Old 22nd February 2023, 02:05   #21  |  Link
kedautinh12
Originally Posted by DMD View Post
Good morning.
I would like to replace the version "3.5+37+12-4e46995bc-.Mod-by-Patman.-x64-msvc1931" embedded in StaxRip 2.13.0.
I am in confusion and don't know which version to install to replace the previous version.
Thank you
You can check speed result one by one to choose what best speed ver
Old 23rd February 2023, 01:19   #22  |  Link
MP4Box 2.3-DEV-rev45-gb964fe422-ab-suite
MediaInfo CLI 22.12
__
PS: uvz AviSynthPlus-Builds got updated to r3936.
Old 23rd February 2023, 02:18   #23  |  Link
kedautinh12
Will mp4box different with Barough's share??
Old 23rd February 2023, 02:22   #24  |  Link
kedautinh12
x265 v3.5+96
https://www.mediafire.com/file/lvwa18uv48f4aq9
Old 23rd February 2023, 02:24   #25  |  Link
TDS
Formally known as .......
TDS's Avatar
Originally Posted by kedautinh12 View Post
Don't forget new AVS, now in 2 "flavour's"...hmm, which one to choose ??
There also seems to be a revised x264 build (same build #, tho)
https://forum.doom9.org/showthread.p...73#post1983473
This can be Very "TeDiouS"..
Long term RipBot264 user.
Ryzen 9 7950X
Intel i9-13900KF
Ryzen 9 5950X
Ryzen 9 5900X
Ryzen 9 3950X
Link to RB v1.27.0
TDS is offline   Reply With Quote
Old 23rd February 2023, 04:26   #26  |  Link
kedautinh12
You need check what build faster by yourself
Old 23rd February 2023, 15:19   #27  |  Link
kedautinh12
FLAC git-9382c537 20230223
Built on February 23, 2023, GCC 12.2.0
(Code Base : 1.4.2)
https://github.com/xiph/flac/commits/master
DL :
https://www.mediafire.com/file/8tn6z6i7tgo2vdk
Old 24th February 2023, 03:47   #28  |  Link
kedautinh12
Avisynth+ 3.7.3 test 7 (20230223)
https://forum.doom9.org/showthread.p...26#post1983526
Old 24th February 2023, 04:13   #29  |  Link
TDS
TDS's Avatar
But test #7 is the latest
Ryzen 9 7950X
Intel i9-13900KF
Ryzen 9 5950X
Ryzen 9 5900X
Ryzen 9 3950X
Link to RB v1.27.0
Old 24th February 2023, 04:47   #30  |  Link
kedautinh12
I know but lazy to delete old post. Pinterf don't do that too
Old 6th March 2023, 21:20   #31  |  Link
Barough
Barough's Avatar
FFmpeg v6.0
Win32
https://github.com/sudo-nautilus/FFm...32-gpl-6.0.zip
Win64
https://github.com/BtbN/FFmpeg-Build...64-gpl-6.0.zip
Old 8th March 2023, 10:45   #32  |  Link
kedautinh12
FLAC git-4d21da11 20230227
Built on February 27, 2023, GCC 12.2.0
(Code Base : 1.4.2)
DL :
https://www.mediafire.com/file/urou3ls9tgk8yww
Old 10th March 2023, 01:19   #33  |  Link
TDS
TDS's Avatar
Originally Posted by Barough View Post
AviSynthPlus r3950
[url]https://gitlab.com/uvz/AviSynthPlus-Builds[/url
To whom it may concern, I have found that the IntelLLVM build of AVS IS faulty...it caused a Decoder Error,
which led me to do a fresh Windows setup, and now I've found out it was this all along
HOWEVER, the Clang build works fine.
I haven't had any issues with previous LLVM builds.
Ryzen 9 7950X
Intel i9-13900KF
Ryzen 9 5950X
Ryzen 9 5900X
Ryzen 9 3950X
Link to RB v1.27.0
Old 11th March 2023, 06:44   #34  |  Link
kedautinh12
You can report to Asd-g
https://gitlab.com/uvz/AviSynthPlus-...ripts/-/issues
Old 11th March 2023, 16:53   #35  |  Link
kedautinh12
FLAC git-4d6d8b34 20230308
Built on March 08, 2023, GCC 12.2.0
(Code Base : 1.4.2)
DL :
https://www.mediafire.com/file/svyvwntoxr3koy9
Barough still don't share this but flac still belong to this post
Old 11th March 2023, 22:07   #36  |  Link
Barough
Barough's Avatar
Since i dont see the need to double-post something. It's as simple as that.
Just look around a little and it will be found here at Doom9!!!
Old 11th March 2023, 22:42   #37  |  Link
john33
I know there is a trend to post, and probably to use, git upgrades of software, but these are not even vaguely beta versions and should not be considered for use for archival purposes.
john33 is offline   Reply With Quote
Old 12th March 2023, 03:10   #38  |  Link
kedautinh12
Or you can try install latest Intel® oneAPI DPC++/C++ Compiler Runtime for Windows*
https://www.intel.com/content/www/us...y-version.html
Old 12th March 2023, 04:56   #39  |  Link
kedautinh12
Visual C++ 2022 Redistributable - 14.36.32420.0
https://github.com/abbodi1406/vcredist/releases
Old 12th March 2023, 06:41   #40  |  Link
TDS
TDS's Avatar
But isn't that for "building", not "running" ?? (184Mb)
I've actually gone back to using r3944...
Ryzen 9 7950X
Intel i9-13900KF
Ryzen 9 5950X
Ryzen 9 5900X
Ryzen 9 3950X
Link to RB v1.27.0
Copyright ©2000 - 2023, vBulletin Solutions Inc.
