21st November 2009, 04:40 | #6061 | Link | |
21st November 2009, 09:19 | #6063 | Link |
It is some months ago, when I did my last reencode with the great BD-Rebuild software.
I just set up a new computer with a fresh Windows 7 x64. After setting up the OS, I installed ffdshow revision 3130, Avisynth 2.5.7 and Matroska Splitter. I activated the MPEG1 and MPEG2 codec, as usual. But trying to reencode a Blu-ray ends in an error. Code:
----------------------- [22:24:32] BD Rebuilder v0.31.02 (beta) - Source: DAS_FUENFTE_ELEMENT - Input BD size: 30,35 GB - Approximate total content: [02:05:35.694] - Target BD size: 22,46 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:24:32] PHASE ONE, Encoding - [22:24:32] Extracting A/V streams [VID_00000] - [22:47:40] Reencoding: VID_00000 (1 of 1) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [22:51:10] - Failed video encode, aborted Code:
[Options] MODE=1 SUPPRESS_FF_WARNING=1 AUDIO_TO_KEEP=deu;gem;ger;gmh;goh; SUBS_TO_KEEP=all SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 TARGET_SIZE=23000 [Paths] SOURCE_PATH=C:\BLU-RAY\DAS FUENFTE ELEMENT\ WORKING_PATH=C:\BLU-RAY\DAS FUENFTE ELEMENT\BD_25\ Code:
"C:\Users\admin\Downloads\BD-RBV03102\BD_Rebuilder\tools\x264.exe" "C:\BLU-RAY\DAS FUENFTE ELEMENT\BD_25\WORKFILES\VID_00000.AVS" --preset medium --qpmin=0 --bitrate 18704 --level 4.1 --sar 1:1 --aud --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --slices 4 --thread-input --stats "C:\BLU-RAY\DAS FUENFTE ELEMENT\BD_25\WORKFILES\VID_00000.AVS.MKV.stats" --pass 1 --output NUL |
21st November 2009, 09:44 | #6064 | Link |
Hi there, new to BD-Rebuilder and Blurays in general. I've been using DVD-Rebuilder for a long time and have even purchased it. Totally worth it.
However, I have not yet been able to test BD-Rebuilder because it refuses to read my Bluray rips. I've ripped 2 BDs - Kung Fu Hustle and Fight Club (Both from Taiwan) with Anydvd HD. When I try to select the source in BD-Rebuilder, I get one of two errors: Code:
SourceCheck() 00055 2501 Code:
SourceCheck() 00006 2501 By the way, this is Windows 7 x64. I have FFDShow, Avisynth, and everything else installed. BD-Rebuilder starts fine... I just can't select a source. |
21st November 2009, 11:13 | #6065 | Link | |
21st November 2009, 13:44 | #6066 | Link | |
BD Rebuilder is not a Decrypter you will need to use AnyDvd or DVDFab6 to first rip the movie to the HD and then use BD Rebuilder to compress the unecrypted movie Edit Just seen you used AnyDvd Hd are you ripping the movie to HD first and then processing with BF Rebuilder Last edited by Dirk Diggler; 21st November 2009 at 13:49. Reason: edit just seen you used AnyDvd |
21st November 2009, 15:49 | #6067 | Link | |
I've also tried selecting the BDMV folder and the STREAM folder, but I get the same error. I've also tried loading AnyDVD and then manually copying the DVD with Windows Explorer. Nothing seems to work. So... am I just seriously unlucky? Do I need to do something specific? |
21st November 2009, 16:35 | #6068 | Link | |
I have never yet had a problem... Perhaps try using this method instead ("rip to image", instead of "rip video DVD") and see what happens? Fork. |
21st November 2009, 17:37 | #6069 | Link | |
Banned
21st November 2009, 19:14 | #6070 | Link | |
BD-Rebuilder Fixed for me
I am very happy to have BD-Rebuilder back and working! |
21st November 2009, 23:33 | #6071 | Link | |
22nd November 2009, 00:04 | #6072 | Link |
@jdobbs;
has your short term experience with Windows 7 been one that you would recommend it for us BD-RB users? It would appear pretty risky at this time, but it sounds like results are mixed, with you reporting mostly success. I really don't think I will be upgrading soon, and have been having only successful results with XP Pro. Perhaps, for me any how, this new OS needs to have more time testing it before I jump in. |
22nd November 2009, 00:23 | #6073 | Link | |
22nd November 2009, 02:53 | #6074 | Link | |
jdobbs, can you shed some light on this error code? anyone else know what I'm doing wrong? I'll pick up another BD and try it on something different next week. |
22nd November 2009, 03:35 | #6075 | Link | |
@MorbidPenguin
Hi! Quote:
2) Are you able to play the purchased discs? 3) What is the total filesize of each of the discs, according to Explorer? |
22nd November 2009, 14:47 | #6076 | Link | ||
Yes, I can play them on my Sony s360. They also work fine with MPC-HC on Win7 x64 Quote:
Anyway, I think it might be a bigger problem between BD-Rebuilder and Win7 x64. I have downloaded the HDMV demo from here: http://www.avsforum.com/avs-vb/showthread.php?t=948496 It's supposed to be an accurate representation of a Bluray Disc for demo purposes. I get the same exact error with that: Code:
11/22/09 [13:45:14] SourceCheck() 00006 2501 jdobbs, is there any file I can post or email you to help you troubleshoot this bug? Thanks. |
22nd November 2009, 17:50 | #6077 | Link | |
@MorbidPenguin
Earlier in this thread is the following post by "drpaulng": http://forum.doom9.org/showthread.ph...19#post1262119 Quote:
23rd November 2009, 01:00 | #6079 | Link | |
