26th January 2018, 14:52 | #81 | Link |
TSM2UHD v1.11
I've updated the first post of this thread with a new release of TSM2UHD.
Changes: Code:
- Added MEDIAINFO to the release (zip file) for collection of UHD and HDR information Note: The version of MediaInfo.exe included with TSM2UHD must be present in the same folder as TSM2UHD.EXE in order for it to execute. - Now adds necessary extensions to MPLS and index.bdmv files. This assures greater compliance. - Several minor changes and updates. - With this version you may often be able to keep original files intact (when they fit on a BD-50). Last edited by jdobbs; 26th January 2018 at 18:02. |
26th January 2018, 20:16 | #83 | Link | |
27th January 2018, 08:16 | #84 | Link |
Still the same problem as I already described. Movie burned on a BDXL 100 Rewriteable, played with UB900. No picture, sound is working properly
mediainfo after TM2Uhd 1.1 Allgemein ID : 1 (0x1) Vollständiger Name : E:\Datensicherung\UHDRips\AlienCov\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : Blu-ray Video Dateigröße : 32,0 GiB Dauer : 2 h 2 min Modus der Gesamtbitrate : variabel Gesamte Bitrate : 37,5 Mb/s maximale Gesamtbitrate : 35,5 Mb/s Video ID : 4113 (0x1011) Menü-ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format-Profil : Main 10@L5.1@High Codec-ID : 36 Dauer : 2 h 2 min Bitrate : 35,3 Mb/s Breite : 3 840 Pixel Höhe : 2 160 Pixel Bildseitenverhältnis : 16:9 Bildwiederholungsrate : 23,976 (24000/1001) FPS ColorSpace : YUV ChromaSubsampling/String : 4:2:0 (Type 2) BitDepth/String : 10 bits Bits/(Pixel*Frame) : 0.177 Stream-Größe : 30,1 GiB (94%) verwendete Encoder-Bibliothek : ATEME Titan File 3.8.3 (4.8.3.0) colour_range : Limited colour_primaries : BT.2020 transfer_characteristics : PQ matrix_coefficients : BT.2020 non-constant MasteringDisplay_ColorPrimaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 MasteringDisplay_Luminance : min: 0.0050 cd/m2, max: 1000.0000 cd/m2 Audio ID : 4352 (0x1100) Menü-ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format_Settings_Mode : 16 Format-Einstellungen für Endianess : Big Codec-ID : 130 Dauer : 2 h 2 min Bitraten-Modus : konstant Bitrate : 768 kb/s Kanäle : 6 Kanäle Kanal-Positionen : Front: L C R, Side: L R, LFE Samplingrate : 48,0 kHz Bildwiederholungsrate : 93,750 FPS (512 SPF) BitDepth/String : 24 bits Stream-Größe : 670 MiB (2%) Text #1 ID : 4608 (0x1200) Menü-ID : 1 (0x1) Format : PGS Codec-ID : 144 Text #2 ID : 4609 (0x1201) Menü-ID : 1 (0x1) Format : PGS Codec-ID : 144 Dauer : 2 h 1 min Video Verzögerung : 3s 86 ms Last edited by wolflop; 27th January 2018 at 08:18. |
27th January 2018, 08:49 | #85 | Link |
Unfortunately, as with the early-ish days of Blu-ray, it seems as though playback of consumer writable and rewritable media at the native format capacity (100 GB here) is not a requirement for players to meet the UHD-BD standard. From what I've seen, it's starting to look as though most players will likely support BD-R/RE 25 GB and 50 GB discs, but very few will support BDXL R/RE 100 GB discs. If the remuxed stream will fit on a BD-R/RE 50 GB disc, have you tried that?
27th January 2018, 10:24 | #86 | Link |
Thanks for the new version, jdobbs.
Unfortunately it still doesn't work like expected on my x800. HDR is not recognized, seems there are still some flags missing. Audio is not sync with video, there is a difference of quite a few minutes at the end of the movie. And the video itself plays better than before, but there are still some occasional stutterings. Hopefully you can figure out what is still missing. If I can help with some additional testing feel free to ask. Thanks for working on this! |
27th January 2018, 11:29 | #87 | Link | |
And After process tsmuxer, every movie duration is set = 01:53:45:443 in mpls file Last edited by no-one; 27th January 2018 at 11:31. |
27th January 2018, 18:05 | #90 | Link | |
Thanks for keeping improving your piece of SW! |
27th January 2018, 18:28 | #91 | Link | |
27th January 2018, 19:00 | #92 | Link | |
27th January 2018, 19:16 | #93 | Link | |
The resulting disc folder didn't play at all on Windows using DVDFab Media Player, but I burnt to a Sony BD-RE 50GB to test on my x800 and got the issues described above... |
27th January 2018, 19:49 | #94 | Link |
movie: Argo UHD (66 GB dual layer disc).
ripped via MakeMKV 1.10.10. demuxed via tsMuxeR 2.6.11. reumuxed main (only) video (HEVC 4K), DTS core English audio, & 2 English PGS streams via tsMuxer 2.6.11. burned & verified with ImgBurn 2.5.8.0 to Verbatim BD-R (not -RE) 50 GB disc via Asus BW-16D1HTv3.00 attempted playback in LG UP870: recognized as Blu-ray disc, but playback immediately fails to main system menu. attempted playback in Xbox One S: playback semi-successful with audio but no video. Xbox bitrate scanner showed as high as ~130 Mbps, which is max allowable bitrate on HTR zone of 66 & 100 GB UHD-BD discs. However, it also reported the stream as 1080p. ran TSM2UHD v1.11 on above-referenced remux: success with no errors reported. burned & verified with ImgBurn 2.5.8.0 to Verbatim BD-R (not -RE) 50 GB disc via Asus BW-16D1HTv3.00 attempted playback in LG UP870: playback attempted, audio fine, video displays decode errors every two seconds or more often, largely as bright monochrome blocks throughout the picture. I noticed there was a pending firmware upgrade for the player, so applied that, but no change in playback results. attempted playback in Xbox One S: playback is largely OK, with no audio issues and only occasional slight stuttering of the video, but result is actually arguably watchable, just not perfect. I'm guessing from this test that the Xbox One S may have the ability to spin BD50s at speeds high enough to ensure smooth(ish) playback of videos encoded somewhere above the max bitrate the spec calls for regarding BD50s, but that the LG UP870 isn't quite as successful. For what it's worth, I'm now burning to BD-RE XL 100 GB, but I don't anticipate that working at all, as neither of my players previously worked with this disc type. --- edit: neither player will recognize the BD-RE XL 100 GB burn (verified via ImgBurn) of Argo. Last edited by A.Fenderson; 27th January 2018 at 22:10. |
27th January 2018, 20:19 | #95 | Link | ||
27th January 2018, 20:20 | #96 | Link | |
28th January 2018, 13:03 | #100 | Link |
Thanks for the great work, the mpls file now contains data extensions HDR, something is missing in the clpi file for HDR activation, replacing the original clpi file in the structure created with TSM2UHD, works HDR.
File clpi original: "ProgramInfo": { "reserved_for_word_align": 0, "program_sequence": [ { "SPN_program_sequence_start": 0, "program_map_PID": 256, "reserved01": 0, "stream_in_ps": [ { "stream_PID": 4113, "stream_coding_type": "H.265", "video_format": "2160p", "frame_rate": "23.976", "aspect_ratio": "16:9", "reserved01": 0, "cc_flag": 0, "reserved02": 4608, "ISRC": { "country_code": "", "copyright_holder": "", "recording_year": "", "recording_number": "" }, "reserved03": 0 File clpi after use TSMuxer and TSM2UHD: "ProgramInfo": { "reserved_for_word_align": 0, "program_sequence": [ { "SPN_program_sequence_start": 0, "program_map_PID": 256, "reserved01": 0, "stream_in_ps": [ { "stream_PID": 4113, "stream_coding_type": "H.265", "video_format": "2160p", "frame_rate": "23.976", "aspect_ratio": "16:9", "reserved01": 0, "cc_flag": 0, "reserved02": 0, "ISRC": { "country_code": "00", "copyright_holder": "000", "recording_year": "00", "recording_number": "00000" }, "reserved03": 0 |
