Old 10th November 2002, 17:01   #21  |  Link
HarryM
Originally posted by sh0dan
When I open MJPEG files with YV12, using Morgan, it has swapped the UV channels (giving me I420 instead of YV12). I'll do a SwapUV function shortly. I'm using an older version of Morgan, so it might be fixed in the latest version.
Thanks for answer.
Can you implement 'SelectRangeEvery' function (for fast compresibility check) too?
HarryM is offline   Reply With Quote
Old 11th November 2002, 16:59   #22  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
How is it different from selectevery?
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 12th November 2002, 09:56   #23  |  Link
vlad59
Vlad, the Buffy slayer
vlad59's Avatar
SelectRangeEvery was included in mpeg2dec.dll by Dividee. I think it's now removed from mpeg2dec3 (by MarcFD) so adding this filter in YV12 is juste a matter of compile.
I can do that tonight.
Vlad59
Convolution3D for avisynth 2.0X : http://www.hellninjacommando.com/con3d
Convolution3D for avisynth 2.5 : http://www.hellninjacommando.com/con3d/beta
vlad59 is offline   Reply With Quote
Old 12th November 2002, 10:31   #24  |  Link
sh0dan
sh0dan's Avatar
Couldn't it simply be included in AviSynth 2.5 (or is that what you meant). The old filters no longer works anyway, so why not just add it as an internal feature?
Old 12th November 2002, 10:49   #25  |  Link
HarryM
SelectRangeEvery is 'must be' for GordianKnot (compresibility check in this famous rip program). I know, actual version GK isn't compatible with Avisynth 2.5, but future...
Old 12th November 2002, 10:51   #26  |  Link
HarryM
I am not (big) programmer, but I think, that implementation of 'SelectRangeEvery' direct into Avisynth2.5 is very easy (few lines of code).
Old 12th November 2002, 10:52   #27  |  Link
vlad59
vlad59's Avatar
Yes it should be included in avisynth 2.5 .
If you need the original code I can send it to you (adding it to field.cpp is just a matter of copy/paste) or if you don't have time I can do this for you.
Vlad59
Old 12th November 2002, 10:58   #28  |  Link
HarryM
SelectRangeEvery is very similar to SelectEvery.
SelectEvery works with alone frames, SelectRangeEvery work with intervals of frames.
E.g.
SelectRangeEvery(280,14)
Select this frames
0 to 13, 280 to 293, 560 to 573, etc.
Old 12th November 2002, 11:07   #29  |  Link
HarryM
Sorry, but i have no experiences with C++ programing and with team programing.
I use relative often VisualBasic or sometime Delphi only.
Old 12th November 2002, 11:23   #30  |  Link
vlad59
vlad59's Avatar
@HarryM
Sorry while posting I was answering to Sh0dan but in the meanwhile you posted two answer too.
So I'll make the modification. don't worry.
Vlad59
Old 12th November 2002, 12:23   #31  |  Link
sh0dan
sh0dan's Avatar
@vlad: I'm doing modifications on field.cpp (I think there is a bug in Separatefields()) today, so feel free to mail or PM me the sources.
Old 15th November 2002, 13:23   #32  |  Link
JohnMK
If someone could make available the SelectRangeEvery-capable binary of mpeg2dec3.dll, I'd be so appreciative.
JohnMK is offline   Reply With Quote
Old 15th November 2002, 14:30   #33  |  Link
vlad59
vlad59's Avatar
SelectRangeEvery will be added in avisynth 2.5's core. So we just have to wait till a new alpha release of avisynth dll.
Vlad59
Old 15th November 2002, 14:59   #34  |  Link
JohnMK
Could that be today please? This is so fundamental.
Old 15th November 2002, 15:30   #35  |  Link
vlad59
vlad59's Avatar
I checked CVS and this function is already added. I won't be able to compile before 5 or 6 hours.
And I don't know if it a really good idea to compile this fresh checkout (I don't know if Sh0dan is modifying something).
Vlad59
Old 15th November 2002, 17:30   #36  |  Link
JohnMK
How about the old compile + this function?
Old 17th November 2002, 19:11   #37  |  Link
SansGrip
Noise is your friend
Question 6:
FluxSmooth supports 2.5/YV12 as of 0.2 .
Regards,
SansGrip
SansGrip is offline   Reply With Quote
Old 18th November 2002, 04:09   #38  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
Be very careful - you cannot use it after a crop, since ffdshow assumes that input pitch = output pitch! This will give the wellknown distorted pictures! I hope someone else has the time to take up the challenge?
Is it more complicated than replacing every instance of 'width' with 'pitch'?
Anyway, I suppose it's about time I figured out how to work with the CVS branch...
Richard Berg is offline   Reply With Quote
Old 18th November 2002, 19:52   #39  |  Link
JohnMK
I just wanted to thank everyone who's made this possible. My encodes are easily -- easily 20-30% faster, just as you say. And quality doesn't look any less. In fact, theoretically, it's better, right?
Old 19th November 2002, 14:30   #40  |  Link
sh0dan
sh0dan's Avatar
1) Unfortunately, yes. It uses both pitch and width, but it only uses ONE pitch. And when input and output images have different pitch, the pictures it distorted. I have an "almost" working version, but there are still one wrong pitch I'm having troubles finding.
2) It's really easy, just use the "avisynth_2_1" branch name to get access to the files.
avisynth, faq
Copyright ©2000 - 2023, vBulletin Solutions Inc.
