Old 13th February 2020, 14:27   #401  |  Link
staina
@justdan96 Yes one saying UI issue - Red area width and overlap text.
Two saying - Still would it would in the same parts behind command Play PL_MK 0, GPR10 (HEX: 42 82 00 00 00 00 00 00 00 00 00 0A) change command Jump Title 1 (HEX: 21 81 00 00 00 00 00 01 00 00 00 00) to command Break (HEX: 00 02 00 00 00 00 00 00 00 00 00 00). Command Jump Title 1 playback bluray disk over and over in loop order ending playback at the end movie.
staina is offline   Reply With Quote
Old 13th February 2020, 21:37   #402  |  Link
imhh11
Hi, is it possible to add an option for batch jobs ( queue) ?
Old 14th February 2020, 19:00   #403  |  Link
zeropc
Doesn't anyone know how to get the app properly working on macOS?
zeropc is offline   Reply With Quote
Old 14th February 2020, 19:55   #404  |  Link
filler56789
SuperVirus
filler56789's Avatar
According to the official README.md:
This ZIP file for MacOS can just be unzipped and the executables can be used after installing a couple of dependencies.
To install those run the commands below in the Terminal:
ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)" < /dev/null 2> /dev/null
brew install freetype
brew install zlib
which in my not-so-humble opinion is not good enough.
I mean, why no static builds for the Mac operating system?
I have already asked this question but it went ignored
--- by justdan96 and by the "contributors" as well.
Old 15th February 2020, 00:11   #405  |  Link
zeropc
Originally Posted by filler56789 View Post
snip...
Thanks. This worked
Old 15th February 2020, 00:34   #406  |  Link
filler56789
SuperVirus
Thanks. This worked
Great
Now all we have to do is give an to justdan96.
Old 18th February 2020, 08:31   #407  |  Link
justdan96
I haven't tried a static build on Mac, I can look into it at some point. Alternatively we could put the dynamic libraries into the app package. Xavery is working on a native build for Mac so he might be better placed to comment.
justdan96 is offline   Reply With Quote
Old 18th February 2020, 10:09   #408  |  Link
Hombre007
ts MuxeR 2.6.15 fore remuxing UHD discs Q
I’am using ts MuxeR 2.6.15 fore remuxing UHD discs.
I take the v.i. a Complete UHD version and select video and English audio streams and ad the Dutch subtitles. But sometimes I encounter 2 problems.
1. tsMuxer chances the frame rate from 24 too 23,976 by the video stream ab subtitles, bet not de audio. Result the audio is out of sync and the picture stutters.
2. The HDR is not done correctly in the remux. Result the UHD player says that the video stream is SDR or gives a minimum 0.000 and maximum 0.000 Nits instead of o.005 -1.000/4.000 Nits as the source file.
So is this a bug ore do I something wrong?
Hombre007 is offline   Reply With Quote
Old 18th February 2020, 17:17   #409  |  Link
a5180007
To change the audio framerate, the audio needs to be re-encoded first (eg via ffmpeg).
Please provide link for a 20MB sample of the original m2ts -cut with a hex editor.
a5180007 is offline   Reply With Quote
Old 19th February 2020, 11:39   #410  |  Link
Hombre007
Thanks fore responding.
Fore problem no 1. someone gave me a tip.
“Try forcing the video stream to stay in 24p with the change fps option”..
Must try if this works.
I did a Blue-ray folder remux with the full UHD of Pan (2015), Rambo 3 and T2 and they played without HDR on the Oppo-203 UHD player. Even forcing HDR in the player did not work.
But how do a make a 20mb source file?
Old 19th February 2020, 13:07   #411  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Originally Posted by Hart2hart View Post
I posted a way to do this a few years ago. Instead of joining playlists join ssif files. The results are seamless. Only thing I had to do was to fix chapter marks on second half. I’ll see if I can locate it and post link here.
It’s post 9 in this thread
https://forum.redfox.bz/threads/3d-b...e-disks.70932/
Hi Hart2hart,
I just thought I'd get back to you to let you know that I still had NO luck getting this to join together successfully...HOWEVER, I acquired a different "version" of Titanic 3D, that was 2 iso's of approx 45Gb each. I joined the 2 SSIF files, and it worked perfectly, thank goodness.
No short black frames between parts.
There was/is obviously something wrong with the versions that most people have tried to join, with not much success.
Live every day like it's your last, because one day, it will be !! (M$B)
Old 19th February 2020, 13:48   #412  |  Link
hubblec4
Matroska find' ich toll
Feature request
Is it possible in demux-mode to extract a sup-stream and the forced captions of this sup-stream simultaneously?
Old 19th February 2020, 18:39   #413  |  Link
a5180007
Use a Hex editor e.g. HxD, or use simple tools such as Trunc.
Which version of tsMuxer are you using ?
Old 23rd February 2020, 21:16   #414  |  Link
a5180007
Originally Posted by hubblec4 View Post
Feature request
@hubblec4 this is rather the job of a subtitle software.
From the sup in BDSup2Sub, File => Save/Export, check the box to export forced subtitles only.
Old 24th February 2020, 06:22   #415  |  Link
a5180007
Originally Posted by mattmarsden View Post
So when I add a single layer DV mp4 created by DVDFab it says the track is unknown.
Originally Posted by cogira View Post
same here with single layer dolby vision mp4 created by dvdfab.
Originally Posted by imhh11 View Post
@a5180007 I hope you can make tsmuxer to remux the single layer mp4 to TS or M2TS, that would be really awesome. It would allow Atmos + DV (Even though DVDFAB's single layer remux are probably not true DV, it's still progress.)
Also, it would be nice to have the ability to go from dual-layer mp4 to UHD structure. Now we have to demux the mp4 with dlb_mp4demux and then build the UHD structure with tsmuxer.
@mattmarsden @cogira @imhh11 could you please try latest version nightly-2020-02-24--01-10-05 and report any issue, thanks.
@SeeMoreDigital DoVi descriptors have been added for .ts files. Not for .m2ts files, which stay with HDMV descriptors.
Old 24th February 2020, 10:08   #416  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Thanks for letting me know...
Old 24th February 2020, 16:24   #417  |  Link
koka
Look tsmuxerCLI is helper for tsMuxeR - like tsMuxerGUI but CLI
Originally Posted by GeorgeLucas View Post
If I drag an mpls file into the tsmuxer, the German audio tracks and subtitles are only automatically marked, for example.
tsmuxer.py BD/BDMV/PLAYLIST/00000.mpls+ deu.meta =V + =deu ! - deu.iso
koka is offline   Reply With Quote
Old 24th February 2020, 16:24   #418  |  Link
Bandits
Is there a reason the Dolby Vision tracks are placed as number 1 and the main video tracks are number 2? The PID's are correct, main 4113 and Dolby Vision 4117, but I would think that they would open in the correct order. I understand they can be reordered but shouldn't the default be the correct order or does the order even matter if a PID is used?
Blu-Ray Ripper 0.112c/0.21a
Bandits is offline   Reply With Quote
Old 24th February 2020, 16:59   #419  |  Link
SeeMoreDigital
I can confirm that I have just used the 'w64-nightly [2020-02-23--01-10-39]' build to re-mux a couple of 'single layer/stream' Dolby Vision.mp4 files to the .ts container, and they work perfectly with my OPPO (and LG TV combination).
I have also used the same build to re-mux a 'double layer/stream' Dolby Vision.mp4 file to the .ts container, and it works perfectly too
In a few hours time I will try the 'w64-nightly [2020-02-24--01-10-05]' build and report back.
Cheers
Old 24th February 2020, 17:41   #420  |  Link
a5180007
Good to know. HPC and VLC seem to have problems reading the double layer .ts with Dolby Atmos, I haven't found the cause. If anybody can point me to any professionally produced .ts with double layer DV for comparison...
The main change in 02-24 is detection of fragmented MP4. I have tested on few mp4; could anybody report any mp4 not properly detected.
