19th August 2018, 13:40 | #21 | Link |
I may have an idea... Are you able to provide a source which trig the issue creating a file like this :
You choose a small part where the scene change trig the issue, the sample will have 3 scenes, so 2 change scene : [Scene 1][Scene 2][Scene 3]. The issue is trigged between scene 2 and Scene 3. You create an avs script like this (i'm assuming input file is an avi file in lossless codec) : Code:
a = AviSource("Small_Sample.avi").trim(0,xxxx) b = AviSource("Small_Sample.avi").trim(xxxx+1,0) a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+b Put enough "a" to finaly be able to trig the issue at the end of the file. Will that trick enable you to provide a trigged sample, without having to provode the whole file (which is of course totaly not possible) ?
My github. |
21st August 2018, 13:32 | #24 | Link |
Yep, so far the problem appears even with threads=1, and with ABR the problem is even more evident (it last 4 seconds, while with CRF or 2-pass it last up to 1 second).
I gave the source to one dev anyway, so if there's something that needs to be fixed, I guess the git will be updated. Thanks. |
21st August 2018, 18:24 | #26 | Link |
Big Bit Savings Now !
mp3dom, out of interest if my approach would fit your scenario:
Does the bitrate behave properly if you add grain as I suggested in post 8 ? (Since the source is not published, otherwise i would try myself. My encodes were all Bluray 2-pass Level 4.1, slices = 4)
21st August 2018, 21:10 | #27 | Link |
I haven't tried an encode with your settings, but checked the effects of the added grain.
I think there's too much grain compared to the original, tbh. It may probably work but mainly because if the grain is always present throughout the stream, the problem is not "triggered" at all (i.e. x264 always keep the quantizers at a certain level). I see this more like a way to "work around" the problem rather than to fix it. It may work now, but I can't add grain to every stream... |
22nd August 2018, 14:37 | #28 | Link |
That was what I wanted to know, no matter if it is your grain or my grain (the latter being barely noticeable at 2,2,1 delta pixels), it is only my workaround to exactly make "x264 always keep the quantizers at a certain level" and it does not fix the underlying problem, I agree right away from the start.
22nd August 2018, 15:50 | #29 | Link |
Yep, but in fact I thank you for the suggestion and effort, and I'll keep it as an alternative way just in case, but currently, as I work on commercial titles, I can't "deviate" from the real source too much, especially if the title is already available in other countries and can be easily compared.
Also, I guess the grain can't be too low or too much "invisible", because you can get the opposite effect (not enough quantization applied by x264 with blocky grain) |
22nd August 2018, 22:14 | #30 | Link | |
Did you try —level 4.0 —bitrate 25000 —slices 1? If that fixes the problem, that’d narrow down the issue to rate control of slices in particular. I kind of hate slices; even though they work well most of the time, if you have significant variability in content characteristics between the slices, the encoder might wind up with some obvious QP differences along very visible horizontal lines. IIRC Blu-ray only has slices for Level 4.1 to make it easier to make parallelized software decoders for PC playback. Frame-threaded decode is generally preferable, but it’s harder to do with only two B-frames. Sent from my iPad using Tapatalk |
9th September 2018, 15:29 | #31 | Link |
It happens even with level 4.0 and bitrate 25Mbps with 1 slice... but I think to have a little understood the culprit.
The problem appears only with VBV for a basic reason: given the maximum bitrate to be 40 Mbps and focusing on the last second only (where the scene change and the problem appear), the scene-change is at about 3/4 of that second. Previous scene (18 frames length) is bitrate hungry (crf-7 eats about 100 Mbps without VBV) while the remaining 6 frames (where the problem appears) is less demanding (crf-7 eats 40 Mbps without VBV), so x264 allocate the most of the bitrate to the hungry scene leaving not enough bitrate to encode the last 6 frames efficiently. The QPs on the grainy scene are near 15, while on the other scene are near 12. After that second, the scene "regain" its bitrate because the 40 Mbps are now spread across the same kind of scene, and not a new (totally different) one and the average qp is lowered to about 6. I guess adding grain to those 6 frames makes some difference mainly because I just "force" x264 to lower the quality on the grainy scene and give some more bitrate to the gradient scene. |
11th September 2018, 05:19 | #32 | Link | |
16th January 2019, 15:41 | #33 | Link |
I'm resuming this topic just to know if some dev had the chance to take a look into the problem that, depending on the source, may happens more or less often but it's very difficult and time consuming to fix afterwards, even with the use of zones.
Thanks. |
16th January 2019, 17:48 | #34 | Link | |
Also, I'm curious if you tried --slices 1 --vbv-maxrate 25000. It might not make sense in practice, but could pinpoint whether this is a rate control issue specific to slices (which are a relatively rarely used x264 feature). Also, what are the QPs before and after you get the hit? It's possible raising --qpmin some might reduce the initial VBV peak, allowing for a shallower valley to follow. Lastly, perhaps try a third pass to see if that changes anything? |
16th January 2019, 19:34 | #35 | Link |
I was able to fix it a bit (the problem is still there, but less evident) adding a cetain amount of grain to the image, but this clearly is a workaround and not the right way to fix it, since the grain was not there in the source! Also, adding grain is not always enough, it depends on the scene itself and with totally flat sources, adding grain on selected scenes is a no-way... too much evident that there's something wrong.
The problem is triggered when using vbv, 1 slice or 4 slices doesn't make any difference, and the same apply to the use of a third pass or lowering the threads. During and after the "hit" there's a big jump in QP values, I saw a difference of 14-15 on some cases and since the scene is exactly the same, it's clearly visible especially on gradients/shades, albeit the problem last for 1 second. Last edited by mp3dom; 17th January 2019 at 11:01. |
16th January 2019, 19:50 | #36 | Link |
As far as i know, even if trigging the issue is not easy, you have provided the devs specific materials to reproduce the issue since a little time now.
My github. Last edited by jpsdr; 16th January 2019 at 21:37. |
16th January 2019, 19:55 | #37 | Link | |
A temp fix would probably entail reducing the initial peak, so the following valley doesn't need to go so low. Something like --qpmin 8 or --nr 500 might be worth trying. Hopefully lower values could work in practice. |
17th January 2019, 09:41 | #38 | Link | |
Yeah, but it's very time-consuming because if you have 5-6 of these problems in a single movie, it's hard to fix all of them and you're going to encode the movie a lot of time before getting acceptable results. Last edited by mp3dom; 17th January 2019 at 09:44. |
20th January 2019, 22:55 | #40 | Link |
Out of curiosity, while getting back to adding grain as I suggested seemed to help,
has anyone tried x264 incorporated in TMPGEnc AuthoringWorks 5 regarding that matter? I found that private x264 build quite nice for the few occasions I used it on but did not bother doing elaborated comparisons regarding the bitrate drop problem back then...
