#221 | Link |
Also note, a function with a Float arg will accept an int [v2.60+, converted to type float inside the function],
but a function with a type Int arg will NOT accept a float. A type float arg specifier basically means 'numeric' whereas type Int is strictly int.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th January 2023 at 16:23. |
#223 | Link |
Edit: Nevermind, Disregard that qusstion as it turned out that Avisynth + and Avisynth wer ein conflict with each other. I was using AVSPmod and it does not detect AVISynth +. My next questions are: How do I make AVSPMod use AVISynth +? And can AVSPmod be a substitute for Virtualdub2? I used the Universal Installer but I installed the latest version of AVISynth + but I am afraid to use it.
#224 | Link |
Big Bit Savings Now !
Modify the Universal Groucho setavs.cmd to
::Batch script for fast switching of Avisynth versions ::Initial idea and work by Groucho2004 ::Modified by jones1913 ::Modified and extended by Groucho2004 ::Updated for AVSPLUS373 folders by Emulgator @echo off cls setlocal :Check administrative privileges fsutil dirty query %systemdrive% > nul if errorlevel 1 goto :noAdmin :: ########################## Start Configuration ######################### :: The variable "AVS_SRC_DIR" must be set according to the location of :: this batch file. :: The simplest way to have this up and running is to copy the "AvisynthRepository" :: directory to a location of your choice (avoid "Program Files" or "Program Files (x86)") :: and create a shortcut to the "setavs.cmd" batch file in the root of "AvisynthRepository". :: If you want to run the batch file from a different directory :: (i.e. a directory to which the "PATH" environment variable points), :: remove the "%~dp0" and use a fully qualified path to the source directory. :: Example: "set AVS_SRC_DIR=E:\VideoTools\AvisynthRepository" set AVS_SRC_DIR=%~dp0 :: Default plugin directories :: If you leave them blank, the respective "plugin" directories within :: the "AvisynthRepository" source directories will be used. set PLUGDIR32= set PLUGDIR64= :: Additional plugin directories (works only with Avisynth+) :: If you leave them blank, only the default plugin directories (see above) :: will be used. set PLUGDIR32PLUS= set PLUGDIR64PLUS= :: **IMPORTANT: :: If you have customized any of the above directories and their names contain :: special characters such as '&', '(' or ')', enclose the variable and path :: in double quotes and use the escape character '^' before the special character(s). :: :: Example 1: :: set "AVS_SRC_DIR=C:\Program Files ^(x86^)\Avisynth" :: :: Example 2: :: set "PLUGDIR32=C:\Program Files ^(x86^)\Avisynth\Plugins ^& avsi" :: ########################### End Configuration ########################## if "%AVS_SRC_DIR%" == "" ( echo. echo The source directory ^(AVS_SRC_DIR^) is not defined. echo Please read the instructions above. echo. goto :end ) if /i %PROCESSOR_ARCHITECTURE%==x86 if not defined PROCESSOR_ARCHITEW6432 set winarch=x32 :: Remove trailing backslash if present if "%AVS_SRC_DIR:~-1%"=="\" SET AVS_SRC_DIR=%AVS_SRC_DIR:~0,-1% echo. echo Installed Avisynth version(s): echo. if defined winarch ( "%AVS_SRC_DIR%\Tools\AVSVersion32.exe" ) else ( "%AVS_SRC_DIR%\Tools\AVSVersion32.exe" echo. "%AVS_SRC_DIR%\Tools\AVSVersion64.exe" ) echo. echo. echo Select the Avisynth version you want to install/uninstall: echo. echo 1 = Avisynth 2.5.8 echo 2 = Avisynth 2.6.0 echo 3 = Avisynth 2.6.1 (Alpha) echo 4 = Avisynth 2.6.0 (SEt's multi-threaded build) echo. echo 5 = Avisynth+ 0.1.0 (x86, r2772) echo 6 = Avisynth+ 0.1.0 (x64, r2772) echo 7 = Avisynth+ XP 3.7.0 (x86, r3382) echo 8 = Avisynth+ XP 3.7.0 (x64, r3382) echo 9 = Avisynth+ 3.7.3 (x86, r3825) echo 10 = Avisynth+ 3.7.3 (x64, r3825) echo. echo 13 = Uninstall Avisynth x86 echo 14 = Uninstall Avisynth x64 echo. echo NOTE: 64 bit versions can be installed alongside 32 bit versions. echo. echo. set no= set /p no= [1-12] (leave blank and [Enter] to exit): if [%no%]==[] goto :cancel if %no%==1 set avs=AVS258 if %no%==2 set avs=AVS260 if %no%==3 set avs=AVS261_Alpha if %no%==4 set avs=AVS260_MT if %no%==5 (set avs=AVSPLUS010_x86) & set avspl=true if %no%==6 (set avs=AVSPLUS010_x64) & set avspl=true if %no%==7 (set avs=AVSPLUS370_x86_XP) & set avspl=true if %no%==8 (set avs=AVSPLUS370_x64_XP) & set avspl=true if %no%==9 (set avs=AVSPLUS373_x86) & set avspl=true if %no%==10 (set avs=AVSPLUS373_x64) & set avspl=true if %no%==13 (set avs=AVSx86) & goto :uninstall if %no%==14 (set avs=AVSx64) & goto :uninstall echo. if [%avs%]==[] (echo Invalid input... goto :menu) if %avs%==AVSPLUS010_x64 set x64=true if %avs%==AVSPLUS370_x64 set x64=true if %avs%==AVSPLUS370_x64_XP set x64=true if %avs%==AVSPLUS373_x64 set x64=true :install :: Remove trailing backslash if present if "%AVS_SRC_DIR:~-1%"=="\" SET AVS_SRC_DIR=%AVS_SRC_DIR:~0,-1% if "%PLUGDIR32%" == "" ( set REGPLUGDIR32=%AVS_SRC_DIR%\%avs%\plugins ) else ( set REGPLUGDIR32=%PLUGDIR32% ) if "%PLUGDIR64%" == "" ( set REGPLUGDIR64=%AVS_SRC_DIR%\%avs%\plugins ) else ( set REGPLUGDIR64=%PLUGDIR64% ) if "%PLUGDIR32PLUS%" == "" ( set REGPLUGDIR32PLUS=%AVS_SRC_DIR%\%avs%\plugins ) else ( set REGPLUGDIR32PLUS=%PLUGDIR32PLUS% ) if "%PLUGDIR64PLUS%" == "" ( set REGPLUGDIR64PLUS=%AVS_SRC_DIR%\%avs%\plugins ) else ( set REGPLUGDIR64PLUS=%PLUGDIR64PLUS% ) :: Remove trailing backslash if present if "%REGPLUGDIR32PLUS:~-1%"=="\" SET REGPLUGDIR32PLUS=%REGPLUGDIR32PLUS:~0,-1% if "%REGPLUGDIR64PLUS:~-1%"=="\" SET REGPLUGDIR64PLUS=%REGPLUGDIR64PLUS:~0,-1% if "%REGPLUGDIR32:~-1%"=="\" SET REGPLUGDIR32=%REGPLUGDIR32:~0,-1% if "%REGPLUGDIR64:~-1%"=="\" SET REGPLUGDIR64=%REGPLUGDIR64:~0,-1% echo Installing %avs%... echo. if defined winarch ( echo setup for 32bit windows system... echo. if defined x64 ( echo Attempt to install x64 AVS on x32 Windows. goto :cancel ) echo copying %avs% files to "%WINDIR%\System32"... copy /y "%AVS_SRC_DIR%\%avs%\avisynth.dll" "%WINDIR%\System32" copy /y "%AVS_SRC_DIR%\%avs%\devil.dll" "%WINDIR%\System32" if errorlevel 1 ( echo Failed to copy files to "%WINDIR%\System32" goto :error ) echo. echo Writing "HKLM\SOFTWARE\Avisynth" /v "" /d "%AVS_SRC_DIR%\%avs%" reg add "HKLM\SOFTWARE\Avisynth" /v "" /d "%AVS_SRC_DIR%\%avs%" /f echo. echo Writing "HKLM\SOFTWARE\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR32%" reg add "HKLM\SOFTWARE\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR32%" /f if errorlevel 1 ( echo Error on importing registry keys! goto :error ) if "%REGPLUGDIR32PLUS%" GTR "" ( echo. echo Writing "HKLM\SOFTWARE\Avisynth" /v "PluginDir+" /d "%REGPLUGDIR32PLUS%" reg add "HKLM\SOFTWARE\Avisynth" /v "PluginDir+" /d "%REGPLUGDIR32PLUS%" /f if errorlevel 1 ( echo Error on importing registry keys! goto :error ) ) call :regWin ) else ( echo setup for 64bit windows system... echo. if defined x64 ( echo copying %avs% files to "%WINDIR%\System32"... copy /y "%AVS_SRC_DIR%\%avs%\avisynth.dll" "%WINDIR%\System32" copy /y "%AVS_SRC_DIR%\%avs%\devil.dll" "%WINDIR%\System32" if errorlevel 1 ( echo Failed to copy files to "%WINDIR%\System32" goto :error ) echo. echo Writing "HKLM\SOFTWARE\Avisynth" /v "" /d "%AVS_SRC_DIR%\%avs%" reg add "HKLM\SOFTWARE\Avisynth" /v "" /d "%AVS_SRC_DIR%\%avs%" /f echo. echo Writing "HKLM\SOFTWARE\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR64%" reg add "HKLM\SOFTWARE\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR64%" /f if errorlevel 1 ( echo Error on importing registry keys! goto :error ) if "%REGPLUGDIR64PLUS%" GTR "" ( echo. echo Writing "HKLM\SOFTWARE\Avisynth" /v "PluginDir+" /d "%REGPLUGDIR64PLUS%" reg add "HKLM\SOFTWARE\Avisynth" /v "PluginDir+" /d "%REGPLUGDIR64PLUS%" /f if errorlevel 1 ( echo Error on importing registry keys! goto :error ) ) call :regWin ) else ( echo copying %avs% files to "%WINDIR%\SysWow64"... echo copy /y "%AVS_SRC_DIR%\%avs%\avisynth.dll" "%WINDIR%\SysWow64" copy /y "%AVS_SRC_DIR%\%avs%\avisynth.dll" "%WINDIR%\SysWow64" copy /y "%AVS_SRC_DIR%\%avs%\devil.dll" "%WINDIR%\SysWow64" if errorlevel 1 ( echo Failed to copy files to "%WINDIR%\SysWow64" goto :error ) echo. echo Writing "HKLM\SOFTWARE\Wow6432Node\Avisynth" /v "" /d "%AVS_SRC_DIR%\%avs%" reg add "HKLM\SOFTWARE\Wow6432Node\Avisynth" /v "" /d "%AVS_SRC_DIR%\%avs%" /f echo. echo Writing "HKLM\SOFTWARE\Wow6432Node\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR32%" reg add "HKLM\SOFTWARE\Wow6432Node\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR32%" /f if errorlevel 1 ( echo Error on importing registry keys! goto :error ) if "%REGPLUGDIR32PLUS%" GTR "" ( echo. echo Writing "HKLM\SOFTWARE\Wow6432Node\Avisynth" /v "PluginDir+" /d "%REGPLUGDIR32PLUS%" reg add "HKLM\SOFTWARE\Wow6432Node\Avisynth" /v "PluginDir+" /d "%REGPLUGDIR32PLUS%" /f if errorlevel 1 ( echo Error on importing registry keys! goto :error ) ) call :regWow64 ) ) goto :end :regWin echo. echo adding more registry entries... reg add "HKLM\SOFTWARE\Classes\AVIFile\Extensions\AVS" /ve /d "{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /ve /d "AviSynth" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}\InProcServer32" /ve /d "AviSynth.dll" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}\InProcServer32" /v "ThreadingModel" /d "Apartment" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\Media Type\Extensions\.avs" /v "Source Filter" /d "{D3588AB0-0781-11CE-B03A-0020AF0BA770}" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\.avs" /ve /d "avsfile" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\.avsi" /ve /d "avs_auto_file" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\avsfile" /ve /d "AviSynth Script" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\avsfile\DefaultIcon" /ve /d "%WINDIR%\System32\AviSynth.dll,0" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\avs_auto_file" /ve /d "AviSynth Autoload Script" /f >nul 2>&1 if defined avspl (reg add "HKLM\SOFTWARE\Classes\avs_auto_file\DefaultIcon" /ve /d "%WINDIR%\System32\AviSynth.dll,1" /f ) else reg add "HKLM\SOFTWARE\Classes\avs_auto_file\DefaultIcon" /ve /d "%WINDIR%\System32\AviSynth.dll,0" /f goto :eof :regWow64 echo. echo adding more registry entries (wow64 mode)... reg add "HKLM\SOFTWARE\Classes\AVIFile\Extensions\AVS" /ve /d "{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /ve /d "AviSynth" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}\InProcServer32" /ve /d "AviSynth.dll" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}\InProcServer32" /v "ThreadingModel" /d "Apartment" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Wow6432Node\Classes\Media Type\Extensions\.avs" /v "Source Filter" /d "{D3588AB0-0781-11CE-B03A-0020AF0BA770}" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\.avs" /ve /d "avsfile" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\.avsi" /ve /d "avs_auto_file" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\avsfile" /ve /d "AviSynth Script" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\avsfile\DefaultIcon" /ve /d "%WINDIR%\SysWow64\AviSynth.dll,0" /f >nul 2>&1 reg add "HKLM\SOFTWARE\Classes\avs_auto_file" /ve /d "AviSynth Autoload Script" /f >nul 2>&1 if defined avspl (reg add "HKLM\SOFTWARE\Classes\avs_auto_file\DefaultIcon" /ve /d "%WINDIR%\SysWow64\AviSynth.dll,1" /f ) else reg add "HKLM\SOFTWARE\Classes\avs_auto_file\DefaultIcon" /ve /d "%WINDIR%\SysWow64\AviSynth.dll,0" /f goto :eof :uninstall echo. echo Remove %avs% .dll and registry entries from this system? set /p rm=[y/n]: if /i not [%rm%]==[y] goto :cancel echo. if defined winarch ( if /i %avs%==AVSx64 ( echo Attempt to remove x64 AVS from x32 Windows. goto :cancel ) echo removing %avs% files from "%WINDIR%\System32"... del "%WINDIR%\System32\avisynth.dll" del "%WINDIR%\System32\devil.dll" call :unregWin all ) else ( if /i %avs%==AVSx64 ( echo removing %avs% files from "%WINDIR%\System32"... del "%WINDIR%\System32\devil.dll" del "%WINDIR%\System32\avisynth.dll" if exist "%WINDIR%\SysWow64\avisynth.dll" (call :unregWin) else ( call :unregWin all ) ) else ( echo removing %avs% files from "%WINDIR%\SysWow64"... del "%WINDIR%\SysWow64\avisynth.dll" del "%WINDIR%\SysWow64\devil.dll" if exist "%WINDIR%\System32\avisynth.dll" (call :unregWow64) else ( call :unregWow64 all ) ) ) goto :end :unregWin echo. echo removing registry entries... reg delete "HKLM\SOFTWARE\Avisynth" /f reg delete "HKLM\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /f reg delete "HKLM\SOFTWARE\Classes\Media Type\Extensions\.avs" /f if [%1]==[all] call :unregAll goto :eof :unregWow64 echo. echo removing registry entries (wow64 mode)... reg delete "HKLM\SOFTWARE\Wow6432Node\Avisynth" /f reg delete "HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /f reg delete "HKLM\SOFTWARE\Wow6432Node\Classes\Media Type\Extensions\.avs" /f if [%1]==[all] call :unregAll goto :eof :unregAll echo. echo removing more avs registry entries... reg delete "HKLM\SOFTWARE\Classes\AVIFile\Extensions\AVS" /f reg delete "HKLM\SOFTWARE\Classes\.avs" /f reg delete "HKLM\SOFTWARE\Classes\.avsi" /f reg delete "HKLM\SOFTWARE\Classes\avsfile" /f reg delete "HKLM\SOFTWARE\Classes\avs_auto_file" /f goto :eof :noAdmin echo This batch file must run with elevated privileges, so: echo. echo Right click on it and chose "Run as administrator" goto :end :error echo. echo something went wrong... echo. :cancel echo. echo cancelled... echo. :end endlocal echo. pause
#225 | Link |
Average an entire clip, return 1 frame
Is there a filter/function/script in Avisynth that will take the average of an entire clip? That is, to create a single frame from a clip, where each pixel in the result frame is the average of all pixels in that position in the clip. The result could be a clip containing 1 frame (ie 32-bit float), or to write the result to a file, fx TIFF in 32-bit float format?
I am only aware of temporal filters that return the average of 3 to 7 frames at a time, for each frame in a clip (TemporalDegrain(), MedianBlurTemporal(), ex_median(), etc.). The next question will be if this can be done with other statistics, for example maximum, minimum, median? My objective for this is to create a single-frame mask for a clip that isolates specific areas according to the statistic - for example the areas of an image that are consistently dark for the whole scene. (assuming the clip contains a single scene) |
#226 | Link | |
#Or to get a single frame average of all frames in a clip: AviSource("blah.avi") ClipBlend() Trim(FrameCount-1,-1) |
#227 | Link |
Thanks @Reel.Deel. Spot on!
![]() Given that I have 10-bit source (YUV442P10), I assume I should use source.ConvertToStacked() as input to ClipBlend16(), to use all 10 bits in the process (assuming no overflow in the accumulator). Do I need to convert to YUV444P16 first? I'll add my vote for HBD support for ClipBlend, and option for running maximum or minimum. Internal 64-bit float accumulator would also be nice. ![]() |
#228 | Link | ||
Broadcast Encoder
Using the Reel.Deel example, in your case it would be like: Code:
#Indexing the 10bit planar source LWLibavVideoSource("whatever.mov") #Going to 16bit planar ConvertBits(16) #Go to 16bit stacked (MSB and LSB) ConverttoStacked() #Work with 16bit stacked precision ClipBlend16() #Go back to 16bit planar ConvertFromStacked() #Final result with 16bit planar precision Trim(FrameCount-1,-1) Quote:
Cheers, Frank |
#230 | Link | |
![]() If you need 32-bit you can do it with expr but you will have to modify the AvgAll_16 script. |
#232 | Link | |
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
#233 | Link | |
#234 | Link |
Yes, you would match these folder names as given in script.
Or choose your own folder names and match script.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 29th January 2023 at 19:59. |
#235 | Link |
21 years and counting...
I have another syntax question.
Is there any difference between these 3 script snips: 1) Code:
PRE1=filter1() PRE2=filter2(PRE1) filter3(PRE2) Code:
filter1().filter2().filter3() Code:
filter1() filter2() filter3() It would help me to understand some of the more advanced scripts any better. ![]() |
#238 | Link | |
Banana User
Anyway, why this thread is treated like "Ask any question about AvS" thread, when it's about AvS wiki?
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling |
avisynth, faq |
