9th November 2015, 06:17 | #34161 | Link |
FYI AMD users. I recall at least one report of queues failing to fill in 'fullscreen exclusive mode' while working fine in windowed mode. While chasing such an issue I made the following discovery the hard way.
If you have set the CCC->Performance-Frame Rate to your display refresh rate (or there abouts) in an effort to reduce power consumption be aware that you have capped the frame rate. Therefore 'fullscreen exclusive mode' can't catch-up when the 'render queue' empties however it continues to work just fine in fullscreen window mode. |
9th November 2015, 07:59 | #34162 | Link |
Is there a whitepaper on how the NNEDI3 algorithm roughly works? I'm not sure how to quantify the difference in quality between NNEDI3 32 and NNEDI3 16 on both chroma upscaling and luma doubling, but I can definitely hear/see a difference in the fan speed and utilization of the GTX 670 going from 1280x720 -> 2560x1440
Also, why is the image upscaling algorithm used for chroma upscaling in addition to the selected chroma upscaling algorithm in some instances? Two "chroma > ..." entries are shown in the OSD. I thought that the chroma upscaling algorithm would be used alone or in conjunction with a selected chroma doubling/quadrupling algorithm, if needed. Last edited by dansrfe; 9th November 2015 at 09:17. |
9th November 2015, 08:41 | #34163 | Link | |
madshi,
Zoom Player 11.1 beta2 Max behaves strangely for some reason with the new test DVD, set to use the default AR, derived (recommended). https://www.dropbox.com/s/6ifrmre5xl...tdisc.zip?dl=0 Zoom Control Settings: (these are the only options I have enabled) move subtitles, to bottom of the screen / window. automatically detect hard coded black bars. notify media player about cropped black bars, no more than once every 2 sec. keep black bars visible if they contain subtitles, forever. Here is the result. https://www.dropbox.com/s/ij9asv9tqa...zoom1.jpg?dl=0 If I disable the option notify media player about cropped black bars it works as expected, showing the subtitles rendered into the black bars. https://www.dropbox.com/s/84h1atoxsd...zoom2.jpg?dl=0 Is Zoom Player causing the problem? Last edited by FreeFall; 9th November 2015 at 08:45. |
9th November 2015, 11:35 | #34164 | Link | |
Apparently the issue is related to tags like <i>...</i>. This happens also with <b> and <u>. The tags have the desired effect, the text is visually modified as it should. However when encountering the first line with a tag the subtitles are not shown anymore in the bottom black bar but on the active video area. Hence if the .srt starts with a line that has tags all the subs are shown in the active video area. If the line with tags is in the middle then the subtitles are displayed in the bottom black bar until said line is encountered. Then the subtitles begin to be shown in the active video area. After this happens if I go back with the video the subtitles that were previously correctly shown are now displayed in the active video area too. At this point I think you can easily reproduce this behaviour yourself. If not I will upload the sample. Thanks for your time! |
9th November 2015, 14:25 | #34165 | Link |
I still have stuttering in windowed mode with my mobile nvidia card. no such problems on my AMD laptop though. does anyone know the reason for that?
9th November 2015, 15:47 | #34167 | Link | |
Intel i5 3470, EVGA GTX 1050Ti SC ACX 2.0, Windows 10 Pro 64 bit, 16 GB 1600 mhz DDR3 RAM |
9th November 2015, 16:25 | #34169 | Link | |
Kid for Today
Will run more tests but with sxbr25/50 I find the picture less sharp/appealing now, much like having it applied only once at the end in older builds and the new options don't make up for the PQ decrease as far as I can see =( I guess you expect us to crank up sharpness in sxbr or the new features when I seemingly prefered having SR applied several times in a row, any chance for a dirty hack to have it applied after every 2X step just like before please? something like a "2X step SuperRes" directory in mVR's folder would work if any possible please. Last edited by leeperry; 9th November 2015 at 16:32. |
9th November 2015, 19:21 | #34170 | Link |
10-bit display on nvidia GTX 970
Sorry to digress, but I would really appreciate some advice on this.
I'm thinking of getting a GTX 970 for my HTPC (currently with a Radeon 7850). I hope to get improved nnedi3 performance from my 7850 (currently getting 32 neurons on doubling but cannot do quadrupling) and I would also like to output 10-bit color as I have a 10-bit capable TV. I can do this today with my AMD card but I've read some dubious comments about nvidia's 10-bit output. Can anyone advise me, or better yet does anyone do this today? Thanks a lot!
HTPC: Intel Core i7 2700K, 16GB DDR3 1833, GTX 660Ti, Samsung SSD860, Asus z77, PCIe 3.0 Desktop: AMD Ryzen 3700x, 16GB DDR4, 1TB NVME SSD, Asus x570 Tuf Gaming, Nvidia RTX 2060. |
9th November 2015, 21:34 | #34172 | Link |
Quick question regarding MadVR's gamma processing. My TV has 3 gamma modes, 1.8, 2.2 & 2.4. I've used 2.2 and find shadows too bright, however 2.4 is somewhat odd because it comes out of black just as quickly as 2.2 but is much darker overall. I've found a pleasant compromise with setting the TV to the default 2.2, and setting MadVR to apply a gamma change to 2.35. Nothing is clipped and it comes out of black slowly as it should. Is there any drawback to doing this, quality-wise?
9th November 2015, 22:11 | #34173 | Link | |
After upscaling the subsampled chroma, the luma and chroma are resized together to match the target resolution. This is image upscaling. Image doubling such as NNEDI3 double the luma and chroma separately, which is why you end up with two entries for the chroma channel: one to account for chroma subsampling, and one to account for image upscaling.
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 9th November 2015 at 22:15. |
9th November 2015, 22:59 | #34174 | Link | |
I do 10 bit output madVR + 12 bit output Nvidia CP -> Sony 10 bit capable TV. Everything works with 0 problems! My OCed GTX 970 can do Nnedi3 64 neurons doubling & quadrupling + ED2 + sharpen edges 0.2 + enhance detail 0.5 = SD -> 1080P = 18 ms render time. = 720P -> 1080P = 21 ms render time. Good choice on the GPU (GTX 970 is almost silent + low power usage), hope the upgrade goes well!
i5 OCed 4 Ghz, Zotac GTX 970 Amp! Extreme Oced (GPU 1382/1534 Mhz, Ram 8 Ghz), Windows 7 SP1 x64, madVR x64, MPC-HC x64, Sony Bravia 46". |
9th November 2015, 23:08 | #34175 | Link | |
10th November 2015, 01:05 | #34176 | Link |
You think this combination is better than SuperRes? I haven't tried it with upscaled sources.
10th November 2015, 02:30 | #34177 | Link |
Be warned, the new image enhancement is taking a toll on SVP. I have to sacrifice Sharpen & Thin edges. Frame rendering is still low at 14ms. But you could see frame dropping like a stop watch. Turning those 2 off solves it.
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR Last edited by Magik Mark; 10th November 2015 at 04:17. |
10th November 2015, 06:53 | #34178 | Link |
QB the Slayer
the 4 new refinements are working wonderfully here. There is little to no impact on performance with my R9 270X. All content I watch pushes the GPU to it's limits (except 1080p24) and enabling all 4 refinements still fit in without any sacrifices. So far I have only left the 4 at the default setting of 1 and I am very pleased with the results. Everything looks fantastic, crisp (but not artificially so) and clean.
Here is my settings if anyone is curious: Target Window = 1024x768 (rectangular pixels) @ 72Hz Content 720p24: Artifact Removal = med/high Image Enhancements = ALL OFF Zoom Control = ALL OFF Image Downscaling = Catmull-Rom AR LL Image Upscaling = Jinc AR (Not used) Upscaling Refinement = sharpen, crispen, thin and enhance all set to 1 AND SuperRes set to 4 with LL Chroma Upscaling = NNEDI3 64 Image Doubling = always double luma NNEDI3 128 AND always double chroma NNEDI3 64 Dithering = Ordered Dithering with colored noise checked and change dither unchecked Keep up the awesome work madshi, I love what madVR can do. And I will be front of the line when you start accepting donations. QB
10th November 2015, 07:41 | #34179 | Link | |
10th November 2015, 09:26 | #34180 | Link |
Everything has it's own niche and will work together fine. In some cases it may be better to scale one up rather than have another enabled.. but then someone enabling all of these likely has compared the image quality with things on and off anyway. If you have the performance available might as well use it, I can't imagine someone would just tick things and set values haphazardly.
