18th March 2021, 12:40 | #30463 | Link | |
I do know that the GTX1660, GTX1660ti, RTX20x0/30x0, and GTX1650Super use the Turing NVENC chip. But the original GTX1650 still uses the Volta (basically Pascal) encoder so it lacks B-frames and performs like the GTX10x0 line. I've never really done a side by side comparison as I've never had a GTX10X0 card, but I can say I have notice a marked improvement in video quality when using NVENC with my GTX1660ti vs my GTX970. |
19th March 2021, 01:11 | #30465 | Link |
Elit Amans
META file bug?
I'm getting an error in the META file. BDRB thinks the video is a .264 file and puts ****.264 for muxing in the META file. The original file is .hevc and BDRB also correctly saves that file as .hevc but puts wrong extension in the META file.
This has only happened to me in the latest version of BDRB and I haven't yet run it with an older version. Will try also another title to see if it is repeatable. Also want to point out that I do know I have the wrong avisynth installed. The reason for that is to get compability with other software. Of course it could be this that makes it error out but because I have never gotten this error before it might not be related and before I test to install the right version of avisynth I will try earlier version of BDRB and also check for another title to try. LOG: Code:
[03-14-21] BD Rebuilder v0.61.21 [19:44:25] Source: Cinema Paradiso (Theatrical) 4K UHD - Input BD size: 90,40 GB - Approximate total content: [03:35:16.728] - Target BD size: 47,07 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), Two Pass - UHD-BD source detected. - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [19:44:27] PHASE ONE, Encoding - [19:44:27] Processing: VID_00000 (1 of 7) - [19:44:27] Extracting A/V streams [VID_00000] - [19:44:33] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 471 frames - Bitrate: 1 038 Kbs - [19:44:33] Reencoding: VID_00000, Pass 1 of 2 - [19:44:36] Reencoding: VID_00000, Pass 2 of 2 - [19:44:38] Video Encode complete - [19:44:38] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:44:38] Multiplexing M2TS - [19:44:42] Processing: VID_00001 (2 of 7) - [19:44:42] Extracting A/V streams [VID_00001] - [20:22:05] Reencoding video [VID_00001] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 176 826 frames - Bitrate: 43 840 Kbs - [20:22:05] Reencoding: VID_00001, Pass 1 of 2 - [20:41:29] Reencoding: VID_00001, Pass 2 of 2 - [17:54:41] Video Encode complete - [17:54:41] Processing audio tracks - Track 4352 (ita): Keeping original audio - Track 4353 (ita): Keeping original audio - Track 4354 (eng): Keeping original audio - [17:54:41] Multiplexing M2TS - [18:08:22] Processing: VID_00005 (3 of 7) - [18:08:22] Extracting A/V streams [VID_00005] - [18:08:41] Reencoding video [VID_00005] - Source Video: HEVC, 1920x1080 - Rate/Length: 59,940fps, 98 692 frames - Bitrate: 1 858 Kbs - [18:08:41] Reencoding: VID_00005, Pass 1 of 2 - [18:55:10] Reencoding: VID_00005, Pass 2 of 2 - [19:34:59] Video Encode complete - [19:34:59] Processing audio tracks - Track 4352 (ita): Keeping original audio - [19:34:59] Multiplexing M2TS EXIT CODE: -2 - Error in attempt to multiplex: MUX_00005.meta - Can't open file: D:\WORK\WORKFILES\VID_00005.AVS.264 [19:35:03] - Failed to build structure, aborted[03-19-21] Checking System Settings - BD-Rebuilder v0.61.21 - Windows Version: 6.2 [9200] - Working Path Free Space: 113,03GB - AVISYNTH Version: 3.6.1.0, not recommended version - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [03-19-21] Systems Settings Check complete Code:
General ID : 0 (0x0) Complete name : A:\UHDBD\Cinema Paradiso (Theatrical) 4K UHD\BDMV\CLIPINF\00005.clpi Format : Blu-ray Clip info File size : 9.52 KiB Duration : 27 min 26 s Overall bit rate mode : Variable Overall bit rate : 4 521 kb/s Maximum Overall bit rate : 109 Mb/s OverallBitRate_Precision_Min : 4521253 OverallBitRate_Precision_Max : 4521256 Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : 36 Duration : 27 min 26 s Bit rate : 4 139 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.033 Stream size : 812 MiB Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 format_identifier : HDMV Source : 00005.m2ts Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 27 min 26 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 37.7 MiB Language : Italian Service kind : Complete Main bsid : 8 Dialog Normalization : -31 Dialog Normalization : -31 dB compr : -0.28 compr : -0.28 dB dsurmod : 1 dsurmod : Not Dolby Surround encoded acmod : 2 lfeon : 0 dialnorm_Average : -31 dialnorm_Average : -31 dB dialnorm_Minimum : -31 dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dialnorm_Maximum : -31 dB dialnorm_Count : 2389 compr_Average : -2.42 compr_Average : -2.42 dB compr_Minimum : -13.84 compr_Minimum : -13.84 dB compr_Maximum : 6.02 compr_Maximum : 6.02 dB compr_Count : 2380 dynrng_Average : -2.38 dynrng_Average : -2.38 dB dynrng_Minimum : -13.68 dynrng_Minimum : -13.68 dB dynrng_Maximum : 5.88 dynrng_Maximum : 5.88 dB dynrng_Count : 2386 format_identifier : AC-3 Source : 00005.m2ts Text ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 26 min 46 s Delay relative to video : 5 s 72 ms Language : English Source : 00005.m2ts Code:
"C:\Vidsoft\BD_Rebuilder\tools\ffmpeg.exe" -probesize 100MB -i "A:\UHDBD\Cinema Paradiso (Theatrical) 4K UHD\BDMV\STREAM\00005.m2ts" -an -pix_fmt yuv420p10le -f yuv4mpegpipe -strict -1 - | "C:\Vidsoft\BD_Rebuilder\tools\x265-64.exe" - --preset medium --profile main10 --uhd-bd --repeat-headers --vbv-bufsize 45000 --vbv-maxrate 48000 --colorprim bt709 --transfer bt709 --colormatrix bt709 --fps 59.97 --sar 1:1 --qpfile "D:\WORK\WORKFILES\VID_00005.CHP" --keyint 60 --bitrate 1858 --y4m --stats "D:\WORK\WORKFILES\VID_00005.AVS.hevc.stats" --pass 2 --output "D:\WORK\WORKFILES\VID_00005.AVS.hevc"
Windows 11 Pro 64-bit, AMD Ryzen 9 5950X@3.40GHz, 32GB, NVIDIA RTX 2070 8GB, PIONEER BDR-S09XLT, ASUS BW-16D1HT, LG CX 65", Panasonic DP-UB820EB-K, Sony PS3 & PS5 |
19th March 2021, 20:09 | #30466 | Link | ||
Or the other way around you can increase the quality level to reach the same filesize |
19th March 2021, 23:26 | #30467 | Link | |||
A few questions...
No worries! Really appreciate your hard work!
22nd March 2021, 05:56 | #30468 | Link | |
See: https://en.wikipedia.org/wiki/High_E...ers_and_levels |
23rd March 2021, 00:03 | #30469 | Link | |
23rd March 2021, 00:07 | #30470 | Link | |
Something you could try: 1. Set BD-RB up to run with the prediction. 2. Let it start and then fail. 3. Go to the BD Rebuilder folder and look for a file called LASTCMD.TXT 4. Open the file (with NOTEPAD) and cut the command line that is represented there. 5. Open a CMD window, and paste the command. 6. Run it and see what error you get. Then mark/cut-and-paste the information from the CMD window to this thread so I can see the error. Last edited by jdobbs; 23rd March 2021 at 00:10. |
23rd March 2021, 00:26 | #30471 | Link |
@LowDead
Can you post the META file that causes the issue you reported? Just to be clear, the encode went correctly and created a .hevc file -- but when it tried to rebuild the META referenced a .264 file, right? I suspect it has something to do with this: - Rate/Length: 59,940fps, 98 692 frames Last edited by jdobbs; 23rd March 2021 at 00:29. |
23rd March 2021, 03:52 | #30472 | Link | |
Elit Amans
Here comes the content of it: Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --hdmv-descriptors --blu-ray --vbr --auto-chapters=5 --vbv-len=500 --start-time=27000000 V_MPEG4/ISO/AVC, "B:\WORK\FULLDISC\WORKFILES\VID_00007.AVS.264", fps=59.94, insertSEI, contSPS A_AC3, "B:\WORK\FULLDISC\WORKFILES\00007.track_4352.AC3", lang=ita S_HDMV/PGS, "B:\WORK\FULLDISC\WORKFILES\00007.track_4608.sup",lang=eng
23rd March 2021, 04:50 | #30473 | Link | ||
x265: I bolded the encoder settings in the MediaInfo below showing the level and tier settings that I assume tell the encoder what level/tier to use. Code:
---------------------- [03/22/21] BD Rebuilder v0.61.21 [11:21:03] Source: THE_FIFTH_ELEMENT_00001 - Input BD size: 35.37 GB - Approximate total content: [02:05:53.546] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Auto Quality: Very Good (Very Fast), ABR - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [11:21:06] PHASE ONE, Encoding - [11:21:06] Processing: VID_00001 (1 of 1) - [11:21:06] Extracting A/V streams [VID_00001] - [11:24:53] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 181,104 frames - Bitrate: 15,315 Kbs - [11:24:53] Reencoding: VID_00001, Pass 1 of 1 - [15:57:33] Video Encode complete - [15:57:33] Processing audio tracks - Track 4352 (eng): Keeping original audio [15:57:33]PHASE ONE complete [15:57:33]PHASE TWO - Rebuild Started - [15:57:33] Rebuilding BD file Structure [15:58:09] - Encode and Rebuild complete - WORKFILES folder removed. [15:58:10] JOB: THE_FIFTH_ELEMENT finished. ---------------------- MediaInfo: General Complete name : C:\Users\eM-SSD\Videos\HEVC\THE_FIFTH_ELEMENT\\BDMV\PLAYLIST\00000.mpls Format : Blu-ray Playlist File size : 456 Bytes Duration : 2 h 5 min Overall bit rate mode : Variable Overall bit rate : 0 b/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : 36 Duration : 2 h 5 min Bit rate : 22.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (23976/1000) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.442 Stream size : 19.3 GiB Writing library : x265 3.2.1+3-b4b2ecac21f6:[Windows][GCC 9.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=1 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=6 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=15315 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=48000 / vbv-bufsize=45000 / vbv-init=0.9 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 format_identifier : HDMV Source : 00000.m2ts / 00000.m2ts Code:
---------------------- [03/22/21] BD Rebuilder v0.61.21 [16:54:48] Source: THE_FIFTH_ELEMENT_00001 - Input BD size: 35.37 GB - Approximate total content: [02:05:53.546] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Auto Quality: Very Good (Very Fast), ABR - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [16:54:49] PHASE ONE, Encoding - [16:54:49] Processing: VID_00001 (1 of 1) - [16:54:49] Extracting A/V streams [VID_00001] - [16:58:09] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 181,104 frames - Bitrate: 15,315 Kbs - [16:58:09] Reencoding: VID_00001, Pass 1 of 1 - [17:12:05] Video Encode complete - [17:12:05] Processing audio tracks - Track 4352 (eng): Keeping original audio [17:12:05]PHASE ONE complete [17:12:05]PHASE TWO - Rebuild Started - [17:12:05] Rebuilding BD file Structure [17:12:42] - Encode and Rebuild complete - WORKFILES folder removed. [17:12:43] JOB: THE_FIFTH_ELEMENT finished. ---------------------- MediaInfo: General Complete name : C:\Users\eM-SSD\Videos\HEVC\THE_FIFTH_ELEMENT\\BDMV\PLAYLIST\00000.mpls Format : Blu-ray Playlist File size : 456 Bytes Duration : 2 h 5 min Overall bit rate mode : Variable Overall bit rate : 0 b/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4.1@High Codec ID : 36 Duration : 2 h 5 min Bit rate : 22.1 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.445 Stream size : 19.4 GiB Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 format_identifier : HDMV Source : 00000.m2ts / 00000.m2ts |
23rd March 2021, 06:01 | #30474 | Link | |
C:\Windows\system32>"C:\Users\eM-SSD\Downloads\BD-RBV06121\BD_Rebuilder\tools\nvenc\nvencc.exe" --avs -i "C:\USERS\EM-SSD\VIDEOS\HEVC\WORKFILES\TEMP.AVS" --codec hevc --preset performance --profile main10 --output-depth 10 --repeat-headers --colorprim bt709 --transfer bt709 --colormatrix bt709 --qp-min 0 --multipass 2pass-full --vbr 0 --vbr-quality 17.55 --aq --aq-temporal --sar 1:1 --aud --pic-struct --vbv-bufsize 45000 --max-bitrate 48000 --gop-len 24 -o "C:\USERS\EM-SSD\VIDEOS\HEVC\WORKFILES\TEMP.265" -------------------------------------------------------------------------------- C:\USERS\EM-SSD\VIDEOS\HEVC\WORKFILES\TEMP.265 -------------------------------------------------------------------------------- avs: invalid clip. avs: DGSource: Cannot open index file! avs: (C:\USERS\EM-SSD\VIDEOS\HEVC\WORKFILES\TEMP.AVS, line 3) failed to initialize file reader(s). Failed to open input file. |
23rd March 2021, 20:36 | #30476 | Link |
I figured it out. I recently upgraded my dgdecnv2053 to the newer v2053.0.0.228. When I opened the TEMP.AVS I noticed it's reference to the new version folder (I had renamed it), but forgot to copy the license file over from the old version. DUH! Don't know why VBR mode worked and CQM didn't, but it's all good now. Soory about that Chief!
24th March 2021, 23:01 | #30478 | Link |
Errors and... errors
1. Installed latest version and everything as instructed including all recommended components in proper order (Win 10)
2. Registered mscomctl.ocx successfully (as Admin) 3. Made sure mscomctl.ocx is in both \system32 and \sysWOW64 and registered properly. 4. When running BDRB.exe as Admin getting error message that mscomctl.ocx or one if it's dependencies is not properly installed or is missing, despite being successfully registered. 5. Installed VisualBasic6 as per some comment, but no luck. 6. If running BDRB as non-admin, the program tries to config LAV which had been properly installed and already configured during installation and BDRB cannot due it saying I have to run it as Admin (see above). Basically running in circles. 7. Running out of options. Any thoughts? |
25th March 2021, 00:12 | #30479 | Link | |
Elit Amans
Probably another issue for you though.. Just putting the idea out there ^_^ //LD //LD
