29th January 2020, 21:52 | #18302 | Link |
I've had a couple of encodes hang after it finished encoding (once today, once some months back). The encoding server had appeared to have closed, but Ripbot was just saying please wait. When looking in task manager it was still showing the Ripbot264 Encoding Client (32 bit) process, so I killed the process and then Ripbot went on to mux the chunks and completed successfully.
No idea what's causing this but others may find the above useful if it happens to them. |
30th January 2020, 01:06 | #18303 | Link | |
Grumpy Old Man.
However, what can be done if "part 2" does out of sync at the join.. If I playback the joined movie, and go to the timeline of the join, and watch...as soon as part 2 starts, it's out of sync....how do you "adjust" half the movie ?? Not much point splitting it again, as that's just going back to same problem.
30th January 2020, 03:33 | #18304 | Link |
Grumpy Old Man.
Well, I've given this a try, and it does indeed join the files, HOWEVER, for whatever reason, part 2 is still out of sync...it's +1000ms, which is about the same as the black frames in between parts, that get's added somehow.
30th January 2020, 10:46 | #18305 | Link | |
Are you sure 2 parts are encoded with exactly same settings (options encoder, resolution) ?? |
30th January 2020, 10:49 | #18306 | Link |
atak i would have a question is your software safe to re-encode hdr10 videos? I don't have a 4k tv yet so I can't test if the hdr10 videos re-encoded by ripbot264 send metadata to the tv ... how can I test this without 4k tv?
30th January 2020, 14:19 | #18310 | Link | |
Grumpy Old Man.
Maybe I should re encode them, and make sure they ARE the same. Wasted 2 days on this already I still think it's got something to do with the slight "black" transition between the parts.
30th January 2020, 14:21 | #18311 | Link | |
Grumpy Old Man.
It works via USB port on my LG 4K TV.
31st January 2020, 06:11 | #18312 | Link | |
DE (Distributed Encoding) doesnt have to use more the one computer, but multiple computers can speed up the encoding. It devide the chunks in to 1,2,3... minutes and encode each other and then merge them. You can stop the process at any time, if done inside at chunk, this chunk will have to be reencoded once the process is restarted. But if you have a power loss, then only the chunk (min. 1 min) encoding will be lost. |
31st January 2020, 11:58 | #18313 | Link | ||
Grumpy Old Man.
However, I did manage to join this with out further issue. It seems that whatever is used to join the 2 files together add's an approx 1 sec of black video, but it doesn't add the 1 second to the audio. Hence the instant 1 second of out of sync. Quote:
You're implying that I have NO experience using RipBot...which is so far from the truth, I've been using it for probably 15 years or so. Also, what your suggestion has to do with joining 2 files together, is anyone's guess... So before you provide suggestions on what one should do, check that you are actually targeting a real "newbie" And just a sidenote, the files in question would not load into RipBot, so your suggestions could not be proven.
31st January 2020, 15:22 | #18314 | Link | |
By cons I have read on other forums that it is not advisable to crop / resize the video of the file to be re-encoded so as not to corrupt the HDR10 / HDR10 + metadata, which would be based on positioning data, therefore HDR10 / HDR10 + values should be recalculated ... But the conclusions are not clear, I do not know what to expect. I would like to know your opinion on the subject? Is it better not to crop / resize the video in this case? |
31st January 2020, 15:27 | #18315 | Link | |
I crop my HDR10 files with no problem at all. I have not tried manually extracting the HDR10+ data and entering it into the x265 parameters......yet. |
31st January 2020, 15:38 | #18316 | Link | |
MaxCLL and MaxFALL does not affect anything ? |
31st January 2020, 16:13 | #18317 | Link | |
Regular HDR10 looks great to me so I'm not sure if I can be bothered to mess around with HDR10+ if it's not straight forward. Last edited by duffbeer; 31st January 2020 at 16:35. |
31st January 2020, 17:48 | #18318 | Link | |
By the way, thanks for fixing that 5.1 audio profile size calculation bug. I just noticed that it went away with the update. |
31st January 2020, 20:51 | #18319 | Link | |
31st January 2020, 22:19 | #18320 | Link | |
ByteShare
Personally I use SMDegrain because it is a much more dynamic than MDegrain alone. SMD can be more than you need when compared with just MD, but when you use it right it makes some great results, as with any good filter. All that said, even MD2 has its uses but if you're looking for an all-in-one perfect degrainer it won't happen without some sort of AI (to be invented). I haven't done it much but you could even apply degrain to specific scenes and not all scenes with AVISynth. If you want MD3 create a script and then you can load it when you add a file or when you're running a batch add. [search here others have done this with MD3 or let us know and we'll help] (..\RipBot\Tools\AviSynth plugins\Scripts\Custom) StaxRip has way more filters builtin and I've used it as a base for either getting a filter (if I couldn't get one from a website to work) or getting other filter ideas. RipBot could have more built in filters but personally built-in filters are often only a starting point and not an end point for great video processing/encoding. Maybe the dev feels different but indications are that the dev isn't likely to start adding lots of filters. TLDR degrain filters are tricky and there is not a single use case for one degrain filter/settings, which is why with five builtin degrain options the dev likely didn't see a reason for a sixth. Last edited by byteshare; 31st January 2020 at 22:23. |
