12th December 2015, 19:27 | #34581 | Link | ||
Then I tried another file but the TV at 720p cut some borders! (in ctrl+j: Movie Resolution=704x576 and Target Rectangle=0,0,1280,720) Weird thing is that this same file at 1080p shows in ctrl+j: Mov Res=720x576! This is weird, right? Right now I can't control, but I'm quite sure I have "touch from inside" option, if it matters. Thank you for bearing with me! |
12th December 2015, 19:34 | #34582 | Link | |
but after this there is most likely a way to play these files back even on an SDR 1080p screen. BTW. 48 hz is not part of the UBD and hdmi 2.0 spec. |
12th December 2015, 20:33 | #34583 | Link |
sorry I meant HDR which is supposed to require HDMI 2.0a. so in that case a new graphic card with 2.0a support would be needed?
12th December 2015, 21:45 | #34585 | Link | |
You said that Win8.1 is better for madVR then Win7. Can you provide more details? |
13th December 2015, 00:42 | #34588 | Link | |
How desktop composition has an effect on madvr ? I see that it's disabled when Aero is off. |
13th December 2015, 01:03 | #34589 | Link | |
With desktop composition off you should avoid most problems but some users have reported tearing (two different frames displayed in the same v-sync). I am not sure why tearing happens with desktop composition off, madVR should v-sync itself, but I have seen it. It seems like Windows 7's desktop composition was designed while assuming a single monitor at 60 Hz. edit: Do you know if Windowed Overlay works well with Crimson? I want to remove the note about only for Intel and Nvidia in madVR options explained if it does.
madVR options explained Last edited by Asmodian; 13th December 2015 at 01:08. |
13th December 2015, 01:08 | #34590 | Link |
the desktop composition is need for v sync. so with it disabled you don't have v sync so it is need for windowed mode.
the next issue on vista/7 with the desktop composition is that only one desktop composition rate can be used for all devices. so using a laptop with 60 hz only display and a TV is going to ruin your day... than windows vista/7 have a huge issue with changing the desktop composition. for example you switch to 23p to watch a movie but the desktop composition stays at the old 60 hz for what ever reason. this happens all the time... this can be avoided with windows 8+ or FSE/overlay mode. but i'm pretty sure i was able to break FSE on windows 7 too with my dual display setup. but i'm over windows 7 for a long time. aero/desktop composition issue where the reason i sticked to crappy XP x64 for some time. |
13th December 2015, 01:11 | #34591 | Link | |
crimson is just on typical new driver with an new UI that is missing a ton of settings. like deinterlace options and stuff like this. |
13th December 2015, 01:31 | #34592 | Link |
OS + Madvr Stability/Crossfire mode
Win 7 + Madvr = Crossfire always on but stable with no dropped frams
Win 8 + Madvr = Crossfire disabled but you have to use SXBR with no dropped frames (Best Combination) Win 10 + Madvr = Crossfire always on Unstable, Madvr always crashes (Piece of Crap) this was running on 2X HD7850 with Latest AMD Crimson Driver (Beta Hotfix.) All are on tested on a clean installed machine. I suggest you stay away from Windows 10+AMD Crimson Driver combination till they sort this shit out. Now going back to Windows 8. |
13th December 2015, 01:33 | #34593 | Link | ||
I'm using classic theme so no Aero. Also, I use FSE and I didn't check Disable Desktop Composition (I guess it doesn't matter with FSE and no Aero). I didn't know about tearing issue, never saw it on my setup (probably because of FSE). |
13th December 2015, 01:49 | #34594 | Link |
I have Samsung 1080p LED TV, in nvidia control panel I see following screen refresh rates:
23Hz,24Hz, 25Hz Interlaced, 29Hz Interlaced, 30Hz Interlaced, 50Hz, 59Hz, and 60Hz. What do you suggest to put in Display Modes in madvr settings? Also, should I enable Smooth motion (I did so far)? Thanks. |
13th December 2015, 02:11 | #34597 | Link | |
Or nothing and use smooth motion most of the time. Personally I like using smooth motion and not using display modes, it avoids the flicker when changing display modes. If you notice smooth motion's blurring display mode changing is required but if you don't smooth motion is even better because it perfectly matches timings so you never get dropped or repeated frames during normal playback. When using standard refresh rates you need to use Reclock or similar or you still get drops/repeats. Or you can use custom refresh rates and tune the refresh rate to match the source frame rates almost exactly, this is somewhat complicated and requires trial and error. Smooth motion is so easy.
madVR options explained |
13th December 2015, 02:12 | #34598 | Link | |
13th December 2015, 02:28 | #34599 | Link | |
I am trying to see if disabling ULPS or actually forcing Crossfire to on for MPC/madVR will fix the problem. |
