Old 9th June 2023, 02:22   #81  |  Link
TDS
Formally known as .......
TDS's Avatar
Avisynth+ 3.7.3 test 11 (20230608 - r3996)
https://drive.google.com/uc?export=d...9MQpZ_YqHCoSEO
https://forum.doom9.org/showthread.p...88#post1988188
This can be Very "TeDiouS"..
Long term RipBot264 user.
Ryzen 9 7950X
Intel i9-13900KF
Ryzen 9 5950X
Ryzen 9 5900X
Ryzen 9 3950X
Link to RB v1.27.0
TDS is offline   Reply With Quote
Old 10th June 2023, 19:20   #82  |  Link
Barough
Barough's Avatar
x265 v3.5+131-aMod -DJATOM
https://github.com/DJATOM/x265-aMod/.../tag/3.5%2B131
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 10th June 2023, 19:33   #83  |  Link
mcjordan
AviSynthPlus r3996
https://gitlab.com/uvz/AviSynthPlus-Builds/
mcjordan is offline   Reply With Quote
Old 11th June 2023, 05:57   #84  |  Link
kedautinh12
L-SMASH-Works 20230611
https://github.com/HomeOfAviSynthPlu...Works/releases
Fixed _EncodedFrameTop and _EncodedFrameTop, close #32. Changed behavior - they are showed only when there are frames to be repeated.
Fixed _FieldBased when repeat is not false.
Used libraries:
FFmpeg d78bffb.
l-smash 2c0696c.
obuparse 055be27.
zlib 1.2.13.
dav1d 1.2.1.
libxml2 v2.11.4.
nv-codec-headers n12.0.16.0.
xxHash v0.8.1.
mfx_dispatch 5a3f178.
kedautinh12 is online now   Reply With Quote
Old 23rd June 2023, 11:54   #85  |  Link
Barough
Barough's Avatar
FLAC v1.4.3 (GCC 13.2.0)
https://www.mediafire.com/file/ljekguyabfqto5i
FLAC v1.4.3 (CLANG 16.0.5)
https://www.mediafire.com/file/vs4o7cd3mo011hw
Old 29th June 2023, 01:04   #86  |  Link
kedautinh12
MediaInfo 23.06
https://mediaarea.net/en/MediaInfo/Download/Windows
Old 2nd July 2023, 14:55   #87  |  Link
StainlessS
StainlessS's Avatar
I'de just like to point out that some of the x265 versions posted, result in 10 bit only encodes [eg 8 in, 10 out. Try MediaInfo on result].
(result a bit bigger and a little slower than 8 bit encode).
Think I'm gonna stick with Patman mods, x265 compiles by jpsdr, for 8(default), 10 and 12 bit encode.
x265 with Patman mods (AVS, AQ-MODE 5, ...):- https://github.com/jpsdr/x265/releases
I tried both GCC and LLVM builds on Gen 8 i7-8700, and chose LLVM AVX2 {Haswell/Gen4+ for AVX2} as a bit faster.
Suggest try simple encode before deciding to implement as your current encoder.
EDIT:
Bit depth                                : 10 bits
Writing library                          : x265 3.5+75+0-f3c013983:[Windows][MSVC 1929][64 bit] 10bit
---[Information] [02/07/2023 01:41:39] encoded 20560 frames in 854.77s (24.05 fps), 1038.07 kb/s, Avg QP:30.24
87,254 KB
Writing library                          : x265 3.5+101+-02ef6de:[Windows][GCC 13.1.0][64 bit] 8bit+10bit+12bit
[Information] [02/07/2023 00:59:40] encoded 20560 frames in 662.81s (31.02 fps), 969.20 kb/s, Avg QP:30.37
81,485 KB
Writing library                          : x265 3.5+101+-02ef6de:[Windows][ICC 2021][64 bit] 8bit+10bit+12bit
---[Information] [02/07/2023 01:16:14] encoded 20560 frames in 646.84s (31.79 fps), 969.00 kb/s, Avg QP:30.37
81,468 KB
x265_r3_5_0_103.7z  [Patman Mods, by jpsdr]:- https://github.com/jpsdr/x265/releases
PATMAN_WinThread_AVX2:
Writing library                          : x265 3.5+103+0-385f07817:[Windows][GCC 13.1.0][64 bit] 8bit+10bit+12bit
---[Information] [02/07/2023 02:27:59] encoded 20560 frames in 648.47s (31.71 fps), 969.20 kb/s, Avg QP:30.37
81,485 KB
PATMAN_LLVM_AVX2: ( *** CHOSEN ***)
Writing library                          : x265 3.5+103+0-385f07817:[Windows][MSVC 1928][64 bit] 8bit+10bit+12bit
---[Information] [02/07/2023 02:55:31] encoded 20560 frames in 630.71s (32.60 fps), 968.97 kb/s, Avg QP:30.37
81,466 KB
EDIT: I've spent months [EDIT: 7 months] encoding slower, at 10 bit output, without realizing.
Jpsdr x265 with PatMan Mods support *.avs, 8, 10 and 12 bits. https://github.com/jpsdr/x265/releases
EDIT:
And for x264, all PatMan Mods versions tested [ support *.avs input, 8 and 10 bit ].
Original: Output bit depth 8/10
Writing library                          : x264 core 164 r3103 941cae6
---[Information] [02/07/2023 16:13:37] encoded 20560 frames, 84.93 fps, 1505.26 kb/s
126278KB
x264-0.164.3107_a8b68eb_Win_GCC122.7z : Output bit depth: 8/10
Writing library                          : x264 core 164 r3107 a8b68eb
---[Information] [02/07/2023 16:45:07] encoded 20560 frames, 84.49 fps, 1505.26 kb/s
126278KB
x264_tmod_r3107.1.7z : MCF: Output bit depth: 8/10
Writing library                          : x264 core 164 r3107+58M ae98796 t_mod_New [(8 & 10)-bit@all X86_64]
---[Information] [02/07/2023 16:35:42] encoded 20560 frames, 84.12 fps, 1505.26 kb/s, 123.10 MB
126278KB
x264_tmod_r3107.1.7z : POSIX: Output bit depth: 8/10
---[Information] [02/07/2023 16:51:57] encoded 20560 frames, 84.01 fps, 1505.26 kb/s, 123.10 MB
126278KB
x264_tmod_r3107.1.7z : WINTHREAD: Output bit depth: 8/10
---[Information] [02/07/2023 17:00:06] encoded 20560 frames, 81.39 fps, 1505.26 kb/s, 123.10 MB
126278KB
x264_tmod_Broadwell_r3107.1.7z : MCF: Output bit depth: 8/10 { *** CHOSEN *** }
---[Information] [02/07/2023 17:09:14] encoded 20560 frames, 86.38 fps, 1505.26 kb/s, 123.10 MB
126278KB
x264_tmod_Broadwell_r3107.1.7z : POSIX: Output bit depth: 8/10
---[Information] [02/07/2023 17:17:23] encoded 20560 frames, 86.26 fps, 1505.26 kb/s, 123.10 MB
126278KB
x264_tmod_Broadwell_r3107.1.7z : WINTHREAD: Output bit depth: 8/10
---[Information] [02/07/2023 17:24:27] encoded 20560 frames, 86.15 fps, 1505.26 kb/s, 123.10 MB
126278KB
All tested produced pretty much identical output size. Could have chosen any of the Broadwell variety.
The Broadwell versions require Gen 5+.
From command "x264.exe -h" of chosen encoder.
x264 core:164 r3107+58M ae98796 t_mod_New [(8 & 10)-bit@all X86_64]
Syntax: x264 [options] -o outfile infile
Infile can be raw (in which case resolution is required),
  or YUV4MPEG (*.y4m),
  or Avisynth if compiled with support (yes).
  or libav* formats if compiled with lavf support (yes) or ffms support (yes).
Outfile type is selected by filename:
 .264 -> Raw bytestream
 .mkv -> Matroska
 .flv -> Flash Video
 .mp4 -> MP4 if compiled with GPAC or L-SMASH support (lsmash)
 .3gp -> MP4 (branded '3gp6')
 .3g2 -> MP4 (branded '3gp6' and '3g2a')
 .mov or .qt -> QuickTime File Format
 .avi -> AVI if compiled with support (yes)
# ... More stuff
      --input-depth <integer> Specify input bit depth for raw input
      --output-depth <integer> Specify output bit depth
# ... Yet More stuff
x264 with PatMan mods, by jpsdr:- https://github.com/jpsdr/x264/releases
I sometimes post sober.
Old 3rd July 2023, 01:49   #88  |  Link
kedautinh12
MKVToolNix v78.0
https://mkvtoolnix.download/windows/releases/78.0/
https://mkvtoolnix.download/doc/NEWS.md
Old 3rd July 2023, 16:20   #89  |  Link
MABS now builds with strong stack protection.
Old 4th July 2023, 02:24   #90  |  Link
kedautinh12
Deleted
Old 4th July 2023, 14:07   #91  |  Link
tormento
Acid fr0g
tormento's Avatar
Try DJATOM's too.
@turment on Telegram
Old 4th July 2023, 20:22   #92  |  Link
StainlessS
StainlessS's Avatar
Try DJATOM's too.
Support *.avs input ?, and 8/10/12 for x264 and 8/10 for x265 ?
Old 4th July 2023, 20:48   #93  |  Link
I remember trying to build this mod just for this reason.
Old 4th July 2023, 23:22   #94  |  Link
StainlessS
StainlessS's Avatar
Well just tried DJATOM's,
x264 [UPDATED]
x264-aMod-x64-core164-r3101+20.7z : x264-aMod-x64-core164-r3101+20-generic.exe
Writing library                          : x264 core 164 r3101+20 87befef (DJATOM's mod)
---[Information] [04/07/2023 23:56:39] encoded 20560 frames, 83.87 fps, 1505.26 kb/s, duration 0:04:05.14
126278 KB
x264-aMod-x64-core164-r3101+20.7z : x264-aMod-x64-core164-r3101+20-opt-skylake.exe
---[Information] [04/07/2023 23:48:55] encoded 20560 frames, 84.96 fps, 1505.26 kb/s, duration 0:04:01.98
126278 KB
jpsdr PatMan mod, 86.38 FPS, so keeping with that.
Also, DJATOM x265
x265-x64-v3.5+131-aMod-gcc13.1.0+opt.7z : x265-x64-v3.5+131-aMod-gcc13.1.0.exe
Writing library                          : x265 3.5+131-c5c0aa6fd:[DJATOM's Mod][Windows][GCC 13.1.0][64 bit] 8bit+10bit+12bit
---[Information] [04/07/2023 22:55:44] encoded 20560 frames in 0:11:00.05 (31.15 fps), 968.97 kb/s, Avg QP:30.37
81466 KB
x265-x64-v3.5+131-aMod-gcc13.1.0+opt.7z : x265-x64-v3.5+131-aMod-gcc13.1.0-opt-skylake.exe
Bit depth                                : 10 bits
Writing library                          : x265 3.5+131-c5c0aa6fd:[DJATOM's Mod][Windows][GCC 13.1.0][64 bit] 10bit
---[Information] [04/07/2023 23:13:49] encoded 20560 frames in 0:14:13.86 (24.08 fps), 1039.09 kb/s, Avg QP:30.24
87339 KB
x265-x64-v3.5+131-aMod-gcc13.1.0+opt.7z :x265-x64-v3.5+131-aMod-gcc13.1.0-opt-haswell.exe
Bit depth                                : 10 bits
---[Information] [05/07/2023 00:20:46] encoded 20560 frames in 0:14:08.58 (24.23 fps), 1039.09 kb/s, Avg QP:30.24
87339 KB
SkyLake & Haswell Results, 8 bit in, 10 bit out, and quite a bit slower.
I'll stick with jpsdr PatMan Mods for both.
EDIT: jpsdr Patman x264 additionally support these output, not that I 'm gonna use them though.
 .mkv -> Matroska
 .flv -> Flash Video
EDIT: Ooops, DJATOM x264 had identical sizes, and identical encode times.
I musta had two logs opened at once and copied from the wrong one.
Re-Done both, and Updated DJATOM x264 timings.
EDIT: Added DJATOM x265 haswell timings, is 10 bit again.
Maybe is supposed to be 10 bit output, but I dont want it. [I dont see any warning about opt versions being 10 bit only]
EDIT: Is there some MeGUI trick for x64 to enable 10 bit encode in GUI. x86 versions
have "tools\x264_10b" folder, which seemingly enable 10 bit selection within MeGUI GUI.
Does MeGUI x64, x265 have similar kludge to enable user selectable 10 bit x265 encode ?
Old 5th July 2023, 15:33   #95  |  Link
Barough
Barough's Avatar
QAAC v2.80
https://github.com/nu774/qaac/releases/tag/v2.80
Old 7th July 2023, 10:11   #96  |  Link
kedautinh12
ffms2_r1363 (pass: BLxmx6YsVJ03):
- AviSynth: both GetParity and _FieldBased now can be changed per frame.
- ffms2@cf7c4b2;
- ffmpeg@4b1969;
- zlib 1.2.13;
- dav1d 1.2.1;
- libxml2 v2.11.4.
Old 7th July 2023, 13:19   #97  |  Link
Barough
Barough's Avatar
AviSynthPlus r4001
Old 7th July 2023, 17:05   #98  |  Link
kedautinh12
Originally Posted by Barough View Post
1.0.0.70 is right version and i was post link above
Old 9th July 2023, 00:19   #99  |  Link
kedautinh12
Deleted
Old 13th July 2023, 07:52   #100  |  Link
TDS
TDS's Avatar
MediaInfo v23.07
Ryzen 9 7950X
Intel i9-13900KF
Ryzen 9 5950X
Ryzen 9 5900X
Ryzen 9 3950X
Link to RB v1.27.0
Copyright ©2000 - 2023, vBulletin Solutions Inc.
