17th November 2013, 23:02 | #12761 | Link |
reinstall haali media splitter
18th November 2013, 03:23 | #12762 | Link |
It Still Pops Up...
I've been getting that 0000494A error for awhile now. I noticed that the videos usually have an odd resolution. I've been reencoding the mkv files and that usually does it. I have had maybe one of the last 10 that it didn't get rid of the error. What version of Haali Media Splitter should I be using, just in case the one I'm using is wrong???
21st November 2013, 14:46 | #12764 | Link | |
Post screenshot
21st November 2013, 20:13 | #12766 | Link |
show me content of getinfo.avs
23rd November 2013, 02:42 | #12768 | Link |
Change Temp Folder Location
Hello all. I may be asking a question that was once answered but my apologize as I can't seem to locate it.
I would like to change my temp folder to another drive other than "C". Is this possible. I tried changing it in the ini file but got errors. Reason is that my "C" dive is a low capacity SSD that I simply use for quick booting purposes. I installed everything including program & data on "D", "E" & "F". |
23rd November 2013, 23:35 | #12770 | Link |
RB264 issues (AV synch) after cut/join with VideoRedo
First of all - I really like RipBot264 and have recommended it to numerous friends. Thanks for this extremely useful tool!
I made the mistake of recording my FIL's memorial service with breaks at 30-minute intervals to keep file sizes under 4GB each. The basic specs for the camcorder's resulting video files are: MPEG4 Video (H264) 1920x1080 29.97fps [Video] Audio: Dolby AC3 48000Hz stereo 256kbps [Audio] The plan was to join them when I got home in a lossless manner with a tool I'm most familiar with that does it - VideoRedo TVSuite 4 - and then cut if/where necessary into a file(s) that could then be re-encoded to various filesizes with RipBot264. So far I don't seem to have a problem re-encoding the original 30-minute segments with RB264, but it seems that once they've been altered in any way by VRD (even just a no-re-encode save), they can no longer be re-encoded by RB264 without issues. The issues are that the audio and video either get out of synch or the job "finishes" prior to the video being re-encoded. This is something that never happens when re-encoding with VRD, but I can't get anywhere near the same resulting quality per filesize as with RB264 (most notable at severe compressions). So I guess I could simply use RB264 to re-encode from the original files only, but this really limits the flexibility I have to give people the kind of files they prefer. Besides, I'd really like to have an understanding of what's going on so I can avoid such issues in the future. For reference, I've attached the MediaInfo details for an original file out of the camcorder (MediaInfo - JVC.txt) and what it looks like after being lossless saved out of VideoRedo TVSuite 4 (MediaInfo - VRD.txt). ------------------- Edit: Well, VidCoder seems to be re-encoding the non-re-encoded VRD files, so hopefully any quality difference will be negligible. Last edited by tluxon; 24th November 2013 at 22:55. Reason: Update regarding VidCoder |
25th November 2013, 00:01 | #12771 | Link |
Ripbot264 (Not Responding)
Well, I am having nothing but issues with RipBot264. I have been using it since 1.17.3 and it has worked fine before. At first I wanted to use a machine just to handle the main task of farming out the tasks to other high powered machines in my home. That is the reason I want to use a different drive because i have an SSD in the Main machine. So I have One Master and three slave machines. I run two servers on each of the slaves and the master maintains and hands out the queues. The master .ini file placed the temp on drive E and writes the final mkv on drive E as well.
Everything seems to go well until I get half way through Pass 2 and it just freezes. The encoding dialog says "RipBot264 Client (Not Responding). So I decided to change the Temp back to C drive. Same issue. I decided to have my desktop PC to not only act as a slave in converting but be the master machine as well in handing out the queue. The original master is still holding the original rip created by AnyDVD. Same problem. Also noticed the server windows on the other slave machines are also frozen and (not Responding). Have to force closed. Just fyi I have a cat "6' network for added throughput. Can some one please advise what would be my next step?? Last edited by Viper714; 25th November 2013 at 00:08. |
29th November 2013, 20:54 | #12776 | Link |
Well, I said I reported it. But I didn't say I fixed it =\
I have no solution to offer, its one of the reason I stopped using Ripbot. The headache and uncertainty of it flubbing up in the middle of a job and taking out half my encoding power wasn't worth it for me. |
30th November 2013, 13:53 | #12777 | Link |
Bug...
Hi Everybody,
Got some problems now that i'm under windows 8. Launch Ripbot, add a task, quit, launch Ripbot .. the task list is empty. My temp folder is in the D drive, looking in it i can see that the "job1" folder is deleted as soon as i quit Ripbot... ?!!? I've tried launching tha application in Windows 7 compatibility mode, same, with administrator rights ... not better.. Isn't there an ini file in the temp folder with all pending jobs in it... ? Cause i can't see any... |
30th November 2013, 14:00 | #12778 | Link |
keep jobs queue option checked or unchecked?
30th November 2013, 15:28 | #12779 | Link |
Errrrr what an ass i am ..... using your application for years now and .... i've never seen this option despite the fact it is in the middle of the screen ...
My apologise for wasting your time ... thanks for helping |
