7th September 2015, 08:38 | #23101 | Link | |
I am going to use QTGMC deinterlacer, I have tested it in BD-RB and the results were great. You should give it a try in my opinion. The output can be (depending on the source) at single or double-frame rate. Enabling double-frame rate output would be much better but as you told that will violate the BD-standard, although almost surely playable on current players. |
7th September 2015, 09:17 | #23102 | Link | |
So if at all 1080p could be a Alternate output option in BD-RB. Almost always I encode 1080i as interlaced, or exceptionally as 720p bobbed (double rate) which is blu-ray compliant. Especially for shaky hand-held videocam clips I don't like to loose temporal resolution. |
7th September 2015, 14:31 | #23103 | Link | |
7th September 2015, 18:27 | #23104 | Link |
You could always go with 720p60. Sure you are losing a little resolution on width, but the height of 1080i is really only 540 lines once you separate fields. There's minimal quality loss, all the frame rate, and it is BD compliant.
Still, most modern electronics handle interlaced content just fine. Deinterlacing is really unnecessary. |
7th September 2015, 18:56 | #23105 | Link | |
After playing a bit with all the four of the letters the only "issue" I found is that p: affects interlaced sources as well. The other letters seem to be functioning as they should. Last edited by mparade; 7th September 2015 at 19:24. |
7th September 2015, 22:43 | #23106 | Link | |
[Edit] Got it. The only time it should be included on an interlaced source is if you have deinterlacing turned on (meaning you are converting to progressive). The code I was using was logically backwards. Last edited by jdobbs; 7th September 2015 at 22:51. |
10th September 2015, 19:29 | #23107 | Link |
Hello. A reminder of a bug. Inverse Telecining enabled by right-click isn't kept, enabled, used in batch.
[09/10/15] BD Rebuilder v0.50.07 [11:12:52] Source: ANCIENT_ALIENS_S01_E01_-_''THE_EVIDENCE''_(RECORDED_FEB_23,_2015,_H2HD)_00000 - Input BD size: 5.16 GB - Approximate total content: [01:23:42.834] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [11:12:55] PHASE ONE, Encoding - [11:12:55] Processing: VID_00000 (1 of 1) - [11:12:55] Extracting A/V streams [VID_00000] - [11:13:39] Reencoding video [VID_00000] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 150,534 frames - Inverse Telecining in effect (IVTC) - Bitrate: 7,780 Kbs - [11:13:39] Reencoding: VID_00000, Pass 1 of 2 [11:13:47]PHASE ONE aborted by user request ========================== [11:14:37] BD Rebuilder v0.50.07 [11:14:37] BEGIN - BATCH SEQUENCE ========================== ----------------------- [11:14:37] PROCESSING BATCH FILE [1] ---------------------- [09/10/15] BD Rebuilder v0.50.07 [11:14:37] Source: ANCIENT_ALIENS_S01_E01_-_''THE_EVIDENCE''_(RECORDED_FEB_23,_2015,_H2HD)_00000 - Input BD size: 5.16 GB - Approximate total content: [01:23:42.834] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [11:14:38] PHASE ONE, Encoding - [11:14:38] Processing: VID_00000 (1 of 1) - [11:14:38] Extracting A/V streams [VID_00000] - [11:15:15] Reencoding video [VID_00000] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 150,534 frames - Bitrate: 7,780 Kbs - [11:15:15] Reencoding: VID_00000, Pass 1 of 2 [11:15:49]PHASE ONE aborted by user request [11:15:49] BATCH ABORTED... ========================== [11:15:49] END - BATCH SEQUENCE ==========================
11th September 2015, 01:07 | #23109 | Link |
Woohoo! High 5!
11th September 2015, 03:20 | #23110 | Link |
CreateBDFiles() 00063 2004
I made some MKVs from my TiVo MPEG-2 sources so I could include the Closed Captions extracted from the MPEG-2's. Then I had BD-RB import the MKVs. During the Multiplexing process of the first video a pop-up displays this error as it's at the end of the process.
[09/10/15] BD Rebuilder v0.50.07 [18:49:50] Source: BD_VIDEO - Input BD size: 32.26 GB - Approximate total content: [08:21:50.843] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: High-Speed Option (BD-25+), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [18:49:51] PHASE ONE, Encoding - [18:49:51] Processing: VID_00001 (1 of 6) - [18:49:51] Extracting A/V streams [VID_00001] - [18:50:29] Reencoding video [VID_00001] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 150,534 frames - Inverse Telecining in effect (IVTC) - Bitrate: 5,352 Kbs - [18:50:29] Reencoding: VID_00001, Pass 1 of 2 - [18:50:29] Reencoding: VID_00001, Pass 2 of 2 - [19:16:39] Video Encode complete - [19:16:39] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:16:39] Multiplexing M2TS - [19:16:39] CreateBDFiles() 00063 2004 [19:16:52]PHASE ONE aborted by user request [09/10/15] Checking System Settings - BD-Rebuilder v0.50.07 - Windows Version: 6.1 [7601] - Working Path Free Space: 43.06GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [09/10/15] Systems Settings Check complete Code:
[09/10/15] BD Rebuilder v0.50.07 [20:26:30] Source: BD_VIDEO - Input BD size: 25.99 GB - Approximate total content: [06:58:14.398] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: High-Speed Option (BD-25+), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [20:26:32] PHASE ONE, Encoding - [20:26:32] Processing: VID_00001 (1 of 5) - [20:26:32] Extracting A/V streams [VID_00001] - [20:27:17] Reencoding video [VID_00001] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 150,534 frames - Inverse Telecining in effect (IVTC) - Bitrate: 6,825 Kbs - [20:27:17] Reencoding: VID_00001, Pass 1 of 2 - [20:27:17] Reencoding: VID_00001, Pass 2 of 2 - [20:53:30] Video Encode complete - [20:53:30] Processing audio tracks - Track 4352 (und): Keeping original audio - [20:53:30] Multiplexing M2TS - [20:53:52] Processing: VID_00002 (2 of 5) - [20:53:52] Extracting A/V streams [VID_00002] - [20:54:35] Reencoding video [VID_00002] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 150,445 frames - Inverse Telecining in effect (IVTC) - Bitrate: 6,675 Kbs - [20:54:35] Reencoding: VID_00002, Pass 1 of 2 - [20:54:35] Reencoding: VID_00002, Pass 2 of 2 [Update 1]: I don't know what's causing it, yet, but if I exit BD-RB after the prompt, and run it again and resume...it does the multiplexing and continues to the next encode. I'm still testing and haven't played the results.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 12th September 2015 at 03:16. Reason: Update. |
12th September 2015, 00:14 | #23111 | Link |
I have another odd bug. Once after another I imported an MPEG-2 to be sure BD-RB would handle it. Once that was confirmed, I deleted IMPORT and WORKFILES directories after exiting BD-RB, which shouldn't be required. Run BD-RB again, this time select the file in the list as a group to active the Menu Editor. I selected bottom to top to keep the numbering correct. This is what happened.
[13:51:45] Importing MPG: ANCIENT_ALIENS_S01_E01_-_''THE_EVIDENCE''_(RECORDED_FEB_23,_2015,_H2HD) - Preparing MPG for processing... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [13:53:48] Video import completed successfully. ---------------------- [13:57:32] Importing MPG: ANCIENT_ALIENS_S01_E02_-_''THE_VISITORS''_(RECORDED_FEB_2,_2015,_H2HD) - Preparing MPG for processing... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [14:00:14] Video import completed successfully. ---------------------- [14:00:34] Importing MPG: ANCIENT_ALIENS_S01_E03_-_''THE_MISSION''_(RECORDED_APR_16,_2015,_H2HD) - Preparing MPG for processing... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [14:03:38] Video import completed successfully. ---------------------- [14:03:45] Importing MPG: ANCIENT_ALIENS_S01_E04_-_''CLOSER_ENCOUNTERS''_(RECORDED_FEB_9,_2015,_H2HD) - Preparing MPG for processing... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [14:06:11] Video import completed successfully. ---------------------- [14:06:24] Importing MPG: ANCIENT_ALIENS_S01_E05_-_''THE_RETURN''_(RECORDED_FEB_16,_2015,_H2HD) - Preparing MPG for processing... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [14:08:42] Video import completed successfully. ---------------------- [14:09:11] Importing MPG: ANCIENT_ALIENS_S01_E06_BONUS_-_''CHARIOTS,_GODS___BEYOND''_(RECORDED_APR_17,_2015,_HSTRYHP) - Preparing MPG for processing... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [14:11:11] Video import completed successfully. [09/11/15] Checking System Settings - BD-Rebuilder v0.50.07 - Windows Version: 6.1 [7601] - Working Path Free Space: 65.79GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [09/11/15] Systems Settings Check complete ---------------------- [14:26:18] Importing: BD_VIDEO - [14:26:23] Importing video file: (1 of 6) - Preparing MPG for processing... - Collecting audio/video streams from source... - Integrating into pseudo-BD structure... - [14:28:38] Importing video file: (2 of 6) - Preparing MPG for processing... [14:28:39]ERROR: Converting MPG container. Aborted.
13th September 2015, 20:42 | #23112 | Link |
BD Rebuilder v0.50.08
I have updated the first post of this thread with a link to the latest version of BD-RB (v0.50.08). Changes for this release:
- Corrected an error in which, rarely, a BD import may not recognize an episode on a series disc. - Updated the BD import routines so they make proper adjustments for M2TS audio delays. - Added a new setting for ALTERNATE output. You can now select a target output size for CRF encoding. BD-RB will perform prediction passes to determine the proper CRF value. - Corrected an issue when using Dynamic Range Compression with LPCM sources that could cause the audio to be blanked. - Fixed checks so that AVISYNTH 2.6 will now be accepted and listed as "Ok". - Changed code so audio reencoding is forced if DRC has been selected to be applied. - Added new experimental CRF prediction code that can use fewer passes. To enable it see NEW_CRF_PREDICTION in HIDDENOPTS.TXT. - Improved DVD import's recognition of playall PGCs and fixed a rare possibility of on of the episodes in series discs. - Modified code so the state of the manually selected IVTC items in the stream list is retained during batch processing. - Updated the recommended LAV Filters version to v0.65. Updated link in README.TXT. - Updated code to select the 64 bit version of X265 when run on a 64 bit O/S. - Added X265 64 bit build to install package. - Updated the included version of X265 to a newer release (08/23/2015). - Updated the included version of X264.EXE to the latest release (r2597). - Updated the included version of X264-64.EXE to the latest release (r2597). - Other minor corrections and cosmetic fixes. |
13th September 2015, 23:24 | #23115 | Link |
Sorry, it is not a bug but could you please check why I have got this message from PayPal after trying to donate?:
"This recipient is currently unable to receive money." I have tried many times with the same result. Thank you. |
14th September 2015, 00:38 | #23117 | Link | |
On the first page: CURRENT VERSION 0.50.09 (September 13th, 2015) [..] You can download the BD-RB beta from this link: BD-RB v0.50.08.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 14th September 2015 at 00:40. |
14th September 2015, 03:52 | #23118 | Link | |
So donations are not currently possible -- and, needless to say, I'm not very happy with Paypal. As a result, I'm likely to just make DVD-RB Pro available for free along with BD-RB. You'll notice the donation tab missing from BD-RB v0.50.08. I'm not sure whether I will spend any more time in development. If so it will be very little time. I've been continuing for a long time making virtually nothing on this project -- but removing the "virtually" may be the last straw. Last edited by jdobbs; 14th September 2015 at 04:01. |
14th September 2015, 04:19 | #23119 | Link |
Youch! As soon as I run the new version I knew something was happening. Well, I might end my dealing with Paypal if they're going to be that unaware and inform others I know to shift their business. Hmm!! What about Google Wallet, WePay, 2Checkout, Authorize.Net, Skrill, Intuit, ProPay, Click2Sell, Dwolla, Breaintree, ClickBank or Stripe?
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 14th September 2015 at 04:23. |
14th September 2015, 04:36 | #23120 | Link |
What a stupid move, though I think their idea of 'circumventing' is ''if it creates a copy, it's not a retail disc and illegal'. Decryption probably didn't even come into play.
I understand you cutting back on developing but please don't. Create a new Paypal, different method, perhaps even offer a straight up wire transfer? It's my main software to create backups, without development is only a matter of time before a serious issue pops up. My only other option is CloneBD and that's not ready for prime use or as feature packed as bdrb is. Verstuurd vanaf mijn Nexus 7 met Tapatalk |
