27th March 2009, 12:51 | #102 | Link |
HDConvertToX author
set crop to 0, resize to original width
(OR if you are brave test this : http://www.64k.it/andres/data/hdconv...ertToX-ana.exe ) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
27th March 2009, 14:40 | #103 | Link |
HDConvertToX author
update NEW FULL PACKAGE
added support for BassAudio Plugin (only used for "Encode Only Audio" and WMA audio codec) added support for hidden options: shutdown.txt, reboot.txt, suspend.txt added a "Hidden Options files" folder, inside this folder you will found ready hidden options files fixed eac3to is unable to normalize mp2 or aac audio. added a workaround fixed MP3 CBR audio muxing in avi fixed opening supported movie or audio files fixed when opening as input an audio file, there is no more need to analyze the file added anamorphic encoding (thanks to SMD for test!) BHH
27th March 2009, 16:56 | #104 | Link |
Many thanks for these quick updates, just a question, does the tools copy audio function keep Hi Def tracks? I want to backup Rush Hour 3, it has a 7.1 DTS-HD track, would this be muxed with the resulting video, or, is the dts core used as the track in the end result?
Regards |
27th March 2009, 17:31 | #105 | Link | ||
Tiny editing request to buzzqw,
Is it possible when you update the full package to also make the regular (non full-) Update to get some extra info in the TOP POST of this thread, because people don't know if this seperate update still is intended for the full update above it. For example, now we have: Quote:
Full Download (please download also the updates) -> http://www.64k.it/andres/data/hdconv...0.6.97.865.rar Update (for v0.5.94.747) -> http://www.64k.it/andres/data/hdconv...ConvertToX.exe |
27th March 2009, 17:38 | #106 | Link | |
HDConvertToX author
@spida_singh
i haven't such file to test, but "copy" should fuction please try on a sample, and report back @Betsy25 users MUST download the latest full pack AND always the update only the hdconverttox.exe as i say "update" (without mention a "full update") but i agree that your second option Quote:
but.. btw the single exe is less the 1mb... BHH
27th March 2009, 19:40 | #107 | Link | |||
For example, if you only did a minor update to the .exe alone, you could change Quote:
27th March 2009, 20:17 | #108 | Link | |
HDConvertToX author
BHH
28th March 2009, 08:31 | #110 | Link |
HDConvertToX author
do you mean the "AR value" in main window ?
BHH
28th March 2009, 11:17 | #112 | Link | |
HDConvertToX author
thanks Sharc
audio bitrate is editable... write 448 or 640 Quote:
BHH
28th March 2009, 14:55 | #114 | Link |
HDConvertToX author
the options in automkv is for override AR detected
as i said the ar used is the one in main window try yourserlf BHH
28th March 2009, 15:09 | #115 | Link |
Life's clearer in 4K UHD
GUI Layout Proposals
Hi Buzz,
I had rather a lot of time on my hands yesterday and could not stop myself from re-designing the GUI layout... The proposed GUI is a bit larger (at 542x574 pixels) than your current design (at 496x547 pixels). However it provides more room for future option additions: -
28th March 2009, 17:20 | #118 | Link |
HDConvertToX author
you don't have to copy ALL files, just the few one you need
just copy SAP or NMT (for example) BHH
28th March 2009, 18:19 | #120 | Link |
HDConvertToX author
yes, you are right
fixed in next update BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
