2014, 05:26 | #25623 | Link | |
Troubleshooter
Its interesting...if I force the Nvidia NEEDI3 runs correctly, but if I force the Intel the screen goes green again...
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. Last edited by Anime Viewer; 3rd April 2014 at 05:44. |
3rd April 2014, 05:53 | #25626 | Link | |
3rd April 2014, 06:29 | #25627 | Link |
this has a lot to do with the cpu and pci-e versions.
i get over 440 fps with haswell and pci-e 3.0 ivy bridge is slower with pci-e 3.0. just have a look at this post: http://www.avsforum.com/t/1477339/so-youve-built-your-htpc-now-what-is-next-how-to-get-the-ultimate-picture-and-sound-quality-from-your-htpc-madvr-svp-xbmc-mediabrowser-jriver/450#post_24514253 this is not 100 % reproduceable number can varies between two identical cards and that a lot. |
3rd April 2014, 09:13 | #25628 | Link | ||
Chroma: Bicubic 75+AR Image Up: Jinc3+AR Image Down: CR+AR+LL 720->1080 with NNEDI 32N: 37ms with OD, 40ms with ED1. Stable and no dropped frames during a 24p movie. If I step down image downscaling to CR without AR/LL, rendering goes down to ~32ms, or image upscaling down to lanczos3+AR to 35ms. The hit from error diffusion is much lower than on the 660, but NNEDI does take a bit more performance out of it. However, its quite usable with NNEDI for 24p content. A 750Ti, with around 20% more performance, should fare even better and beat the GTX 660 consistently. A "860" model based on Maxwell sounds like a good madVR card, but who knows when those will come out. To reach enough performance to run 60p with NNEDI, you'll need to wait for the new high end cards, though! 90% of all content I watch is 24p, 7% is 25p, and only the last 3% are anything higher, so for me it would probably even be enough.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 3rd April 2014 at 09:18. |
3rd April 2014, 10:12 | #25629 | Link | |
-Disabling exclusive mode solves the stutter. -When in exclusive mode, (even with a GPU queue of 24), the decoder queue is always something like 21-25/24 while the others are 20 or 21-24/24 -The mouse is stuttering a lot in exclusive mode (maybe a clue?) |
3rd April 2014, 10:44 | #25630 | Link | |||
The only other setting I can think of is the Windows Power Settings for PCI-E power savings but that makes no difference. Quote:
EDIT: Just realised Pitcairn is an AMD code name so that's probably fine.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 Last edited by DragonQ; 3rd April 2014 at 11:09. |
3rd April 2014, 11:18 | #25631 | Link | |||||
Some users are still using it. I hope to be able to get rid of it some day, but it's not costing me much support work, so I'll leave it in for now. The big cleanup might come for v1.0. No need to rush cleanup now. Quote:
You're saying the 750 is faster with error diffusion but a bit slower with NNEDI compared to the 660? I think the 750Ti should be a great HTPC card, at least it's by far the greatest card which doesn't need an extra power plug. Can't wait for 860Ti or 960Ti in 20nm without an extra power plug... Quote:
(1) How's the presentation queue? (2) Do you get frame drops? Or presentation glitches? Or both? (3) Have you changed any other settings besides from the queue sizes? (4) Hope you're using the default flush settings? (5) Have you tried disabling desktop composition (if you're on win7)? |
3rd April 2014, 11:18 | #25632 | Link | |
Please don't drop XP support. And thanks madshi for the new build with Vsfilter/black frame bug fixed!
XP SP3 / Geforce 8500 / Zoom Player Last edited by TheShadowRunner; 3rd April 2014 at 11:20. |
3rd April 2014, 11:50 | #25633 | Link | |
Can't think of any settings to change so I guess I'm stuck. My CPU is overclocked but Nehalem uses Base Clock rather than CPU Multiplier for overclocking, so the PCI-E bus is overclocked as well. My RAM has to be underclocked due to this but I can't imagine that would make such a huge difference; it's still over 1333 MHz. EDIT: Just realised the PCI-E bus isn't overclocked since it's separate to the Base Clock. Been a while since I've checked BIOS settings on this machine! In any case, QPI should surely be fast enough...is anyone else here using an AMD GPU on a QPI-based motherboard? I think QPI was only used on first-generation Core i7s (Bloomfield), at least for desktop systems.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 Last edited by DragonQ; 3rd April 2014 at 12:42. |
3rd April 2014, 12:51 | #25635 | Link | |
1) Almost always empty (i.e. 0 or 1-8/8) 2) Both 3) I tried with the reseted settings and it's the same. 4) Yes, defaults 5) Tried it too I must precise again that these errors only show up with High10. |
3rd April 2014, 21:11 | #25636 | Link |
Troubleshooter
While experimenting around with different forms of combinations it looks like optimus (and manybe AMD's hybrid) may be able to run in a hybrid state. While using the force registry key to Nvidia, and selecting the Intel gpu for MPC-HC in Nvidia control panel it looks like it may have used a combination of the two gpu. The NNEDI3 continued to render using the Nvidia because the screen didn't turn green and render times didn't shoot up drastically (like when I force the Intel in the registry), but the render times did increase ~5-7ms over the times when run with Nvidia control panel and the registry set to Nvidia. Potentially if other things besides OpenCL could be forced (like DirectCompute) people with dual gpu systems could eliminate the weaker of the two gpu's when it comes to using certain features. People with hybrid amd/intel systems might be able to get around the OpenCL interop bug if they set their systems to force the Intel in the registry, but tell their system to use the AMD for MPC-HC (or whatever other video player - like POT - they may be using).
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
3rd April 2014, 23:24 | #25637 | Link | |
My OpenCL copy and kernel fps drops from approximately 5250 fps to 130 fps with the interop. I'm on Windows 8.1 x64 and running the latest AMD beta driver. OpenCl error diffusion used to give me the same problem before madshi switched it to DirectCompute. The lowest frame time I can get with luma doubling at 16 neurons for a 720p 24 fps file is 48-50 ms with everything else either disabled or the lowest possible settings. My GPU runs at approximately 40% when I try to use my current settings with luma doubling. Sorry if this is kind of abrupt, I have been following madVR and lurking here since madshi started developing it, to which I cannot express my gratitude enough in words (for now, thank you!), but I have been pulling my hair out due to this problem. Please let me know if I can provide any other kind of info. |
4th April 2014, 00:10 | #25638 | Link | |
