14th August 2015, 13:09 | #13781 | Link | |
15th August 2015, 09:55 | #13782 | Link |
I got this error on one mkv
"DirectShowSource:Renderfile, the filter graph manager won't talk to me (E:\Temp\RipBot264temp\job25\getinfo.avs, line 2)" this is the avs file video=DirectShowSource("E:\***\***.mkv",audio=false).ConvertToYV12() LoadPlugin("D:\DirectCD\Program Setup Files\RipBot264v1.19.0\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=NicDTSSource("E:\Temp\RipBot264temp\job25\33_audio_English.dts") AudioDub(video,audio) WriteFile("E:\Temp\RipBot264temp\job25\info.txt","Framecount") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","Framerate") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","AudioRate") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","AudioChannels") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","AudioLength") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","Width") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","Height ") Trim(0,-1) |
16th August 2015, 02:21 | #13785 | Link |
It turns out this isnt the only program I am having issues with. Both RipBot and PowerISO are making my files and they do not show up in Windows Explorer, but they do show up when I use to program(s) and go to that same location. I don't know what the heck is going on! Thanks for the input guys!
16th August 2015, 07:54 | #13786 | Link | |
ByteShare
17th August 2015, 05:13 | #13789 | Link |
I am using WIndows 10. I just wanted to let everyone no, problem is solved. It appears to have been the Free Comodo Anti-Virus I was using with it. The minute I removed it, I could see and access those files! Thanks everyone!
17th August 2015, 16:01 | #13790 | Link |
Atak, I updated to v1.19.0 today and discovered that the 10 bit x265 you've provided this time is nearly 15MBs in size. Till v1.18.2 the 10 bit x265 file bundled with RipBot used to be about 4.5MB, and I used to update that twice a week from http://builds.x265.eu/ which linked to an almost daily updated 16 bit executable roughly the same size as the one provided in v1.18.2. The URL for x265 that you've listed in the 'Tools' button--a wonderful addition, thank you!--links to an x265 executable that is 4.5 to 5MBs. So that still does not provide me with the same 10 bit x265 which you've provided with the latest version of RibBot. My concerns, most likely unfounded, are as follows:
1. I am assuming that the settings you've provided for HEVC encoding--I've been using the 10 bit progressive profile--are optimized for the x265 you've provided. So ideally I should do my weekly update using the same source as the one you've provided the settings for. 2. With the same assumption: is there a problem if I update on a weekly basis given that your settings are written for the x265 version you provided at the time of v1.19.0 release. If RipBot just needs an x265 executable whatever the source might be then just let me know and then I can go ahead and keep updating from http://builds.x265.eu/ or whichever other site provides regular updates. If there is a particular version of x265 that would work better with RipBot then would you please provide a link for updates which, with x265 development going the way it is, can provide significant boosts in both speed and quality? As I mentioned the x265 link in the 'Tools' section does not link to the file you've bundled in Tools>x265. Thanks! Last edited by lemaireus; 17th August 2015 at 19:12. |
17th August 2015, 19:48 | #13791 | Link | ||
Basically use any x265 binaries you like. There is no special optimization for specific build.
18th August 2015, 14:56 | #13793 | Link |
hello, i have got encode a open matte movie and the result of the encode have black borders over and under. What is wrong?
I have no change the resolution. Log: C:\>"C:\Users\marban\Desktop\Programme\Ripbot24\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job1\job1.avs" -o - | "C:\Users\marban\Desktop\Programme\Ripbot24\tools\x264\x264_x64.exe" --crf 22 --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 2883 --sar 1:1 --level 4.1 --preset veryslow --tune film --ref 4 --no-fast-pskip --rc-lookahead 120 --deblock -1:-2 --qpmin 0 --aq-strength 0.9 --sar 12:11 --stdin y4m --output "C:\Temp\RipBot264temp\video.264" - y4m [info]: 1920x1080p 12:11 @ 10000000/417083 fps (cfr) x264 [info]: using SAR=12/11 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x264 [info]: profile High, level 4.1 C:\Temp\RipBot264temp\job1\job1.avs: 1920x1080, 10000000/417083 fps, 2884 frames x264 [info]: frame I:16 Avg QP:19.35 size: 66944 x264 [info]: frame P:888 Avg QP:22.62 size: 39242 x264 [info]: frame B:1979 Avg QP:23.26 size: 21972 x264 [info]: consecutive B-frames: 6.3% 13.9% 8.2% 43.8% 6.8% 9.2% 2.7% 7.2% 1.9% x264 [info]: mb I I16..4: 24.1% 72.9% 3.0% x264 [info]: mb P I16..4: 13.6% 39.4% 0.4% P16..4: 35.6% 3.5% 2.2% 0.0% 0.0% skip: 5.3% x264 [info]: mb B I16..4: 1.6% 5.2% 0.0% B16..8: 39.8% 5.8% 0.8% direct:12.7% skip:34.0% L0:45.7% L1:50.9% BI: 3.4% x264 [info]: 8x8 transform intra:74.3% inter:88.1% x264 [info]: direct mvs spatial:98.6% temporal:1.4% x264 [info]: coded y,uvDC,uvAC intra: 50.1% 52.3% 2.1% inter: 21.5% 31.9% 0.0% x264 [info]: i16 v,h,dc,p: 25% 20% 18% 37% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 8% 15% 8% 11% 11% 11% 11% 14% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 8% 4% 9% 13% 14% 12% 13% 13% x264 [info]: i8c dc,h,v,p: 37% 36% 22% 5% x264 [info]: Weighted P-Frames: Y:6.3% UV:5.4% x264 [info]: ref P L0: 55.9% 7.1% 22.4% 12.7% 1.8% 0.1% x264 [info]: ref B L0: 84.8% 11.9% 3.3% x264 [info]: ref B L1: 93.8% 6.2% x264 [info]: kb/s:5282.53 encoded 2883 frames, 10.72 fps, 5282.53 kb/s C:\>"C:\Users\marban\Desktop\Programme\Ripbot24\tools\mkvtoolnix\mkvmerge.exe" -o "E:\Fight Club HDTV - (Open Matte) (1)-001_.mkv" --compression 0:none --title "Fight Club HDTV - (Open Matte) (1)-001_" --default-duration 0:24000/1001fps "C:\Temp\RipBot264temp\video.264" --compression 0:none --language 0:ger "C:\Temp\RipBot264temp\job1\Encoded_Audio_1.ac3" --chapters "C:\Temp\RipBot264temp\job1\chapters.txt" mkvmerge v8.2.0 ('World of Adventure') 32bit 'C:\Temp\RipBot264temp\video.264': Using the demultiplexer for the format 'AVC/h.264'. 'C:\Temp\RipBot264temp\job1\Encoded_Audio_1.ac3': Using the demultiplexer for the format 'AC3'. 'C:\Temp\RipBot264temp\video.264' track 0: Using the output module for the format 'AVC/h.264 (unframed)'. 'C:\Temp\RipBot264temp\job1\Encoded_Audio_1.ac3' track 0: Using the output module for the format 'AC3'. The file 'E:\Fight Club HDTV - (Open Matte) (1)-001_.mkv' has been opened for writing. 'C:\Temp\RipBot264temp\video.264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 2095/1080. The cue entries (the index) are being written... Muxing took 4 seconds. ------------------------- Elapsed Time: 00h:04m:34s Last edited by Marban; 18th August 2015 at 15:09. |
18th August 2015, 15:34 | #13794 | Link |
Because you have forgotten to crop those borders in ripbot.
18th August 2015, 18:36 | #13795 | Link |
Hi Atak,
this is a few posts back I got this error on one mkv "DirectShowSource:Renderfile, the filter graph manager won't talk to me (E:\Temp\RipBot264temp\job25\getinfo.avs, line 2)" this is the avs file video=DirectShowSource("E:\***\***.mkv",audio=false).ConvertToYV12() LoadPlugin("D:\DirectCD\Program Setup Files\RipBot264v1.19.0\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=NicDTSSource("E:\Temp\RipBot264temp\job25\33_audio_English.dts") AudioDub(video,audio) WriteFile("E:\Temp\RipBot264temp\job25\info.txt","Framecount") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","Framerate") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","AudioRate") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","AudioChannels") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","AudioLength") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","Width") WriteFile("E:\Temp\RipBot264temp\job25\info.txt","Height ") Trim(0,-1) Do you have any sugestions? (your pm's are full!) |
18th August 2015, 19:50 | #13796 | Link |
Post mediainfo report. Maybe your mkv was encoded by some odd codec.
18th August 2015, 21:55 | #13797 | Link |
Here it is
General Unique ID : 170740912739023209494050400861862561038 (0x807380EFB48043C2A82371C00E49050E) Complete name : E:\***.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 24.8 GiB Duration : 1h 33mn Overall bit rate mode : Variable Overall bit rate : 38.1 Mbps Movie name : *** Encoded date : UTC 2015-06-18 20:44:14 Writing application : mkvmerge v7.9.0 ('Birds') 64bit Writing library : libebml v1.3.1 + libmatroska v1.4.2 _STATISTICS_WRITING_APP : mkvmerge v7.9.0 ('Birds') 64bit _STATISTICS_WRITING_DATE_UTC : 2015-06-18 20:44:14 _STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES DURATION : 01:20:59.396000000 NUMBER_OF_FRAMES : 93 NUMBER_OF_BYTES : 57557 Video ID : 33 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 33mn Bit rate mode : Constant Nominal bit rate : 35.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.704 Title : MPEG-4 AVC / 35000 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1 Language : English Default : Yes Forced : No Audio ID : 34 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 33mn Bit rate mode : Variable Bit rate : Unknown / 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Title : DTS-HD Master Audio 5.1 / 48 kHz / 3956 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Language : English Default : Yes Forced : No Text #1 ID : 1 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Language : Japanese Default : No Forced : No DURATION : 01:33:10.627000000 NUMBER_OF_FRAMES : 134041 NUMBER_OF_BYTES : 23708627328 _STATISTICS_WRITING_APP : mkvmerge v7.9.0 ('Birds') 64bit _STATISTICS_WRITING_DATE_UTC : 2015-06-18 20:44:14 _STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Text #2 ID : 2 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Language : Japanese Default : No Forced : No DURATION : 01:33:11.030000000 NUMBER_OF_FRAMES : 524159 NUMBER_OF_BYTES : 2764814692 _STATISTICS_WRITING_APP : mkvmerge v7.9.0 ('Birds') 64bit _STATISTICS_WRITING_DATE_UTC : 2015-06-18 20:44:14 _STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Text #3 ID : 3 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Language : English Default : No Forced : No Text #4 ID : 4 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Language : French Default : No Forced : No Text #5 ID : 5 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Language : German Default : No Forced : No Text #6 ID : 6 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Language : Italian Default : No Forced : No |
20th August 2015, 12:10 | #13798 | Link |
would you be able to support a yadifmod > nnedi3 option in deinterlacing (with 25fps and a 50fps)... as i find nnedi3 really does do a great job vs yadif by itself?
Regards, p.s. on the batch screen, can you include a denoise option there... as i can't use batch right now as i need to use denoise on every episode. Thanks, |
20th August 2015, 20:34 | #13800 | Link | |
Alternatively, you can create a lossless AVI using an AVISynth script that includes the filter you want and then open the AVI in RipBot. Or use MeGUI which allows for editing the AviSynth scripts to add any filters not already available. Once you get the ability to do anything you like, the 'Bot' aspect of the program kind of disappears. Sorry, and of course I can't speak for Atak_Snajpera, but what you're asking requires the program to go in a new direction and one of its good points is its ease of use. Me, I do all the heavy filtering before ever using RipBot, and only use it to do the final conversion (to x264/AAC/MP4) with no additional filtering. |
