Old 14th October 2008, 12:03   #261  |  Link
MOmonster
Sorry no clue about it. Never used MT.
Did it work with mrestore? If not, it is probably a problem with the conditional enviroment.
Could you post the error and your script?
MOmonster is offline   Reply With Quote
Old 15th October 2008, 05:47   #262  |  Link
superuser
I have not used MRestore with MT as had switched to another plugin 6-8 months back.
MT("srestore(frate = 25.0, dmode=4, omode=6, speed=9, blocks=3, thresh=24, chroma=false, dclip=last.crop( 6, 46, -10, -58))", threads=4)
i even took out other params to leave it to below:
MT("srestore(frate = 25.0)", threads=4)
and in both cases I get error below:
If I use above without MT it works fine
thanks for the looking into it
superuser is offline   Reply With Quote
Old 15th October 2008, 15:43   #263  |  Link
MOmonster
I will test MT with the next srestore release and see what I can do for you.
Old 16th October 2008, 08:10   #264  |  Link
krieger2005
krieger2005's Avatar
Before you start to test with MT i would ask the developer if MT support ScriptClip-Enviroments yet. I don't think so. MT is still in development...
krieger2005 is offline   Reply With Quote
Old 17th October 2008, 03:55   #265  |  Link
superuser
thnxs Krieger ... I hve asked for help in MT plugin for the same here
again and lets c what response we get in MT plugin.
In meanwhile I will try out MRestore also and see if tht works or not.
Regards
Old 19th October 2008, 14:33   #266  |  Link
aand
Learning fast
aand's Avatar
Can you implement a <max number of dups/blens in a row> variable? Currently SRestore is cutting blends and also some frames with motion blur, leaving dups behind, breaking the motion.
aand is offline   Reply With Quote
Old 19th October 2008, 15:37   #267  |  Link
MOmonster
@aand
Such a variable won't help much. I'm allready working on a saver detection. Could you upload a sample and post your script, please?
Old 23rd October 2008, 03:26   #268  |  Link
thetoof
Sleepy overworked fellow
I'm having some trouble with a source... It a fieldblended anime that contains regular simple blends (easily detected and removed by srestore) and these wonderful double chroma blends
AnimeIVTC() - v2.00
-http://boinc.berkeley.edu/-
Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p)
thetoof is offline   Reply With Quote
Old 23rd October 2008, 20:22   #269  |  Link
MOmonster
The avi is not the source, or?
A sample of the source would be better.
The chroma is not blended. The chroma-fields shifted. Frame 4 has the chroma of frame 5 and otherwise. That's why it looks like chroma double blending.
Old 23rd October 2008, 22:04   #270  |  Link
thetoof
Yeah, sorry 'bout that, I thought that it was some kind of blending so I uploaded the bobbed clip. It comes from the source in this post.
Thanks for helping.
AnimeIVTC() - v2.00
Old 24th October 2008, 21:54   #271  |  Link
Trixter
I just have to say that, after telling people for 11 years that it was impossible, my jaw dropped the first time I used srestore() today. I took an NTSC interlaced blend of a PAL source, double-rate bobbed it with yadif, and then ran srestore() -- and the source turned into a blended mess into a pure 25fps original. My jaw hit the floor so hard I think I lost a tooth! Excellent work!!
Trixter is offline   Reply With Quote
Old 24th October 2008, 22:18   #272  |  Link
MOmonster
@thetoof
Sorry, really less spare time at the moment, but I will have a look on it.
@Trixter
, I try to make next version even better.
Old 25th October 2008, 18:32   #273  |  Link
thetoof
@MOmonster
Goodie good, take your time.
@Trixter
If you tried TempGaussMC_beta1() instead of yadif, I think your jaw would hit the floor so hard it'd break it
AnimeIVTC() - v2.00
Old 31st October 2008, 06:21   #274  |  Link
EuropeanMan
recently this weekend i tried yadif with srestore() on a source but i couldn't get rid of ghosting properly.
will it be okay if i put a link for a sample ?cuz i'm having problems fixing the ghosting...thanks
EuropeanMan is offline   Reply With Quote
Old 31st October 2008, 17:11   #275  |  Link
MOmonster
@thetoof
I think this is fixable. A script I will create later.
@EuropeanMan
Of course, post the sample! I allready gave a sample on my hd srestore doesn`t get rid of. Post a link, I will use it for the next release.
Old 1st November 2008, 05:18   #276  |  Link
thetoof
Awesome! Here's another sample to play with http://www.mediafire.com/?hdzdyjwnwg0
You'll see the issue around 0:15.680
edit: and here's another new issue (well, it's something new for me ): (post# 331 & 332)
AnimeIVTC() - v2.00
Old 1st November 2008, 05:56   #277  |  Link
EuropeanMan
http://www.sendspace.com/file/ctv6r7
here is the sample and thx in advance
Old 1st November 2008, 17:15   #278  |  Link
EuropeanMan
bump in hopes MOMonster is around to help me with the link provided by 'thetoof' in post 2 above this...
thanks
Old 1st November 2008, 20:21   #279  |  Link
45tripp
Dolphin Blue
45tripp's Avatar
a bump after 12 hours will earn you no favours
injected with feelings; with no final fading
45tripp is offline   Reply With Quote
Old 3rd November 2008, 23:31   #280  |  Link
Piper
Piper's Avatar
Motion Blur
@MOmonster: After a bit of experience with srestore, I've noticed the following with with static scenes. Say someone is talking in an otherwise static scene and they move their head to the side. There's a frame or two delay from when they stop moving and the scene remains motion blurred to when it becomes nice and clear again. Is this simply an unavoidable outcome of this type of pattern matching or is there a threshold one could tweak to tighten this up a bit? Or, is it a bobbing issue? I've used TempGaussMC_beta1() along with all the other usual suspects, but without much success. Any advice?
Piper is offline   Reply With Quote
mrestore, srestore
